high compression & high boost - Yellow Bullet Forums
Old 01-29-2011, 07:43 PM   #1
bluebottle
Pre-Staged
Default high compression & high boost
high compression such as 12-13:1 and high boost 30 psi.
do we see this combination?
will high compression and high boost make more power?
bluebottle is offline   Reply With Quote
Old 01-29-2011, 07:52 PM   #2
stroked93cobra
Pre-Staged
stroked93cobra's Avatar
Default Re: high compression & high boost
x2
stroked93cobra is offline   Reply With Quote
Old 01-29-2011, 07:54 PM   #3
91silverfox
Member
Pullin gears
91silverfox's Avatar
yes will make more power if you keep from detonating it apart
91silverfox is offline   Reply With Quote
Old 01-29-2011, 09:28 PM   #4
ZERO260IN1
TTBBF
ZERO260IN1's Avatar
Methonal yes.
ZERO260IN1 is offline   Reply With Quote
Old 01-29-2011, 11:36 PM   #5
thebull
thebull's Avatar
The tuning window will be VERY NARROW! Don't slip up
thebull is offline   Reply With Quote
Old 01-29-2011, 11:39 PM   #6
thebull
thebull's Avatar
You would also need a very large turbo to run 30lbs at 12.5 to1 comp.
I have a GT500 with compound boost(stock blower and twin billet 64's) and run 8.5 to1 and 40lbs and am building a new motor with 9.5 to 1 and hope to pick 100-150rwhp at the same boost level.
Old 01-30-2011, 12:37 AM   #7
95mmRenegade
VP Import
95mmRenegade is offline   Reply With Quote
Old 01-30-2011, 12:43 AM   #8
us7race
us7race's Avatar
My friends old Big Cheif 540 had 11-1 with up to 43psi of boost on Alcohol..But is had a 14-71 kobelco on it..
us7race is offline   Reply With Quote
Old 01-30-2011, 07:50 AM   #9
thebull
thebull's Avatar
[QUOTE=thebull;5560527]You would also need a very large turbo to run 30lbs at 12.5 to1 comp.
I have a GT500 with compound boost(stock blower and twin billet 64's) and run 8.5 to1 and 40lbs and am building a new motor with 9.5 to 1 and hope to pick 100-150rwhp at the same boost level. It's on E85.....The fuel is incredible....I don't know why they won't allow it in X275????? Cheaper for the racer and a lot less breakage!!!
Old 01-30-2011, 08:00 AM   #10
koolrayz
Moderator
koolrayz's Avatar
[QUOTE=thebull;5561467]
Quote:
It really pisses me off that I will have to switch back to gas this year to run X275. I will miss my cheap racing fuel.
X275 ERL motor, Midwest Chassis Suspension, Garrett 88mm turbo, AEICNC, Shearer fabrications, Driveshaft shop, All Pro heads, RPM transmission, PTP performance, Big Stuff 3
Like WWW.facebook.com/koolrayzracing
koolrayz is offline   Reply With Quote
Old 01-30-2011, 08:03 AM   #11
bluebottle
Pre-Staged
I wish there was some solid data such as:
- dyno graps with low compression vs high compression
- drag race results low vs high comp engine
When the compression is raised, the piston turns the cranshaft faster.
There "is" or "should be" a point where more compression will trigger detonation whichever fuel we run.
It is hard to find that sweat spot.
Old 01-30-2011, 09:22 AM   #12
95mmRenegade
If you search on google, there are some back to back tests that were done with dyno sheets.
Phil - ProStreet Motorsports
"The Renegade" - Best 1/8 4.62 @ 153 -
2000 Mustang #227N
Virginia Speed 450" LSx
John Marcella Sheetmetal Intake
NLR AMS-1000 Power Management
Old 01-30-2011, 06:52 PM   #13
bamared
Spooled up
bamared's Avatar
check out the diesel engines. HIGH compression and TONS of boost. its all in the fuel and tune for gas. also, without a long drawn out post, " just an example" if you were to run 8.5:1 engine with say.... 12lbs of boost and make 400rwhp. now, if you were to run a 10.0:1:1 engine and want to make the same rwhp you would be able to run less boost to get the same result. but you need to be more carful with the tune. like they say, the window for tuning is shorter. The 8.5:1 engine might be able to run on 89octane fuel, but the 10.0:1 would need to be on 93 octane.
bamared is offline   Reply With Quote
Old 01-31-2011, 01:58 AM   #14
Bear77
Burnout box
Bear77's Avatar
Quote:
The only tests I have ever seen are low compression ratio vs high compression ratio with constant boost. Surprise surprise the high compression engine makes more power....
The back to back tests with dyno sheets I would like to see are low compression ratio vs high compression ratio while maintaining the same BMEP, i.e. increase boost pressure with lower compression to create the same BMEP as the high compression engine.
If you search on google you will also find some interesting information on the benefits of low compression/high boost:
http://www.modularfords.com/forums/s...boost-pressure
http://forum.e46fanatics.com/showthread.php?t=726637
Cheers,
Glen
Bear77 is offline   Reply With Quote
Old 01-31-2011, 11:14 AM   #15
Slugg0
Spooled up
Slugg0's Avatar
Quote:
Well said. That's what it's all about. We just need to find some one with the coin$ to afford us this information. One method could require less octane or greater efficiency at the same BMEP.
There are also a lot of factors to consider with each cylinder head design and such.
Slugg0 is offline   Reply With Quote
