ArkAngel 64 Chevelle build for 9.90 Renegade Racing series - Page 15 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Build Threads > GM Builds
GM Builds Share all GM builds in this section.
Old 06-04-2011, 12:00 AM   #211
Leavinsteven
REBUILDING
Leavinsteven's Avatar
Default Re: ArkAngel 64 Chevelle build for 10.50 Renegade Racing series
Thanks Denn.... 10.50 racers get used to this view!
http://youtu.be/5L5h8pyAG6Q
Life is Drag Racing....
Everything else is waiting.
Leavinsteven is offline   Reply With Quote
Old 06-04-2011, 09:56 PM   #212
Leavinsteven
REBUILDING
I dropped my Block of at Ronnie V's House of Horsepower (Isn't that the coolest name for a Race engine shop you have ever heard!) today, The Official Engine Builder of Summit Motorsports Park.... I love the way that sounds!
Anyways, I spent most of the day planning and mounting the electronics on the electronics panel that I fabricated. I left a little extra space in case I need to ad any thing later.
Here is how it turned out:
Old 06-04-2011, 10:01 PM   #213
Leavinsteven
REBUILDING
I will mount the Electronics plate on rubber pads, on the passenger side foot board. I will also mount a "grounding stud" to use as a ground near the plate. I am thinking about hinging the plate so that it can swing up to be serviced. What do you guys think?
Old 06-05-2011, 10:10 AM   #214
BADBBMONTE
Member
Pullin gears
BADBBMONTE's Avatar
I think if u spent more time workin on it, and less time posting pics n updates you would be done by now.Just busting your balls
BADBBMONTE is offline   Reply With Quote
Old 06-05-2011, 10:53 AM   #215
Leavinsteven
REBUILDING
LOL. I spend enough time working on it and at the job and with the girlfriend and son, to fill out 18 hours, of a 24 hour day! What you don't see is my 3 year old working with me in the garage every day! I have to watch my son FIRST and work on the car SECOND. I am not in a hurry to finish, but I am working hard, just about everyday, to finish. I know your just busting on me, but once the car is done it still wont be fifnished because I have a 10 year plan, for THIS car!
Oh yeh I only post AFTER I am done working on the car. I take pics as I go along, which I have always done for years. I had tons of them, but my laptop crashed a few months ago (before I started this build thred) and the pics are on it!
Old 06-05-2011, 11:01 AM   #216
Leavinsteven
REBUILDING
Now that I have said all that, I think I will go out to the garage and work on the Chevelle.....
Old 06-05-2011, 03:11 PM   #217
gerry
R.I.P DAD 9-25-2012
gerry's Avatar
BADMONTE- YOU HAVE NEREVE MR I NEED 2-3 PEOPLE TO PUT MY ENGINE IN
Its official Making a come back in 2016
R.I.P JAMES PENN 9-25-2012 YOU WILL BE TRUELY MISSED DAD
R.I.P FRANCIS COLEY 7-01-2012
gerry is offline   Reply With Quote
Old 06-05-2011, 10:09 PM   #218
Leavinsteven
REBUILDING
LOL you guys are crazy! I guess thats why we are called the RENEGADES!
Old 06-05-2011, 10:32 PM   #219
Leavinsteven
REBUILDING
Today I ripped out all the old wiring that will not be used. I also use new clothes line to make a mock-up of the front engine compartment harness, from the electronics plate, to everything electric in the engine compartment except the Ignition wiring. That includes the headlights, which is mandatory to race with the Renegades.
I also labeled all the wiring that will be reused, including the overhead switch panel and the rear trunk harness. Finally I know where and what everything is, wiring wise, in the car. I am still trying to figure out why the electric fuel pump has two 40 amp relays wired together????
Here is the wiring that I ripped out:
Old 06-05-2011, 10:36 PM   #220
camaro 77
we ran the 2 relays because of the magnafuel pump that we had in the car and that is what they sell for there really kit
camaro 77 is offline   Reply With Quote
Old 06-05-2011, 10:42 PM   #221
Leavinsteven
REBUILDING
Ahhhh great input! Thanks for the info. It had a Barry Grant 280 in it, when I bought it from Dave though. I bought a Magnafuel ProStar 500 to put in it, so that works out perfect! Keep a eye on your PM's cause if I have anymore questions I will PM you or keep a eye on this thread. Thanks!
Old 06-05-2011, 10:59 PM   #222
Leavinsteven
REBUILDING
The front mock-up harness is completed and next I will remove it and lay it on the ground and starting from the Electronics panel end, I will layout each circuit. They will be held together loosely with zip ties, so I can slide the wire for the circuit in it, until I have all the circuits in the new harness. Once that is done, I will install the harness mounts using the dozen plus pics I took of the mock-up harness. Last, but not least, I will install the Terminal ends. Then it will be on to the next harness until it is completed.
Old 06-06-2011, 12:12 AM   #223
chevydude
chevydude's Avatar
Garage
Quote:
Easy there big boy, this is Index racing! You don't want to be taking all that stripe! LOL!!!!
The Ultimate budget build!!Ford makes it, Chevy shakes it...86 Coupe S/S, BBC Powered 10 to1 489ci very mild..615/.620 flat tapped cam,(Procomp heads)850 alky carb, Powerglide, 4.10's 9" tire.best to date= 1.331 60' & 6.053 @ 112mph 1/8th, Has been 9.90's In the quarter but have not run the quarter since figuring out some issues, Car & motor built by me, Build cost of entire car Just under $5000.00
https://www.youtube.com/watch?featur...&v=kJaN3fgNl1k Still sorting!
chevydude is offline   Reply With Quote
Old 06-07-2011, 08:57 PM   #224
Leavinsteven
REBUILDING
Perfect pass will get em every time.... show em the taillights at the tree! lol!
Old 06-07-2011, 08:58 PM   #225
Leavinsteven
REBUILDING
Garage flooded with that big storm this morning! Im getting tired of this real quick!
Resources saved on this page: MySQL 2.06%
