4.75 stroke in a 10.2 Bowtie block - Yellow Bullet Forums
Old 10-26-2007, 11:01 PM   #1
Ryan71nova
Spooled up
Default 4.75 stroke in a 10.2 Bowtie block
How much cuting do you have to do to get a 4.75 stroke crank in a 10.2 deck bowtie block.Also would it be practicul to run 6.7 length rods.Going to be a nos engine.Thanks Ryan
Ryan71nova is offline   Reply With Quote
Old 10-28-2007, 09:59 AM   #2
Ryan71nova
Spooled up
Default
Any body got any info on doing this just wanting to know if it would work better with 4.500 or a 4.750 stroke thanks Ryan
Old 10-28-2007, 10:55 AM   #3
excelerater
Senior Frog
excelerater's Avatar
Default
split the difference 4.625
excelerater is offline   Reply With Quote
Old 10-28-2007, 01:37 PM   #4
MR HORSEPOWER
Pre-Staged
MR HORSEPOWER's Avatar
Default
IT ALL DEPENDS ON WHAT CUBIC INCH YOU WAN'T?IS YOUR BLOCK A REGULAR BOTIE,OR CNC BOWTIE BLOCK?4.750 CAN BE DONE WITH NO PROBLEM.I CAN GIVE YOU EXACT NUMBER'S TO MACHINE TO ON A BRIDGEPORT IF YOU LIKE.
REGARDS
MR HORSEPOWER is offline   Reply With Quote
Old 10-28-2007, 04:26 PM   #5
Ryan71nova
Spooled up
Default
It is a cnc bowtie block 4.560 bore.
Old 10-28-2007, 10:08 PM   #6
Ed-vancedEngines
Location: Temp location. In a bed in McKinney, Tx. Call anytime on Cell 972-464-7400
Default
You should be able to do that stroke but is it worth all the work? I too suggest the 4.625 instead. I most definitely do not like that long of a rod with a 4.750 stroke in a 10.200 block. Where are you going to put your pistons? By the time you do that stroke and that rod the pistons will eithe rbe far too short or sticking far above the deck.
Tell me what Head and valve angle and I will tell you a suggestion based on many years experience of how short your piston can be. Also is this for NOS or gasoline?
Do you have a GM Part # for that block or a Casting number? All of the Bow Tie Blocks are not the same?
Ed
Ed-vancedEngines is offline   Reply With Quote
Old 10-29-2007, 01:16 AM   #7
MR HORSEPOWER
Pre-Staged
Default
YOU STILL HAVE TO CUT THE BLOCK QUITE A BIT TO GET A 4.625 STROKE INTO A BOWTIE BLOCK WITH ALUMINUM RODS,EVEN STEEL RODS.I WOULD NOT USE A 6.700 ROD ,DO TO THE FACT THAT IT LEAVE'S YOU WITH A UNDESIRABLE RING STACK UP,BUT CAN BE DONE MORE SO FOR AN N\A ENGINE.I HAVE PERSONALLY BUILT OVER 40 632'S OUT OF 10.200 BOWTIE BLOCK'S THAT MAKE GREAT POWER AND LIVE JUST FINE WITH MY PERSONAL COMBO.
REGARDS,
Old 10-29-2007, 08:24 AM   #8
Ryan71nova
Spooled up
Default
It is going to be nos engine I am spraying my current combo with 40 jets in nos pro race fogger going to have two foggers on this engine.As far as heads my engine right now has bb2extras on it thinking of going to the 405 BMF for this engine.Wanting the compression ratio to be around 14.1.I will get the casting number some time today off it litte cold to walk out to the garage this morning. How long of a rod would you all use.It is not set in stone to put a 4.75 stroke in it.I have not bought a crank yet or rods.I am going to start working on this combo here pretty quik for next season.I am wanting to try and get between 950 to 1000 hp on the motor that would be 100 to 150 hp stronger than my current engine.ThanksRyan
Old 10-29-2007, 07:45 PM   #9
Ryan71nova
Spooled up
Default
The block is a 14044807 cnc mark4 tall deck bowtie block
Old 10-30-2007, 11:42 AM   #10
joesmithz28
Default
I'd use a 4.625" stroke max. If you're really gonna lean on the kits, then 4.500" would be better so you can build a better piston.
joesmithz28 is offline   Reply With Quote
Old 10-30-2007, 12:03 PM   #11
Ed-vancedEngines
Default
Gen IV bloack = 4.560 maximum bore. I agree 4.500 or 4.625 stroke.
Ed
Old 10-30-2007, 12:18 PM   #12
Outlaw Bill
Outlaw Bill's Avatar
Default
I would go with the 4.500 stroke, it will give you more room to have the correct piston designed.
TeamZmotorsports Stock Suspension 25.3 Outlaw Drag Radial 1991 Mustang
http://www.teamzmotorsports.net/category_s/166.htm
Thank you to the following-
TeamZmotorsports
Marcella Manifolds
Schoneck Composites
Ultimate Converter Concepts
http://www.hardcore50racing.com/vbulletin/index.php
Outlaw Bill is offline   Reply With Quote
Old 10-30-2007, 12:40 PM   #13
NOS-Nelson
Procharger Power
NOS-Nelson's Avatar
Default
Quote:
Yeah what he said.
NOS-Nelson is offline   Reply With Quote
Old 10-30-2007, 01:18 PM   #14
Camaro632
Burnout box
Default
Had no problems with a Dart Big M 10.2 using the 6.7 rod and 4.75 stroke. I do not know if the pan rails etc. are similar in thickness. There was adequate material at both the pan rail and the bottom cylinder wall for grinding purposes.
This motor has been used with mild nitrous, 150-300 with no problems.
Camaro632 is offline   Reply With Quote
Old 10-30-2007, 01:43 PM   #15
Ryan71nova
Spooled up
Default
The block is at standard 4.500 right now I thought you good bore it out 125 over may be mistaken.I am looking to spray it with two foggers no more than 32 jets in both.Thanks Ryan
