power glide blowing fluild - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 03-20-2011, 09:39 AM   #1
Gold camaro
Pre-Staged
Gold camaro's Avatar
Question power glide blowing fluild
i have powerglide trans with 176 plan. everytime i make a pass at the track it leaks fluild bad. yesterday i got under the car to check it out. i notice fluid coming down from my cooler lines,so i made sure that they were tighten.i took brake cleaner and clean all the old oil off. i took my airline and blowed air threw my dip stick and oil started to leak out my vent tube and at the bottom of my t-brake solenoid. i have the 2 wire solenoid. i check my fluild level all the time, and it not over full, what can cause fliuld to blow out the vent tube.
Gold camaro is offline   Reply With Quote
Old 03-20-2011, 09:47 AM   #2
Theshotgun
Burnout box
Default Re: power glide blowing fluild
Stock case? I has one crack between the transbrake solenoid and the outside corner. Would only spew transmission fluid while trans-brake was on.
Theshotgun is offline   Reply With Quote
Old 03-20-2011, 09:51 AM   #3
Gold camaro
Pre-Staged
it a stock case . t-brake solenoid is leaking when it not running
Old 03-20-2011, 11:43 AM   #4
Hutch
Moderator
Hutch's Avatar
If its leaking out the front by the cooler lines , it sounds like the vent. If you pressurized the case and the solenoid leaked , that tells you the solenoid is bad also. Im suprized you could pressurize the case. Is the vent plugged?
Hutch
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
Old 03-20-2011, 12:54 PM   #5
Gold camaro
Pre-Staged
The vent plug has a relief valve ,I think that the name of it.when I put air to it the valve it would move out and then it will follow by fluild coming out the vent
Resources saved on this page: MySQL 2.38%
