1976 HP on a F2 !! ???? - Page 6 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Supercharged - All Out Automotive
Old 04-12-2011, 08:37 AM   #76
morris
morris's Avatar
Default Re: 1976 HP on a F2 !! ????
I am working hard on some stuff right now and have a F3 deal coming up this week I will be testing with. Big Block Chrysler too!
I will keep you guys posted on the progress.
as far as details it really is the whole combo, but it has some really good heads on it, the cam is a new deal for me and something I am moving towards and we are modifying the blower. More to come on that.
Steve Morris
www.stevemorrisengines.com
morris is offline   Reply With Quote
Old 04-12-2011, 09:18 AM   #77
slim
Member
Pullin gears
slim's Avatar
Quote:
Originally Posted by morris View Post
Craigs just messing with you guys now, the blower spins 54000 not 80000
LOL He had me believing it. Oh well, you don't race power numbers anyway.... Show me a 4.7X or 4.8X this year on that True 10.5 tire keeping it off the bumper; that would be cool.
slim is offline   Reply With Quote
Old 04-12-2011, 09:52 AM   #78
68Bird
68Bird's Avatar
Quote:
Exactly. My work is just beginning! Lots of changes to the entire car to get a handle on.
And yeah, was just messing around with you guys. We're spinning less than 60k which is awesome because the F2 is a super durable piece at that RPM.
Craig
68Bird is offline   Reply With Quote
Old 04-12-2011, 05:19 PM   #79
dan schoneck
dan schoneck's Avatar
Can you guys help me understand this. You guys made 24lbs of boost at 6800rpms and slowed the blower down to 54000rpms and made the same boost of 24lbs but @ 7500? So what blower pulleys are you running. I can tell from this dyno vid that there was around a 48 tooth blower pulley on it and looks to be around a 77-80 crank pulley so that gives me bower speeds of 61000 for the 80-48 and 59000 with the 77-48. If it had a 75/48 it would be 57000rpms of blower speed @ 6800rpms. Now untill you tell us what pulley combo it had, it makes no difference. You would of had to of had a 75-56 to only be at 54000rpms of blower speed at 7500rpms. But there is no way in the vid there is a 56tooth blower pulley on it. Pulley combo that appears to be on during this dyno pull is a 75-80 and no bigger than a 48 so blower speed of no less than 59000 and as much as 63000 @ 7100 when the dyno run ended.
Next what is with the 13.3 af ratio? and the brake specific being lower than the motor that made 1400hp in the other vid. This motor is magically making 250+hp more than any other f2 i have ever seen on an engine dyno and thats alot of boost for a bbc and a f2. The motor that makes 1400hp on your engine dyno has an air fuel of 11.8 and a brake specific of .58 to .68 and this motor is .51-.53. Do you really believe this engine will live on the track with a 13.33 af? Next who ever is talking in the vid talks about the torque falling off after peak power, but look at the a/f again its 13.5 climbing to 13.9.... Those are starting to be NA a/f numbers. Where are the EGT numbers?
Also why does this motor make so much more boost than the motor that made 1400 when it looks like the blowers are pullied real simular and how does this motor have 10lbs more boost on top of the carb then it does below the carb? and the other bbc that made 1400 only has a loss of 4 lbs of boost at 20 above carb and 16 below.
Next what is the fastest a F2 motor of yours has gone in the 1/4 at any givin weight and how much power did it make on your dyno. Before this motor what is the most hp you have seen with a f2 and any dyno vids and dyno data of it. brake specifics, boost by rpm egt etc
How much timing also where you running? I know a bb can handle more due to the bore size but im curious.
Junior has been the fastest ever on radials and a f2. The motor was 360 cubes with heads that flow 360-260 and the car wieghed 3200lbs. The blower can only support x amount of air which in return only makes x amount of hp. Tell me how you got x amount of air to make 250 more hp. How is this possible?
It will be very interesting to see this thing on the track for sure. Mph with wieght and tire will be the real hp calculator and it should run 7. teens @ 3200lbs on radials, cause juniors car maybe made 1700hp at the flywheel to go 7.38/191 and I think he will agree.
Cant wait to see updates on this......
Later Dan
www.schoneckcomposites.com 507-525-3333 Your one stop Mustang Composite shop. 79-09 Mustang Composites
add us on facebook (SchoneckComposites)
Also Wanted 2005-2006 Ford GT Supercar parts Buy sell Trade
dan schoneck is offline   Reply With Quote
Old 04-12-2011, 05:25 PM   #80
scott foxwell
scott foxwell's Avatar
Had me going.
