SV1 e85 carb - Yellow Bullet Forums
Old 04-22-2011, 08:50 AM   #1
71silvercamaro
Pre-Staged
71silvercamaro's Avatar
Default SV1 e85 carb
Anyone running a sv1 on e85? If so how do you like it and whats your combo? Anyone got experience with one on a street car?
71silvercamaro is offline   Reply With Quote
Old 04-22-2011, 12:36 PM   #2
PUMPGAS
Member
Pullin gears
PUMPGAS's Avatar
Default Re: SV1 e85 carb
I have one and I must say it's flat out amazing. Throttle response is insane compared to my old Dom E85 PS carb. Track results show it gets on the t-brake faster resulting in better RT's on .400 pro trees. I have driven it on the street but not a lot of miles just due to the ware factor of the engine and drive line. I also got the carb to idle down to 850 RPM in gear with out an issues at all, then grab a hand full of throttle and it's at 6K instantly.
Just a few specs on what I have are, sbc on E85 and nitrous.
PUMPGAS is offline   Reply With Quote
Old 04-25-2011, 11:56 AM   #3
71silvercamaro
Pre-Staged
thanks pumpgas
1971 camaro tko 5speed 434 SBC
Old 04-25-2011, 01:48 PM   #4
PUMPGAS
Member
Pullin gears
PUMPGAS's Avatar
Quote:
Originally Posted by 71silvercamaro View Post
thanks pumpgas
Hope that helped with making a choice. If nothing else give Patrick a call and pick his brain to see what he feels would be best for your combo.
Old 04-25-2011, 03:25 PM   #5
98blueSScamaro
Spooled up
98blueSScamaro's Avatar
Quote:
Hey pumpgas what compression you running your setup at and are you spraying wet with e85???? Where do you get your e85from as well
Rob
You think Chrs1313 is slow wait till you see me Run
98blueSScamaro is offline   Reply With Quote
Old 04-25-2011, 05:33 PM   #6
PUMPGAS
Member
Pullin gears
PUMPGAS's Avatar
Quote:
Rob
Rob, my car is carb'd, so yes it is a wet system that I also use E85 in. I get my E85 from the BP station down the street from my house. My engine is only 11-1 so I don't really see the full benefit from the E85 switch as it ran really good on 93 octane and doesn't really need the added octane of the E85, but none the less still runs strong.
Resources saved on this page: MySQL 2.30%
