Your thoughts on BBC/Procharger CID - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Supercharged - All Out Automotive
Old 01-16-2011, 06:36 PM   #1
bighead
Pre-Staged
Default Your thoughts on BBC/Procharger CID
I'd like to start laying the ground work for a new procharger motor and hope to increase my knowledge on this subject. My chassis is a moly dbl frame rail door car, 33x17 tires, weight with driver under 2500lbs. I'd like to run some local quick 8 deals that would require 4.60-4.80 et's. What's your thoughts on displacement considering the cost of an aftermarket shortblock is about the same over a couple hundred cid range? Thanks for your feed back, bert
bighead is offline   Reply With Quote
Old 01-16-2011, 07:21 PM   #2
wicked nova
Launchin
wicked nova's Avatar
Default Re: Your thoughts on BBC/Procharger CID
f-3 front mount , a/w intercooled or methenol , 502ci billet crank and rods standard heads at 2500lbs this goal is easy
wicked nova is offline   Reply With Quote
Old 01-16-2011, 07:36 PM   #3
1QuickBird
1QuickBird's Avatar
4.125 stroke and 4.500 bore. With a CN block, or a KB 600. Conventional heads or big chief, will make all sorts of power.
WWW.LEGENDRACINGENT.COM
https://www.facebook.com/LREhorsepower
Midwest Muscle Car Specialists
High Performance engine builders
Induction Solutions Midwest dealer
1QuickBird is offline   Reply With Quote
Old 01-16-2011, 10:45 PM   #4
bighead
Pre-Staged
Thanks for the reply! So a smaller inch engine is the ticket? What kind of rpm would you spin one up to? Aluminum rod motor or billit steel? Thanks again!
Old 01-16-2011, 10:52 PM   #5
NOS-Nelson
Procharger Power
NOS-Nelson's Avatar
Never build a max cubic inch power adder engine.
NOS-Nelson is offline   Reply With Quote
Old 01-16-2011, 10:53 PM   #6
Greg Kelley
I have gone 4.20 @ 169mph weighing 2000 lbs with a 540, F2, 22lbs, alky, 7600 in the traps. The 4" stroke guys are recommending does sound good. Your goal sounds very reasonable.
GK - 609-265-2110 -- http://www.motorsportsinnovations.com/
Data Logging - Racepak - Edelbrock
Wide Band O2 - Innovate -
Good Old EGT kits too!
Greg Kelley is offline   Reply With Quote
Old 01-16-2011, 11:15 PM   #7
1QuickBird
1QuickBird's Avatar
Quote:
It's a solid combo, especially with a blower you don't need a bunch of stroke because you don't want that big arm swinging around.
We like to run 4"-4.250" max on a blower motor. And with a 4.500 bore you get a nice size bore to let the heads breathe.
We are in the process of building a 4.600 bore motor now with a 4" arm to kind of test a theory.
But we have made about 2500hp in our '57 Chevy with a 525.
I would run a billet rod, with a good Diamond piston with thick skirts.
If you are interested shoot me a PM and we can get you a quote on some stuff.
Old 01-17-2011, 04:50 AM   #8
55chev
55chev's Avatar
4.250 stroke 4500-4600 bore oringed receiver grooved 6 stud chevy .
The only true wisdom is in knowing you know nothing.
https://www.facebook.com/lamuderacingengines?fref=ts
https://www.youtube.com/watch?v=Q1hJQEkr7RM
55chev is offline   Reply With Quote
Old 01-17-2011, 08:17 PM   #9
bighead
Pre-Staged
Guys, thanks again for sharing your knowledge.
I look forward to getting started on this build!
Old 01-18-2011, 04:32 PM   #10
Outlaw Bill
Outlaw Bill's Avatar
4.00 stroke is about perfect for a 9.800 deck BBC power adder.
TeamZmotorsports Stock Suspension 25.3 Outlaw Drag Radial 1991 Mustang
http://www.teamzmotorsports.net/category_s/166.htm
Thank you to the following-
TeamZmotorsports
Marcella Manifolds
Schoneck Composites
Ultimate Converter Concepts
http://www.hardcore50racing.com/vbulletin/index.php
Outlaw Bill is offline   Reply With Quote
Old 01-18-2011, 05:15 PM   #11
Flex
Member
Pullin gears
Flex's Avatar
call Pro-line ask for Eric
'41 Willys
Under Pressure Performance BAE Hemi
Flex is offline   Reply With Quote
Old 01-18-2011, 05:57 PM   #12
tomato
what is the best stroke for a small block?
tomato is offline   Reply With Quote
Old 01-19-2011, 02:39 PM   #13
Outlaw Bill
Quote:
Depends on deck height.
TeamZmotorsports
Marcella Manifolds
Schoneck Composites
Old 01-19-2011, 05:31 PM   #14
morris
morris's Avatar
I am also a big fan of the 4 inch stroke even though most of what I build is 4.25 540 is just a great combo for boost.
the kind of power you want to make is a easy deal and I have proven engine builder kits all laid outor do complete engines.
But in general i would set you up with a 540 (since you have a big tire car) nice easy F3 135 or a 139 conventional head will work fine.
Steve Morris
www.stevemorrisengines.com
morris is offline   Reply With Quote
Old 01-20-2011, 09:28 PM   #15
tomato
9.5 on the small block. for the big block- 5.0x4.25= 667 in.