Heads and cam can be huge.
Induction Development Specialties
Retail/wholesale parts sales
Custom cams
423 391 7774
New Canfield BB Chevy heads now available!
Acts 2:38, the perfect answer to the perfect question.
scott foxwell is online now   Reply With Quote
Old 04-12-2011, 05:29 PM   #81
scott foxwell
Lot of the very same questions I've had in my mind since this thread started, but too lazy to type out. (I hate typing...I have ten thumbs)
Later Dan
Custom cams
423 391 7774
Old 04-12-2011, 05:43 PM   #82
Vader Ta
Procharged SBC Enthusiast
Vader Ta's Avatar
Its all in the Flux Capacitor
Vader Ta is offline   Reply With Quote
Old 04-12-2011, 05:48 PM   #83
PCHARGED70
Member
Pullin gears
PCHARGED70's Avatar
Quote:
wasn't it set to 21.1 jigowatts !!!!
PCHARGED70 is offline   Reply With Quote
Old 04-12-2011, 05:50 PM   #84
mark micke
Launchin
Later Dan
They got the new Dave W limited edition F-2. LOL
M&M Transmission 573-636-4136
2008 NMCA Prostreet champ
2013 NMCA Super Street champ
2013 ADRL Pro Drag Radial champ
mark micke is offline   Reply With Quote
Old 04-12-2011, 06:25 PM   #85
dennysavage
dennysavage's Avatar
Quote:
I heard that too....
dennysavage is offline   Reply With Quote
Old 04-12-2011, 06:28 PM   #86
67AfroMaro
That guy...
67AfroMaro's Avatar
I want one... GOLD PLATED!!!
DJ Reid - www.afromaro.com
Vortech Superchargers
Chris Alston's Chassisworks
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Unlimited Fiberglass
Holley Performance
Flatiron Racecars
Follow me on Facebook
Follow my build on
67AfroMaro is offline   Reply With Quote
Old 04-12-2011, 07:15 PM   #87
dan schoneck
The Dave W limited blower came from me and its only worth 75-80hp Mark you have dyno'd enough Procharger stuff, What do you think when you see the a/f ratio's and the bsfc?
Old 04-12-2011, 09:21 PM   #88
morris
morris's Avatar
Ya know, I put up these videos and show all the info, good, bad or different. It is me that does the talking on the videos.
Couple things
BSFC is reflection of efficiency not total fuel flow used.
your wrong on the pulley combo, Craig can chime in if he wants to tell the pulley combo, The 1400 engine you are looking at is a unported head and intake with a different cam.
I Don't know what your talking about 10 PSI on top of the hat, I think your reading fuel pressure not boost differential like I did on the other engine.
4150 carbs have more boost differential than Dominators. Hence different boost in the manifolds and efficiency. less boost differential, more efficient.
Timing setting, Not telling, don't feel like saying what my combos need compared to your engine or anyone else. just someone else saying it wont work.
I dont do lots or F2 race only builds, Mike Jones, last year made 1300 HP Non intercooled and went 7.99 at 174 in a 3400lbs 10 in stock suspension car. The math works and my dyno is not happy.
AFR's don't mean anything, they are a tuning tool not the gospel, Plugs are, yes the carb is at its limit and starting to go lean. But it is not as bad as it seems.
As far as Juniors car, its awesome, next.
as far as it only has X amount of air, change X.
I am the only one to lose on this, I told both Craig and Jake I would take crap about this, and now if Craigs brick of a car, doesn't go 4.70's then I look bad.
I just put all this info out there, people can look at it, and call BS on me if you want, the track tells all, And yes I think it will go 7.30s all out, why not 7.10's?? it is not a Fox body mustang! thats why not.
Steve Morris
Old 04-12-2011, 09:30 PM   #89
scott foxwell
Thanks Steve. Unfortunately the scepticism comes with the territory when someone pushes the envelope that far. You do an amazing job with these Procharger engines and I, for one, have a a lot of respect for what you do, your experience, and the time you give here.
Custom cams
423 391 7774
Old 04-12-2011, 09:33 PM   #90
67AfroMaro
That guy...
67AfroMaro's Avatar
I bought a couple of your videos and he's right... your voice is not very sexy... but then again, it's a dyno video, not a porno.
Thanks for posting Steve, it gives the rest of us F2 guys something to shoot for.
I can help with that
Oh SNAP! You tell them lemmings
Oh and... when can I order my new 1900HP parts?
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Holley Performance
Flatiron Racecars
Follow my build on
