500ci build, Big Chiefs or DRCE? - Yellow Bullet Forums
Old 04-14-2011, 05:57 PM   #1
Datsun
Spooled up
Datsun's Avatar
Default 500ci build, Big Chiefs or DRCE?
Planning a new engine build and am indecisive on head selection. This is more of a "wannabe" prostock engine build I'm just tinkering around with, I don't think I need DRCE style heads for the application but maybe I do. I want to make a lot of power (though no particular goal), turn some decent RPM's, but don't want to get too crazy with the cam and valvetrain necessary to turn 10,000+ rpm. I don't want to change valve springs all the time. A realistic peak rpm/hp goal for me is at 9000rpm. Bore size will be around 4.6+. I guess my main question for the head guys is how much power advantage am I really looking at stepping up to a DRCE head vs. a well designed/ported 18* (or less) big chief head if all I want to turn it is 9000rpm? Engine will be ran on gasoline, have sheetmetal intake and 2 dominators, 15-16:1 compression, dry sump, yada yada. Curtis or others, what would your recommendation be? Thanks in advance...
Datsun is offline   Reply With Quote
Old 04-14-2011, 06:36 PM   #2
cboggs
cboggs's Avatar
Default Re: 500ci build, Big Chiefs or DRCE?
RFD / Dart 11* head is about as close to a DRCE as you can get in a Big Chief style head, valve angle / location etc, ..
2.52 x 1.82 valves, .. can make a fairly bad ass 500" project. The ports in my cnc are based off of 2006/2007 DRCE prostock stuff.
DRCE is a bunch more money, .. mostly because of all the other machine work and processing to get the castings in running order.
If this was an all out, comp eliminator, puller or something where you need every last little bit, then DRCE.
Curtis
Race Flow Development
http://www.raceflowdevelopment.com
757-222-9717
WD- Brodix-Dart-Edelbrock
cboggs is offline   Reply With Quote
Old 04-14-2011, 07:00 PM   #3
Datsun
Spooled up
Datsun's Avatar
Curtis, exactly what I needed to hear. When I'm ready to pull the trigger on this project I will be getting in contact with you for the heads. Thanks
Old 04-14-2011, 07:04 PM   #4
stix818
Member
Pullin gears
stix818's Avatar
I have a Big Chief 18* headed 500" Oldsmobile that turns 9000.. Makes pretty descent power.. It's a Rodeck (SP) with 4.600" Bore and 3.750" stroke, 9.500" Deck I believe..
Nelson Speed & Marine
Hellbound Train & Heartbeat Dragboat Racing
1986 Cole TR-3 Dragboat
stix818 is offline   Reply With Quote
Old 04-14-2011, 09:58 PM   #5
airflowdevelop
Member
Pullin gears
Do you already have bottom end parts?
Are you sold on staying GM?
Dollar for dollar...the Hemi 99 market is crazy soft right now...
airflowdevelop is offline   Reply With Quote
Old 04-14-2011, 11:06 PM   #6
1fastS10
Spooled up
1fastS10's Avatar
A few years ago I ran a DRCE2 block with olds 14 degree CFE big chiefs at 500 cubic inches. Fairly mild cam (less than 900 lift), spun it just over 9000 rpms and it made over 1200 hp NA. Valve train geometry was a bit screwy and finding head gaskets was a bitch, but it was a very stout motor.
1fastS10 is offline   Reply With Quote
Old 04-15-2011, 10:28 AM   #7
calypso50kid
All motor wannabe
calypso50kid's Avatar
pm outlawbill on here hes running a prostock style motor i believe with drce's
https://squareup.com/store/hays-consulting-llc
Authorized Racepak Dealer if you need anything Racepak related contact me 7346648337
Feature car sept 2016 RPM magazine
http://issuu.com/rpmmag/docs/rpm16-09_webready_reduced
Drag Illustrated 30 under 30 member 2016
https://dragillustrated.com/drag-ill...-a-difference/
URATCHKO RACING ENGINES
SLICK RICK RACING HEADS
DRINK HARD RACING
Carbon Fiber Manufacturing
Team Racepak 2017
calypso50kid is offline   Reply With Quote
Old 04-15-2011, 12:11 PM   #8
Outlaw Bill
Outlaw Bill's Avatar
Acutally its a DRCE 2 block and E-460 heads, but its a messed up cluster now. I'm waiting to see if the heads are fixable/usable or junk for my use. Its called if the heads can't be used, then I need to switch to DRCE 2 heads.................which means machining another block.
TeamZmotorsports Stock Suspension 25.3 Outlaw Drag Radial 1991 Mustang
http://www.teamzmotorsports.net/category_s/166.htm
Thank you to the following-
TeamZmotorsports
Marcella Manifolds
Schoneck Composites
Ultimate Converter Concepts
http://www.hardcore50racing.com/vbulletin/index.php
Outlaw Bill is offline   Reply With Quote
Old 04-15-2011, 12:46 PM   #9
Jim Craig
I've got a complete (pan to manifold -- just freshened) late 90's "vintage" 499 ci DRCE just looking for a new home -- one of pawuk's old pieces.....................you won't need to engineer a thing its done.
Jim Craig is offline   Reply With Quote
Old 04-15-2011, 02:02 PM   #10
vegaman924
vegaman924's Avatar
buy CFEs all you need
vegaman924 is offline   Reply With Quote
Old 04-16-2011, 10:35 AM   #11
NPS Nova
NPS Nova's Avatar
Ok so nobody did, so I will, WHY???
I too have an old. 10,000 RPM 498 inch Pro Stock motor from the late 90's the year the "big" teams went to 4.9 bore spacing. I did it for the Hp to $$$ ratio and it was good for me. BUT most classes hit the heads with weight and you can get "REALLY" close with a set of conventional heads from Curtis or Slick Rick to name a few.
Not sure if I would go this way again if I was doing it over. I think I would use as much of the Pro Stock stuff as I could, but with a "conventional" (if there really is such a thing) heads and a sheetmetal and run from there.
Now if your looking at staying with that style, I think I would go with the 10/11 deg. CFE/Dart castings as they seem to be the power kings. The 12 deg. Raptors are a good head as well. Not sure how much savings $$$ wise these are over the DRCE stuff, but I know there is a lot of used stuff out there and that's not always the case with DRCE I, II, III.
Whatever, just bring it.
NPS Nova is offline   Reply With Quote
Old 04-16-2011, 01:02 PM   #12
R347GT
The Medcine Man
R347GT's Avatar
Quote:
Good luck with that.
R347GT is offline   Reply With Quote
Old 04-16-2011, 08:03 PM   #13
clevo
Datsun,
Are you limited to 500cid ? How much HP are you looking to make,How fast do you want to go ?
clevo is offline   Reply With Quote
Old 05-07-2016, 08:25 PM   #14
widowmaker
Member
Pullin gears
widowmaker's Avatar
My current 500" motor. Makes over 1200 at 8800 rpm.
12 degree reher morrison raptor heads
60mm cam
937 keyway jesel lifters
Donovan aluminum block
Winberg crank
dailey dry sump 6 stage
GPR aluminum rods
Camila Davalos^^
Quote:
Originally Posted by Monty Mikho View Post
No problem.. Now fix your signature... No one needs to scroll 6 pages to get past your post..
widowmaker is offline   Reply With Quote
Old 05-07-2016, 08:45 PM   #15
Ignant
Spooled up
Ignant's Avatar
You may consider this,
https://www.facebook.com/Beck-Racing...6494735395908/
Ignant is offline   Reply With Quote
Resources saved on this page: MySQL 1.03%
