are Cometic gaskets reusable? - Yellow Bullet Forums
Old 03-16-2011, 06:07 AM   #1
Camora
YB Word Crew
Camora's Avatar
Default are Cometic gaskets reusable?
Head gaskets, we took them off the BBC to do some work, they look fine, do they need to be replaced?
Camora is offline   Reply With Quote
Old 03-16-2011, 06:12 AM   #2
lktna
Launchin
lktna's Avatar
Default Re: are Cometic gaskets reusable?
Yes you can reuse them up to 4 times without a problem. I have had mine off and on 4 times now and not a problem one out of them. Anymore than that I would say replace them.
lktna is offline   Reply With Quote
Old 03-16-2011, 06:17 AM   #3
Honk if parts fall off
Drag Week Survivor
I've reused cometics and fel-pros on sbc and bbc's.
Honk if parts fall off is offline   Reply With Quote
Old 03-16-2011, 06:41 AM   #4
Scott @ Moroso
Pre-Staged
Scott @ Moroso's Avatar
I reused mine 9 or 10 times on my 632 engine.
Clean them good, including in between the layers. I used rubbing alcohol (cheap and it evaporates easy) and lots of compressed air.
Use carb & choke cleaner or such to get the oil off the outside.
Spray them with cooper gasket coat and your good to go!
When you torque them down, some oil will seap from the layers...no worries.
Scott Hall
scotth@moroso.com
Scott @ Moroso is offline   Reply With Quote
Old 03-16-2011, 06:42 AM   #5
slojoenova
Member
Pullin gears
slojoenova's Avatar
If i have time to order new one i do...... but on a quick fix of something i did reuse with no problems. My engine guy said just clean real well and spray with copper sealer.... worked no problem.
I'm just sayin .......
Mona vie &
RVL
Distributor
You want to lose weight and gain wealth?
Visit: www.Mousehouseracing.com
or email mousehouseracing1@gmail.com
slojoenova is offline   Reply With Quote
Old 03-16-2011, 07:01 AM   #6
fast406malibu
fast406malibu's Avatar
Scott Hall
scotth@moroso.com
I've been told this too!! I've reused my Felp-pro head gasket 4-5 times with Cooper Seal sprayed on there with no issue's.
APD carbs & race engines..
Fleenor Racing Powerglides
419-280-1406
BTE, Hughes & Trans Specialties Dealer.
http://www.youtube.com/watch?v=iW-5g...ature=youtu.be
http://www.youtube.com/watch?v=f0cho...ature=youtu.be
fast406malibu is offline   Reply With Quote
Old 03-16-2011, 07:25 AM   #7
71olds442
Burnout box
71olds442's Avatar
I reuse mine up to 5 times could go more i suppose no prob with copper coat!
1988 mustang gt 555 bbc
1971 olds 442 461 BBC
1999 Mustang gt 4.6 5speed
71olds442 is offline   Reply With Quote
Old 01-03-2013, 01:32 AM   #8
jon c anderson
SPEL CHECK
jon c anderson's Avatar
found this surfin da web good to know
jon c anderson is offline   Reply With Quote
Resources saved on this page: MySQL 1.11%
