Mustang lower instant center brackets??? - Page 11 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 02-06-2012, 01:02 AM   #151
Bad351
Default Re: Mustang lower instant center brackets???
Who else sells weld in upper control arm mounts? im looking for a some for my moser fabricated 9 inch.? does anyone have any pictures of these installed and where did you get them?
Bad351 is offline   Reply With Quote
Old 02-07-2012, 01:29 PM   #152
Bad351
Any takers out there?
Old 02-07-2012, 01:39 PM   #153
9secondlx
9secondlx's Avatar
Quote:
Originally Posted by Team Z View Post
That's a pretty good Idea for a JIG Dominic, we just made one that picks up several of the rear cover bolts, But I like your idea simple and clean!
Thanks, coming form the innovator that means alot!!
It made it so simple, I can have the rear in the jig and be welding any brackets on with in minutes..
9secondlx is offline   Reply With Quote
Old 02-08-2012, 02:23 PM   #154
EHA Racing
EHA Racing's Avatar
Just got my relocated uppers and D/A lowers from Team Z. Should match the adjustable lower brackets nicely.
Doug Vanstrom / P4046
SBF 114mm Turbo
4.67 @ 162.8 on 275's
7.51 @ 186 1/4 on 29's
www.vanstromperformance.com
www.eha.us.com
www.ultimateconverters.com
www.penngrade1.com
Quote:
Originally Posted by morris View Post
You want to go Bruder fast, Jackson fast it is from the flywheel back.
EHA Racing is offline   Reply With Quote
Old 02-14-2012, 10:13 PM   #155
woodhauler
Spooled up
woodhauler's Avatar
So you want to leave uca in the stock location and move the lca to adjust IC? What will happen if my lca is 8.75 rear and 11.0 front from the floor ? These numbers give me an A/S of 101% Is angle too steep?
woodhauler is offline   Reply With Quote
Old 02-14-2012, 11:13 PM   #156
580stang
580stang's Avatar
that car setting that high?
580stang is offline   Reply With Quote
Old 02-14-2012, 11:23 PM   #157
woodhauler
Spooled up
woodhauler's Avatar
The measurements to the stock mounting points is 10.5 rear and 11 is that too high? If I lower the car that will put my lca at a downhill angle which I dont want. What is a good height for the front mounting point? Should I lower the car? And add lower instant center brackets? Its has coil overs so lowering is easily done
Old 02-14-2012, 11:32 PM   #158
woodhauler
Spooled up
woodhauler's Avatar
All Team Z suspension with a 29 x10
Old 02-15-2012, 10:04 AM   #159
old man joe
Spooled up
old man joe's Avatar
I would put instant center brackets on and use the coil over to adjust in a heart beat.
Don`t fuck with old people, We`ll just shoot ya.
old man joe is offline   Reply With Quote
Resources saved on this page: MySQL 2.27%
