2nd Gen Camaro brake conversion??? - Yellow Bullet Forums
Old 01-29-2011, 04:38 PM   #1
moosedk
Member
Pullin gears
moosedk's Avatar
Default 2nd Gen Camaro brake conversion???
I have a '73 that had power brakes and now has manual. Brakes are a little iffy, doesn't stop as good as it should. I know some cars take a differant length rod between pedal and master cyl.(power vs. manual) and in some cases have to change pedal assy. Anyone know for sure if this is the case here?? It has new master cyl., rear wheel cyl's, prop. valve, etc. It should stop better than it does!! Any input is greatly appreciated. Thanks....Moose.
'73 z/28. 540" Shafiroff pump gas bbc, th400, 4.10. 315 M/T Radials.
UPDATE..11/14/10..1.35 60'-6.281 @ 107=1/8-
9.952 @ 132=1/4-race gas, with full exhaust, DOT's and footbrake @ 3565#
"Not Trying To Go Faster Than You've Been, Just Faster Than I've Been".
moosedk is offline   Reply With Quote
Old 01-29-2011, 04:48 PM   #2
hrracecar
Member
Pullin gears
hrracecar's Avatar
Default Re: 2nd Gen Camaro brake conversion???
Did you move your pedal linkage rod to the upper hole in the pedal assembly for more leverage when you changed to manual? If not, this will help greatly..........Toni
Go ahead and let me do it right the first time, I don't have time to redo it later.
Roll Cages/Back halfs/Mini Tubs/Frame Connectors/Narrowed Housings/Rear set up and parts/Tube Chassis
www.hrracecar.com
toni@hrracecar.com
www.OSORRACING.COM
Dealers for:
Moser Eng./Motive Gear/Holeshot Race Wheels/Bogart Race Wheels/QA1/Glasstek Fiberglass/R1C Powdercoating/TCI Transmission
hrracecar is offline   Reply With Quote
Old 01-29-2011, 05:05 PM   #3
moosedk
Member
Pullin gears
moosedk's Avatar
Quote:
I didn't (it was actually converted when I got it). There is a bolt thru that hole with a metal contact tab for the brake light switch. I will try that and hope like hell it is that easy to improve on it!!
....Moose.
Old 01-29-2011, 06:56 PM   #4
moosedk
Member
Pullin gears
moosedk's Avatar
Hey Toni, have you done this before? The reason I ask is where the rod is attached to is a pressed in stud on the pedal arm. The upper hole is a bolt thru with a nut and I was wondering if I "bolt" it to the arm, will it still pivot freely enough? Hate to sound stupid, but I've not tried this before. Thanks for your help....Moose.
Old 01-29-2011, 07:47 PM   #5
racurass
racurass's Avatar
use a bolt and double nut it. i ran mine like that for a long time until i bought a new mc/ pushrod that had a rod end on it. good luck.
racurass is offline   Reply With Quote
Old 01-29-2011, 10:27 PM   #6
moosedk
Member
Pullin gears
moosedk's Avatar
Quote:
Thanks alot....Moose.
Old 01-29-2011, 11:18 PM   #7
72RS/SS
Member
Pullin gears
72RS/SS's Avatar
My car did not have the two holes on the pedal when I did the change. I'm not real impressed with my stopping power either on the conversion but I have been told, but not confirmed, that the mid 90's impalas have larger amount of brake surface on pads that fit on our 2nd gens.
72RS/SS is offline   Reply With Quote
Old 01-29-2011, 11:39 PM   #8
racurass
racurass's Avatar
Quote:
the hole that the little tab is bolted on that goes to the stoplight switch is the one i used.
Old 01-30-2011, 02:34 AM   #9
paul c
paul c's Avatar
i got the set up off of ebay for a stock manual set up. the hole was higher for the manual set up which changes the fulcrum for more leverage. also the power booster is at an angle so it lines up with the lower hole, the manual bolts directly to the firewall and comes in straight and ends up higher up on the pedal. i used a 72 vette master and my brakes feel really nice.
paul c is offline   Reply With Quote
Old 01-30-2011, 07:40 PM   #10
moosedk
Member
Pullin gears
moosedk's Avatar
Thanks for the input guys!!! Got it done..was a breeze, haven't driven it yet 'cause the roads around here are still nasty. Thanks again....Moose.
Old 01-30-2011, 08:39 PM   #11
KylePBZ
KylePBZ's Avatar
I was going to say, that stud is just pressed in and you can pop it out and put it in the top hole. How I did mine, if I remember correctly. Mine was originally a manual brake car but it was a 3-speed and I put a automatic brake pedal in it and had to switch the stud around.
KylePBZ is offline   Reply With Quote
