Mustang lower instant center brackets??? - Page 10 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 01-22-2012, 08:14 PM   #136
EHA Racing
EHA Racing's Avatar
Default Re: Mustang lower instant center brackets???
These are the Team Z pieces installed.
Doug Vanstrom / P4046
SBF 114mm Turbo
4.67 @ 162.8 on 275's
7.51 @ 186 1/4 on 29's
www.vanstromperformance.com
www.eha.us.com
www.ultimateconverters.com
www.penngrade1.com
Quote:
Originally Posted by morris View Post
You want to go Bruder fast, Jackson fast it is from the flywheel back.
EHA Racing is offline   Reply With Quote
Old 01-22-2012, 08:28 PM   #137
Max rider
Max rider's Avatar
Did you put it in a jig to weld them on? If not how did you get them on there?
4.75 @ 151.7 ON JACKSTANDS!!
Thanks to
SPEED365
SIEDLE MOTORSPORTS
INDUCTION SOLUTIONS
Max rider is offline   Reply With Quote
Old 01-22-2012, 09:30 PM   #138
EHA Racing
EHA Racing's Avatar
They were tig welded on by my chassis builder. Not sure of the method he used to locate them as I was not there. He's one of the best chassis guys I have met. Randy Jewell at RJ ProFab in Holley, NY.
SBF 114mm Turbo
www.eha.us.com
www.penngrade1.com
Old 01-22-2012, 09:47 PM   #139
Max rider
Max rider's Avatar
Yea they are nice i was looking at these to but was told they had to be welded on with a jig. Maybe Dave will chime in.
Thanks to
SPEED365
SIEDLE MOTORSPORTS
INDUCTION SOLUTIONS
Old 01-23-2012, 10:13 AM   #140
Team Z
We use a JIG but it's not needed, we have one and it speeds the process up, but if you have the housing out and on a bench it takes about 4 hours to measure cut the old brackets off and weld the new ones on. it's fairly simple the hardest part is cutting the old brackets off!
Team Z is offline   Reply With Quote
Old 01-23-2012, 10:32 AM   #141
image4you2see
image4you2see's Avatar
Quote:
Originally Posted by fast67rs View Post
Thanks, I'm really happy with how it turned out. It should definitely handle whatever I can throw at it.
Are the LCA brackets welded on plus bolted?
image4you2see is offline   Reply With Quote
Old 01-23-2012, 08:30 PM   #142
Proshot
Spooled up
Proshot's Avatar
Quote:
Originally Posted by turbo vert View Post
WOW , THAT LOOKS GREAT.
X2 very nice!
Proshot is offline   Reply With Quote
Old 01-23-2012, 09:16 PM   #143
fast67rs
Spooled up
Quote:
I didn't weld them. I considered it and it couldn't be any easier to do since they sit in there perfectly, if somebody wanted to weld them. But with the way they are designed, it isn't necessary to weld them. They contour up and around the axle tube and fit very nicely, so there is no way they are coming off without ripping the factory control arm mount off with it and even then, that is welded in with the brace. So I decided to keep the option of putting a standard control arm back in there if there was ever a need to do so and just bolted them in.
fast67rs is offline   Reply With Quote
Old 01-23-2012, 10:37 PM   #144
Mean Green
Mean Green's Avatar
Thanks for the pics Doug, the new Team Z mounts look good.
Thanks to Dave for chiming in regarding getting these installed / fabbed on a nice 8.8.
Look out Ultra...Here I come.
Mean Green is offline   Reply With Quote
Old 02-01-2012, 01:33 AM   #145
9secondlx
9secondlx's Avatar
Here's a set we are currently installing. Very nice peices.Highly recommend them.
9secondlx is offline   Reply With Quote
Old 02-01-2012, 08:09 AM   #146
EHA Racing
EHA Racing's Avatar
^^^^^ Looks great!!
SBF 114mm Turbo
www.eha.us.com
www.penngrade1.com
Old 02-02-2012, 03:22 PM   #147
86cutlass350
Spooled up
is there anyone u guys could sugest to cut my old brackets off and put new ones on in the chicagoland area
86cutlass350 is offline   Reply With Quote
Old 02-03-2012, 01:14 AM   #148
plmberkevin
Member
Pullin gears
plmberkevin's Avatar
neal becker hes in lombard 847 613 8621 great prices tell him i gave u his number.
Quote:
Fastest all motor mustang in chitown
plumber out of chicago
plmberkevin is offline   Reply With Quote
Old 02-03-2012, 10:37 AM   #149
Steedafied
Member
Pullin gears
Steedafied's Avatar
Chris at BehindBarsRaceCars
(phone) 1-815-788-1697 (Email) BEHINDBARSRACECARS@SBCGLOBAL.NET
He does excellent work, he narrowed my rear axle for me, braced it and welded on all my brackets.
Steedafied is offline   Reply With Quote
Old 02-03-2012, 01:47 PM   #150
Team Z
Quote:
That's a pretty good Idea for a JIG Dominic, we just made one that picks up several of the rear cover bolts, But I like your idea simple and clean!
