ArkAngel 64 Chevelle build for 9.90 Renegade Racing series - Page 14 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Build Threads > GM Builds
GM Builds Share all GM builds in this section.
Old 06-02-2011, 10:18 PM   #196
Leavinsteven
REBUILDING
Leavinsteven's Avatar
Default Re: ArkAngel 64 Chevelle build for 10.50 Renegade Racing series
Okay............. Here we go again. I spent some time getting organized today. I needed a plan instead of just jumping in with both feet, in order for the wiring to come out nice, neat, organized and to look Professional. I looked for and found the wiring diagram I made for my 67 Camaro racecar, (which was my first time ever wiring a car from front to back) and I finally found it. I made the diagram BEFORE wiring the 67 Camaro and all the colors of each circuit are the same as on/in the car, so that all trouble shooting and tracing of problems would be much easier! I must have done a good job because I never had any wiring problems with that car. The main difference between that car and this car will be the Camaro used a 3 stage retard and a 3 step and the Chevelle will use a Start retard and a 2 step.
The other difference is that I will be using relays this time.
Here is a pic of Camaro wiring diagram that will be used on the Chevelle again:
http://youtu.be/5L5h8pyAG6Q
Life is Drag Racing....
Everything else is waiting.
Leavinsteven is offline   Reply With Quote
Old 06-02-2011, 10:30 PM   #197
Leavinsteven
REBUILDING
I trashed the old aluminum electronics mounting plate and bought this 16 guage 12"x 12" steel plate from Home Depot for $10. I rounded off and trimmed the sharp corners using a Jig saw and a grinding stone in a drill to smooth the rough edges, because my 3 year old and girlfriend will be riding in the car thru the pits and I do not want them to get cut on it.
Before:
After trimming:
Old 06-02-2011, 10:38 PM   #198
Leavinsteven
REBUILDING
I went looking for the Terminal Blocks/strips or Junction blocks/strips at Advance Auto Parts and they did not have them. Neither did Napa (they wanted to order them for $23 EACH!!!!!!) Auto Parts. I called Summit and they didnt have them either. I then went to Radio Shack and they DID have them for $3.19 each. I bought 3 of them.
Here is a pic of them:
Old 06-02-2011, 10:42 PM   #199
Leavinsteven
REBUILDING
I will ride the Starter Saver and the 2 step piggyback on top of the 7al-2 ignition box to save space.
Old 06-02-2011, 10:45 PM   #200
Leavinsteven
REBUILDING
I will start on the rest of the wiring tomorow and this weekend and I hope to make good progress while the weather is good.
Also I decided to post a pic of how the car looks while I am working on it. Most of the time you see the after pics. Heres what it looks like while I am working on it:
Old 06-02-2011, 10:48 PM   #201
Leavinsteven
REBUILDING
Old 06-02-2011, 10:51 PM   #202
Leavinsteven
REBUILDING
This is why people hate wiring cars! LOL! It was at this point that I decided to take a step back and get organized!
Old 06-03-2011, 12:18 AM   #203
68 nova 10.5
68 nova 10.5's Avatar
Quote:
plan your work and work your plan!
http://s87.photobucket.com/albums/k1...nsperformance/
1.399 60' 3rd pass foot brake no spool stock suspension! On a 9" slick!
68 nova 10.5 is offline   Reply With Quote
Old 06-03-2011, 12:45 AM   #204
Preacher's Kid
Preacher's Kid's Avatar
this car is turning out fantastic!
Matt
9.974@135.55 All Motor
"Like" MotorManiaTV on Facebook!
Check out my videos!
Preacher's Kid is offline   Reply With Quote
Old 06-03-2011, 06:33 PM   #205
Leavinsteven
REBUILDING
Thanks 68 nova 10.5 and that is a great compliment Preacher's kid! It is grea motivation when all the hard work is appreciated and hopefully someone learns from my mistakes and my experiences! I did misspeak a few posts back and this will be my THIRD car I wired from front to back. Here is a pic of the first car. My 27t Altered, "The BleachBox Hero."
Old 06-03-2011, 06:52 PM   #206
Leavinsteven
REBUILDING
The Plan: (as 68 nova 10.5 says) I will be making a mock-up of the wiring harness using clothesline. It is easier than wasting wire by making mistakes and having to start over with new wire. Clothesline is cheaper to make mistakes with.
There will be 3 systems/harnesses that I have to make:
The first will be The engine compartment/front harness.
The second will be The Instrument panel/dash harness.
The third will be The overhead switch panel.
The rear harness was pretty much done and in place when I bought the car.
The overhead panel is partially complete "as bought"and it is "fused" by the manufacturer.
Old 06-03-2011, 07:06 PM   #207
Leavinsteven
REBUILDING
After I complete the mock-up harness and I have everything to length, I will lay it out and build the actual wiring harness's on the ground, by laying each individual wire, using the wiring diagram, on top of the mock up harness. It is slow and tedious work, but if I do it right, it will come out nice and precise.
I will then loosely mount the harness and mock it up in place. Once I am satisfied, I will add the terminal ends and connect them to the "loads/components". I will test the system and then finally turn each component on after I test it. This is the safest way and all it takes is a Ohmmeter to test continuity....BEFORE TURNING THE SYSTEM ON.
THIS IS THE PLAN!
Old 06-03-2011, 11:23 PM   #208
Leavinsteven
REBUILDING
I did not spend any time this evening on the wiring..... I did spend a couple hours FINALLY washing down, oiling up and bagging my engine block and when I get a minute, I will drop it off at V's HOUSE OF HORSEPOWER, The Official Engine Builder of Summit Motorsports Park!
I was supposed to do it about a month ago, but I decided to wait until I was close to having everything else done, so that once I get it back from V's I would be virtually ready to assemble it (I dont want it sitting around, bare block, in my damp garage that seems to leak everytime it rains) and drop it right in. That time is approaching....FAST!
Old 06-03-2011, 11:35 PM   #209
Leavinsteven
REBUILDING
RENEGADES REV' EM UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 06-04-2011, 12:06 AM   #210
denn468
denn468's Avatar
nice pic, steve!
denn468 is offline   Reply With Quote
Resources saved on this page: MySQL 2.11%
