Powerglide noise in neutral and park - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 03-13-2011, 03:42 AM   #1
doombrain
Pre-Staged
doombrain's Avatar
Default Powerglide noise in neutral and park
I have a stock cased JW Glide in my Camaro which has done around 100 passed without a problem or noise. I recently removed the trans while other work was done to the car and replaced it without touching it. I have however fitted a transmission shield and flex plate shield.
When I start the car I now have some noise in neutral and park, this noise goes away as the trans warms up.
Apart from the noise the trans works fine.
Do you think the new shields are amplifying noise that previously was not heard?
Simon.
doombrain is offline   Reply With Quote
Old 03-13-2011, 07:32 AM   #2
turbo chicken
Member
Pullin gears
turbo chicken's Avatar
Default Re: Powerglide noise in neutral and park
I have always had a whine from my powerglides in park and neutral.
turbo chicken is offline   Reply With Quote
Old 03-13-2011, 10:16 AM   #3
F. RIZZO
F. RIZZO's Avatar
Simon.
It is very possible that the shield has applified the noise as a PG has the planetary active in park & neutral. If the noise seems to get worse with time then I would say that the sun gear is starting to get some "spalling" on it which will make the gear set louder.
When was this trans checked out last ?
Dave
Dave Klaput (F. RIZZO) aka A.J.
Proformance Racing Transmissions
(630)365-9483
http://proformanceracingtransmissions.com/
http://fastesttransmissions.com/
http://www.facebook.com/pages/Profor...15573581840260
Leaf Spring Shootout T-Shirts for sale just call or PM !
F. RIZZO is offline   Reply With Quote
Old 03-13-2011, 11:01 AM   #4
stage20
more than likely you just hear the hum of the planetaries, but it should be there all the time, not just when it warms up.
get under the car and check your flywheel and starter. i have seen a starter bendix vibrate around on the flywheel and make a chirp sound that you will never find.
TJ
88 iroc-z/28 408 LSx
all the good stuff.
05 2500HD 6.0L
one hauls, one hauls @$$!
CHP May 2011 feature
http://www.chevyhiperformance.com/fe...aro/index.html
stage20 is offline   Reply With Quote
Old 03-13-2011, 11:52 AM   #5
doombrain
Pre-Staged
doombrain's Avatar
Thanks guys, the trans was new last year, it has covered about 100 runs, we run a 550hp smallblock engine with a 100 shot of gas, as yet we haven`t touched it, it creeps forward a little in neutral, worse when cold, which I understand is OK, other than this noise when cold I am very happy with it. We run very consistant 10.60s and the car is great fun.
Old 03-13-2011, 01:08 PM   #6
Hutch
Moderator
Hutch's Avatar
Glides do make some noise but if you didn't hear it before I would not expect you to hear it now. Is it possible that the trans shield or flexplate shield is touching the floor somewhere?
Hutch
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
Old 03-13-2011, 01:15 PM   #7
doombrain
Pre-Staged
doombrain's Avatar
Pretty sure the shield is clear of the floor, the shifter cable is a little close here and there now, maybe we will have to watch the oil and keep going till it shows up.
Old 03-14-2011, 06:01 AM   #8
psimatt
Launchin
psimatt's Avatar
mine did it one day out of the blu..was told its normal and just the gears, i did try a different fluid at the same time so i assumed that was it
www.psimotorsportsinc.com
www.mrenforcer.com.au
6.37@226mph
psimatt is offline   Reply With Quote
Old 03-14-2011, 04:37 PM   #9
doombrain
Pre-Staged
doombrain's Avatar
Thanks, did it stay together ?
Old 09-19-2013, 10:54 PM   #10
bdg
bdg's Avatar
I just fired up a new build. , PTC converter, 180 straight cuts, pro brake etc. All new, it has a pretty noticeable whine noise. Was louder the first time I ran it. Still makes the noise, just not as loud. How loud of a noise should a glide make? It gets faster and a little louder when revved. Had a diff glide built the same in another car, and didn't hear this noise, but that car had 4" bullets and was loud and this one is quite. Nothing to worry about?
bdg is offline   Reply With Quote
Old 09-22-2013, 12:24 PM   #11
doombrain
Pre-Staged
doombrain's Avatar
Brett, I wouldn`t worry if I were you, since I noticed the noise in my glide the car has don 200+ passes and lots more other noises and issues have kept me awake instead.
Old 09-23-2013, 06:52 AM   #12
Manford
Launchin
Manford's Avatar
All of my old stock cars with powerglides made noise
10.31 at 130
Manford is offline   Reply With Quote
Old 09-23-2013, 08:34 PM   #13
bdg
bdg's Avatar
Thanks for the update. I guess I never knew they sounded like that until I built this car. Pretty quit exhaust. Talked to tranny guy and he said the same. So time to thrash on it.
Resources saved on this page: MySQL 2.04%
