Input shaft seals - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 02-02-2011, 11:49 AM   #1
00 DEAD ON
Spooled up
Default Input shaft seals
Is there a easy way to install the teflon seals on a input shaft? PG trans, turbo spline
Thanks in Advance
2009 Sumerduck Dragway Top ET Track Champion
2009 Sumerduck Dragway IHRA SSS Champion
2008 IHRA Division 1 Top ET Bracket Final
Runner-up
2007 Colonial Beach Dragway Top ET Track Champion
00 DEAD ON is offline   Reply With Quote
Old 02-02-2011, 12:26 PM   #2
00 DEAD ON
Spooled up
Default Re: Input shaft seals
They are one piece seals
Runner-up
Old 02-02-2011, 12:53 PM   #3
Hutch
Moderator
Hutch's Avatar
Stretch them around the shaft then size them with a tool that is made to the bore of the pump stator tube.
Hutch
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
Old 02-02-2011, 02:18 PM   #4
00 DEAD ON
Spooled up
How do you mean size them? If I put the shaft in the freezer and warm up the seals, then install the seals will they conform to the size of the input shaft?
Runner-up
Old 02-02-2011, 02:34 PM   #5
JShelton
why not run a scarf cut teflon seal?
JShelton is offline   Reply With Quote
Old 02-02-2011, 03:34 PM   #6
00 DEAD ON
Spooled up
I would but this is what I have at this time
Runner-up
Old 02-02-2011, 08:11 PM   #7
Hutch
Moderator
Hutch's Avatar
What shaft is it that you need to install one piece rings? If its conventional just get a different set of rings or cut yours. When I say "size" , I mean shrink them back down to the bore size. Teflon is stupid and has NO memory so if its stretched it just stays that way.
Hutch
www.hutchtrans.com
519-453-4318
Old 02-02-2011, 11:18 PM   #8
JShelton
Quote:
lot less hasle to get some scarf cut type.
Old 02-03-2011, 07:58 AM   #9
00 DEAD ON
Spooled up
Thanks, I took your advice and got another set of seal rings that were cut.
Runner-up
Old 02-03-2011, 08:40 AM   #10
Crosley
Member
Pullin gears
use a long socket to hold the teflon ring on... then with a sharp x-zacko knife, cut the ring at angle to scarf cut them. Longer scarf cut the better. Check for fitment and you may need to size them as with 1 piece use
If you find yourself in a ditch... let up on the throttle and down shift
Crosley is offline   Reply With Quote
Resources saved on this page: MySQL 2.20%
