06 F150 Tail light problem - Yellow Bullet Forums
Old 03-30-2011, 02:06 AM   #1
smlblk396
Member
Pullin gears
Default 06 F150 Tail light problem
I have a friend that has a F150 and the tail lights quit working. We have checked all of the bulbs and wiring. What are we over looking?
smlblk396 is offline   Reply With Quote
Old 03-30-2011, 02:14 AM   #2
jason306
Default Re: 06 F150 Tail light problem
brakelights work? running lights work? reverse lights work? need more info. have you checked all the fuses?
Monty Mikho is my dad!
jason306 is offline   Reply With Quote
Old 03-30-2011, 02:16 AM   #3
Colt
Ask me about my Weiner!..
Colt's Avatar
I dont have any experience with those trucks, but, did ya check the fuses under the hood?
The brake lights, unless it's changed ran through the blinker switch ( just on the rear circuit, not the front obviously since there are no brake lights )...
Other than that, I sure cant think of anything... I bet it's simple though..
Colt is offline   Reply With Quote
Old 03-30-2011, 02:19 AM   #4
smlblk396
Member
Pullin gears
Checked all of the fuses and they are good will check again. Just the brake lights are not working.
Old 03-30-2011, 02:30 AM   #5
jason306
either turn-signal switch or brakelight switch.
Old 03-30-2011, 02:36 AM   #6
Colt
Colt's Avatar
Hummm, the only thing I can suggest is get your hands on a schematic, and just start from the back, all the way up.. Since it has clearance lights, the ground is good, so it's just the power circuit somewhere...
Without looking at a schematic, I can only guess... But if you have access to any diagnostic equipment, so you can see if the ECM is recieving the signal from the brake switch.. That would help narrow it down, but not really worth tracking one down if you dont have access to it.. ( one other way to check it though, put it on cruise control, tap the brakes, if cruise shuts off, the ECM is getting a signal ).... There should be a plug somewhere under the bed, check that dude out and see if you get power on the drive side of the circuit ( closest to the front of the truck, load side would be to the back )..
Dont know what to tell ya other than that...
Old 03-30-2011, 02:40 AM   #7
smlblk396
Member
Pullin gears
Thanks for the help
Old 03-30-2011, 09:53 AM   #8
bsj
Member
Pullin gears
bsj's Avatar
had a similar problem with my nephews truck.taillight and brake lights worked but no turn sig in dash,on mirror,or on front, traced it to the multifunctio(turn signal)switch,wires are held into the plug with tiny plastic tabs that did not hold the wire properly,the wire moved down just enough that it would not make a connection.ended up putting a ziptie around the wire to hold it to the one next to it.works fine now but what a pain in the ass to fined. not saying thats youre problem but something to check.
BIG SHOT JOE
bsj is offline   Reply With Quote
Old 03-30-2011, 11:49 AM   #9
TH383
Member
Pullin gears
TH383's Avatar
Right below about where the drivers would sit there is large connector for the 2 harness under the truck. Pull them apart and look for the green death. Have seen quite a few get corroded.
TH383 is offline   Reply With Quote
Old 03-31-2011, 07:02 AM   #10
JoeP.
Launchin
JoeP.'s Avatar
Quote:
X2, pretty common to see the 2 large wiring connectors on the outside of the frame rail, just under the driver area corroded.
JoeP. is offline   Reply With Quote
Old 03-31-2011, 08:01 AM   #11
a493demon
i had a 06 monday that the left signal would not work when head lights were on. it was the factory flat 4 trailer light plug under the left side of the rear bumper.
a493demon is offline   Reply With Quote
Resources saved on this page: MySQL 2.17%
