Spark Plug gap to small? - Yellow Bullet Forums
Old 04-03-2011, 05:27 PM   #1
Natas_69
Spooled up
Natas_69's Avatar
Default Spark Plug gap to small?
What type of symptoms have you all seen when a spark gap is to small?
Vehicle in question was running @ .035" with out any issues. Then the motor wouldnt rev starting checking things out and regapped to .025". Nothing changed. Later realized it was the crank trigger pick up.
I never regapped the plugs; I am just curious as to what would be the results?
www.supernaturalturbo.com
Natas_69 is offline   Reply With Quote
Old 04-03-2011, 07:47 PM   #2
Toaster64
Toaster64's Avatar
Default Re: Spark Plug gap to small?
A lot of people around here run .022 gap on booted apps. .035 is way to high, it will put the spark out...
LS is in, I'm coming for you!
Sponsors:
Deeds Perfomance
QMP Racing Engines
Fab-Tech
Mickey Thompson
Mike's Transmissions
Precision Turbo
ARP
Ross Pistons
275 Trim 1.18 60ft - 4.62 @ 157 7.16 @ 196
8.5 Trim 1.22 60ft - 4.65 @ 161 on M/T's
First to the 4.7X's on a 26x8.5
First to the 4.6X's on a 26x8.5
NMCA West Street Outlaw Champion
No Mercy 4 Outlaw 8.5 Winner
NMCA West Outlaw 8.5 Champion
Throwdown at T-Town Unlimited 8.5 Winner
Toaster64 is offline   Reply With Quote
Old 04-03-2011, 10:26 PM   #3
CW25
Pre-Staged
CW25's Avatar
Us slower low boost guys run larger gaps. I run .032" no issues.
Curtis
1998 Dodge Dakota CC, installing 581 RWHP, 400BB, S475 remote mount, MSII and A/C blowing ice cold.
CW25 is offline   Reply With Quote
Old 04-03-2011, 10:29 PM   #4
stkjock
stkjock's Avatar
How much boost?
Small gap can cause the a/f mix to not burn well as I recall
Corn Powered Shelby GT500
L&M Built - 5.4L 4V - Lund Racing Tuned - 4.0L Whipple Charged
stkjock is offline   Reply With Quote
Old 04-04-2011, 12:11 PM   #5
Bellman
Bellman's Avatar
I set my gap at .018 with a Digital 7 with a 8261 HVC coil... With hot ignitions the gap will open up quicker than you think..
86 Mustang GT
383 ci SBF
Garrett GTX5518r turbo
TH400 Tranny
Bellman is offline   Reply With Quote
Old 04-04-2011, 01:11 PM   #6
boostedbowtie
boostedbowtie's Avatar
Quote:
Originally Posted by Bellman View Post
Digital 7 with a 8261 HVC coil... will open up quicker than you think..
Yes it will . Mine is street driven with the 8251 and they open up fast .
boostedbowtie is offline   Reply With Quote
Old 04-04-2011, 01:22 PM   #7
MEAN_SBC
TURBOBULLET.COM BITCHES!
MEAN_SBC's Avatar
X2.. This is what I run.
Brant Campbell
Worlds Fastest MPH Car on 275's
6.92@212.09
2011 PSCA XDR/TT5 Champion
2011 PSCA Sin City Shootout Champion
Thanks To The Following:
MEAN_SBC is offline   Reply With Quote
Old 04-04-2011, 02:29 PM   #8
NCR Motorsports
NCR Motorsports's Avatar
What we run on the T/S car also...
just another mustang.....
NCR Motorsports is offline   Reply With Quote
Old 04-04-2011, 05:40 PM   #9
BruceWilkie
Launchin
Quote:
Originally Posted by stkjock View Post
How much boost?
Small gap with spark is better than large gap with no spark! Type of ignition(capacitive or inductive) you run matters too!
BruceWilkie is offline   Reply With Quote
Old 04-04-2011, 05:54 PM   #10
stkjock
stkjock's Avatar
Quote:
agreed. however the OP question was what happens when it's too small.
Old 04-04-2011, 06:13 PM   #11
BruceWilkie
Launchin
Hope this answers the question
http://www.ngk.com/charglossary.asp?kw=Gap+Settings
Gap Settings
A spark plugs’ tip temperature and the voltage necessary to fire the plug are directly affected by the gap setting. NGK sets the gap from the factory for that plugs most popular application. Unfortunately, that plug may have hundreds of applications from automobiles to golf carts. Setting the gap for your particular engine is important as insufficient spark plug gap can cause pre-ignition, detonation and even engine damage. Whereas too much gap can result in a higher rate of misfires, loss of power, plug fouling and poor fuel economy. Even if the preset gap is supposed to match your motor, it is always best to physically check that the gap is adjusted properly for your motor prior to installation.
For modified motors, proper gapping is essential; gap settings are affected by increased compression, fuel type, turbos, nitrous and high output ignition system. Most experienced tuners know that opening the gap up to present a larger spark to the air/fuel mixture maximizes burn efficiency, however, after they have raised compression and installed a turbo, they have to lower the gap (to ensure ignitability in the denser air/fuel mixtures). It is for this reason that most racers add high power ignition systems. The added power allows them to reopen the gap without misfire.
You may also want to read through here. http://www.ngk.com/search_char.asp?s...nufacturerID=1
Old 04-04-2011, 06:45 PM   #12
promodefi
Member
Pullin gears
.018-.020 is the typical range for everything we run including a 44 mag. The smaller MSD's can definately use .018 with no problems. You can usually tell if you are too tight if the idle is eratic. But max power under hi boost is usually between .018 and .020.
I was tuning a bonneville car for a customer with a naturally aspirated mechanical injected alcohol engine with 20% nitro running a Don Zig massaged mallory mag and the customer was insistent on running .035 gap. The car would shoot ducks all the way down the course and you couldn't pull enough fuel away from it to get heat in the plug and smooth it out. I finally talked them into .025 we had to add fuel and finally set the record. Had the car in impound and they opened the plug gap back up to .030. Made the run the next morning and failed miserably. Again the car shot ducks all the way down the course. They finally called Don Zig and the word was if you run anything over .020 you are crazy......that wasn't the exact words he used they were a little more harsh.
You wouldn't think .005 would make a difference but it is huge from even .025 down to .020 and from .025 to .030 was a deal breaker......cost them the record!!!
If the car is a 12 second car you probably aren't going to notice a difference. If it is a 10 second car or faster with some substantial cyl. pressure you will probably pick up some numbers if you go down to .018-.020.
promodefi is offline   Reply With Quote
Old 04-04-2011, 06:54 PM   #13
Mark55
Member
Pullin gears
Mark55's Avatar
Any closing the plug gap down to get it to fire at high boost / high rpm is a band aid for a single coil system.
There's no escaping the physics of it. There is just not enough coil charge time to fire 4 cylnders per revolution at high rpm.
21' Eliminator Daytona V-Drive
540 Arias, BW 75mm turbo's,
FAST XFI/XIM, E85 Fuel, 1800 HP lake boat.
Mark55 is offline   Reply With Quote
Resources saved on this page: MySQL 2.17%
