Powerglide question - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 02-14-2011, 12:31 AM   #1
"Stroker Ace"
Pre-Staged
"Stroker Ace"'s Avatar
Default Powerglide question
I have a Deadenbear case and I will no longer be using an Trans cooler . My question is , what are you guys doing with the Fluid out and return ?
I thought the two would have to be looped together but , with what?
Or just cap them off . I dont think it has an internal bypass..
"Stroker Ace"
"FASTEST CHICKEN IN THE SOUTH"
"Stroker Ace" is offline   Reply With Quote
Old 02-14-2011, 05:06 AM   #2
Blu Thunder
Spooled up
Blu Thunder's Avatar
Default Re: Powerglide question
"Stroker Ace"
never seen them capped off but just looped with a stort piece 6an bradied line with crimped, not screwed on ends.
Success isn't permanent and failure isn't fatal.
Blu Thunder is offline   Reply With Quote
Old 02-14-2011, 10:27 AM   #3
Hutch
Moderator
Hutch's Avatar
If you are not certain about the internals of the trans , make a loop line but NEVER plug off the cooler lines.
Hutch
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
Resources saved on this page: MySQL 1.15%
