Looking for the best way to keep the car off the bumper - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Nitrous - Induction Solutions
Old 01-24-2011, 02:52 PM   #1
bykr
bykr's Avatar
Default Looking for the best way to keep the car off the bumper
The car currently has 10.5w M/T's and wheelie bars.300 shot off the transbrake.I'm thinking on trying a couple of different tire classes this year(275 and E/T Street) that don't allow bars.So is it better to delay the nitrous hit (like a digiset) or to pull timing to prevent big wheelstands?One of the classes doesn't allow traction control so I guess a 7531 is out.Car currently has a MSD digital 6 in it.
91 Mustang LX sbf,nitrous,glide
NMCA West Outlaw 8.5
bykr is offline   Reply With Quote
Old 01-24-2011, 03:14 PM   #2
425ci
Default Re: Looking for the best way to keep the car off the bumper
Put more power to it.Slip the tires just a little.Limit frontend travel.
425ci is offline   Reply With Quote
Old 01-24-2011, 03:18 PM   #3
Monte Smith
The nitrous guy
LACK of power, is what causes big wheelstands. You dead stick the tire and the pinion climbs the ring gear, is what pushes the front end up. On bias tires, like slicks or ET Streets, you need to get after it hard enough to snap the car up on the tire and make wheelspeed.......this keeps the front down. Radials are a little diff, because you can't slip them and you can't hammer it like a bias tire. Chassis setup is more important than anything with a radial. Plant the tire, but control the front end rise with suspension and weight percentage.
Monte
Monte Smith
Motorsports Technical Representative
Nitrous Oxide Systems
www.montesmithperformance.com
gtxmonte@msn.com
ph. 256-783-3418
Monte Smith is offline   Reply With Quote
Old 01-24-2011, 03:19 PM   #4
b00sted
b00sted's Avatar
Is a progressive considered traction control? Either that or break it up into multiple stages if they allow it.
No traction control doesn't necessarily mean a 7531 is out. Ask and find out.
b00sted is offline   Reply With Quote
Old 01-24-2011, 05:51 PM   #5
z289sec
z289sec's Avatar
More power earlier, and keep tightening the front shocks.
RTCTTFMF!!!!
Stock suspension 67 Camaro
565 Conventional head BBC with fogger and a plate on 275's
Just about done
Thanks to:
Texas Racewerks, Sanger, Texas
Nyes Automotive Racing Engines, Muncie, Indiana
FTI Converters and Transmissions, Deland, Florida
ACE Racing Transmissions, Garland ,Texas
z289sec is offline   Reply With Quote
Old 01-25-2011, 12:04 AM   #6
bykr
bykr's Avatar
Thanks,good info guys.Not sure if PSCA considers a 7531 traction control or not-I'll check.
Old 01-25-2011, 12:23 AM   #7
1QuickBird
1QuickBird's Avatar
Mo Powa!
WWW.LEGENDRACINGENT.COM
https://www.facebook.com/LREhorsepower
Midwest Muscle Car Specialists
High Performance engine builders
Induction Solutions Midwest dealer
1QuickBird is offline   Reply With Quote
Old 01-25-2011, 07:42 AM   #8
fast 351
Member
Pullin gears
fast 351's Avatar
x2 On the progressive (edlebrock of course)... It does wonders at calming the car..
I had the same problem kept extending the build time from
(all in @) .800 to 1.200 worked like a champ and pick up on et & mph..
4/5/92 - 8/21/07
RIP TONY JR...MISS U MUCH!!!! DAD
BEST TO DATE:6.72@102 motor
395W otb Vic Jr heads ]5.91 @115 mph 1/8 mile w/ 250 shot.
[URL]http://www.youtube.com/watch?v=39Ca_y9dy-8
best to date: 5.76 @121 w/200
Thanks to: ALL YB MEMBERS.
fast 351 is offline   Reply With Quote
Old 01-25-2011, 11:47 AM   #9
White90GT
I'm about half a second off your time, but when my car stood up, I put weight in the back seat, moved the nitrous bottle (15 lb bottle) to the passenger seat, and tightened up the front struts to 7. This resulted in a clean straight launch that just carried the wheels less than a foot off the ground. But again, it was only a 1.34 sixty and a 5.90@117. I'm going 1.38 sixty on motor now with the front struts on 2, no weight in car, carrying front wheels 30 feet or so a foot or a little more off the ground. I'm going to be hitting it with 300 this year and have borrowed an NOS controller from a buddy who's getting away from nitrous. We'll see how it works. I plan to start it at 50% off the line and bring it in over 2 seconds to start.
Oh yeah, thats on 28x10.5S tires.
Carl Smith: 2014 Mustang GT Premium Ruby Red Daily Driver
80 Coupe with a few goodies...
White90GT is offline   Reply With Quote
Old 01-25-2011, 09:18 PM   #10
fast 351
Member
Pullin gears
fast 351's Avatar
She's gonna stand way up hittng it with 50% off the line. I had to come down to 20% to get the front calm down. At 35% it was doing this..
http://www.youtube.com/watch?v=9acsA8Ekab4
4/5/92 - 8/21/07
Old 01-25-2011, 10:02 PM   #11
1QuickBird
1QuickBird's Avatar
Have you ever tried hitting it harder than that?
Old 01-25-2011, 10:12 PM   #12
team hyperactive ez555
front end is pretty loose in that vid.. limit front travel down to 1/2 to 1 1/2 inch. put the screws to her..
team hyperactive ez555 is offline   Reply With Quote
Old 01-25-2011, 11:44 PM   #13
z289sec
z289sec's Avatar
Yes, if you throw more power at it, you also have to compensate with tightening the front shocks, or you can limit travel also. Personally I have better luck with all the travel in it and a front end that's tighter than a lowrider with the hydraulics extended.
RTCTTFMF!!!!
Just about done
Thanks to:
Old 01-26-2011, 02:14 AM   #14
TobyG
I have made a 'Wheelie-Control' box for eight years. I didn't make it as a performance enhancing product and for liability sake never advertised as a safety device. I just make something to help guys from tearing up parts. Unfortunately many times I get a call monday morning from a racer telling me they wished they had my box yesterday and they wouldn't be replacing front end parts.
I will say over the time talking to guys, like mentioned many times earlier, the wheelstand condition occurs when the tire is not hit hard enough, weight transfers to the rear end, tire hooks and the car climbs the ring gear.
I don't have much experience with smaller tires compared to working with Pro Stock cars, but it seems like the same scenario. When you dead hook a PS car, the driver might as well kick the clutch in. Some times when we watch the tires damn near go up in smoke, walk back to the pits thinking the time slip for the short times will suck, they are bad ass. Again, not much experience with the smaller tire deal, there is alot of be said with higher rather than lower tire speed. I know higher tire speed as it might be hard to imagine is easier to control. Mainly because tire shake is out of the equation. Tire shake I guess isn't a problem with your tire yet an example.
Just get after the tire, put a set up in that thing where you will think you are way over center and work from there. If I were you, I would rather go up to the line worrying about blowing the tires off than sticking it on the ass end again.
For those guys on this thread replying that have a progressive, do you find a point of being 'too aggressive' and have the same wheel stand as not being aggressive enough?
TobyG is offline   Reply With Quote
Old 01-26-2011, 08:15 AM   #15
fast 351
Member
Pullin gears
fast 351's Avatar
Quote:
OK I'll give that a try. Never knew limiting the front end travel would help. Learned something today. Thanks
4/5/92 - 8/21/07
