Boosted 70 Chevelle SS 454 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Build Threads > GM Builds
GM Builds Share all GM builds in this section.
Old 01-18-2016, 06:29 PM   #1
BlownShovel
BlownShovel's Avatar
Default Boosted 70 Chevelle SS 454
I've been here for a while but never posted up my car. Car is always in some form of build or redo.
I've owned this car for a couple decades. NA, N2O, Procharger, Turbo, back to Procharger over the years.
Basic info
Factory BB car
Factory suspension
Th400, rear gear 3.73
MT 295/65/15 ET Street Radial
3800+lbs
454+ Reworked factory oval ports, forged rotating assembly, hyd flat tappet, 900cfm carb
Not real fancy - 10. @ 140
Authorized Extreme Velocity Dealer --- Free shipping to YB members w/in continental US
BlownShovel is offline   Reply With Quote
Old 01-18-2016, 06:41 PM   #2
BlownShovel
Default Re: Boosted 70 Chevelle SS 454
Some engine pics - rebuild a few years back
Old 01-18-2016, 06:46 PM   #3
BlownShovel
Fabbed up a basic belt guard - also had to re-alin pulleys for belt groove more toward the center . Needed to space the head unit pulley out. since I added a rear V pulley to the crank pulley for WP/Alternator
Old 01-18-2016, 06:56 PM   #4
superd54
superd54's Avatar
Nice.
I hear a Blower Car.
superd54 is offline   Reply With Quote
Old 01-18-2016, 11:29 PM   #5
PurplePeopleDefeater
PurplePeopleDefeater's Avatar
Sweet looking car, man. What are your plans with it next?
PurplePeopleDefeater is offline   Reply With Quote
Old 01-19-2016, 06:23 AM   #6
Kingsize
Kingsize's Avatar
Nice looking car.
2000 Formula: 615rwhp all motor, TH400, 9" rear
615rwhp Dyno Pull>>> 615rwhp dyno pull N/A - YouTube
9.87@139 Motor Pass>>> http://www.youtube.com/watch?v=CWYRSYr3nys
2006 GTO: Stock bottom all motor LS2, bolt on's, Hutch built PG & GV combo.
Idle Clip>>> http://www.youtube.com/watch?v=s2rKmw2DDZY
www.fquick.com/Kingsize
Kingsize is offline   Reply With Quote
Old 01-19-2016, 07:06 AM   #7
chevyman0429
chevyman0429's Avatar
Gotta love the 70 Chevelle nice ride Sir
chevyman0429 is offline   Reply With Quote
Old 01-19-2016, 08:21 AM   #8
BlownShovel
Thanks guys
Late in the fall I cracked a header tube. I had previously welded a crack on a pipe the year before. Basically the headers are beat and thin as heck at this point. I bought them used 20+ yrs ago. When I pulled them off last month I noticed a date 1989 - guess I got my money's worth. Hooker super comp- 2 piece- looking to replace with hooker comp 1 piece. Slightly smaller but hoping for a better fit. (Plugs, Oil filter, Starter)
Old 01-19-2016, 10:05 AM   #9
offroadr
offroadr's Avatar
Time to order some Lemons! No more bashing tubes
'66 Chevelle 300 Deluxe post - 582 pump gas w/ F2
1148ft lbs 1100hp rear wheel 13lbs boost
offroadr is offline   Reply With Quote
Old 01-19-2016, 11:27 AM   #10
BlownShovel
Lemons would be sweet
I'm trying to go on the cheap - I trial fit some hooker street comps on the engine. They appear to clear the plugs nicely, oil filter can be removed w/o pulling header or dumping it sideways oil all over, no issue with kickout oil pan.
-The real test will be in the chassis itself -
Old 01-19-2016, 11:41 AM   #11
1970ls8
1970ls8's Avatar
Nice ride; thanks for sharing.
Get the Lemons. Pricey but worth it.
(AND if you look at spread out the cost over the years you have had the car.. and it appears you are not letting it go...)
1970ls8 is offline   Reply With Quote
Old 01-19-2016, 03:55 PM   #12
offroadr
offroadr's Avatar
They are well worth the $$, only headers I have never had to beat on to fit.
Old 01-19-2016, 04:21 PM   #13
BlownShovel
Any idea on solid mounts vs rubber? I seem to remember many manufacturers stating you need to use mount x (68 chevelle rubber mounts) in order for their headers to fit. I'm running solid Moroso's.
Are you running solid? - my guess is you have a plate front and mid.
Basically concerned with engine height and clearance issues
Old 01-19-2016, 04:48 PM   #14
offroadr
offroadr's Avatar
I am currently still using stock mounts with solid Mororso mounts. I use a poly trans mount. My headers fit perfect. Dan Lemons will tell you what you need and what will fit. I had to use a particular starter. I have 2 1/4 primary's and 4" collectors
Old 01-19-2016, 04:57 PM   #15
BlownShovel
Pretty sweet setup there - and similar to what I envision. originally I had a full sized tq starter - now mini mini. Glad to hear about the solid/stock like I am.
Resources saved on this page: MySQL 2.04%
