High build primers? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Auto Body and Paint
Old 01-02-2011, 02:13 PM   #1
429 Powered 84
Pre-Staged
429 Powered 84's Avatar
Question High build primers?
Anyone here use any good high buuild primers and what are the best options?
Dan
429 Powered 84 is offline   Reply With Quote
Old 01-02-2011, 03:53 PM   #2
Autorotica
Default Re: High build primers?
Not much of a body guy but I have used a product called Duo-Prime. Have heard body guys refer to it as spray on stucco..
Chris
Autorotica is offline   Reply With Quote
Old 01-02-2011, 04:16 PM   #3
markadams
markadams's Avatar
Spies Hecker makes a spray polyester primer that can fill up to 100 mils. If you lay a dime on your hood you can fill it. I used some on a badly checked hood I didn't want to strip, been excellent for 8 years. Guys were using it to fill hail dents.
What are you putting it over?
Big THANKS to:
Trend Performance, LGM Racing, Ferrea, Mahle, Holeshot Wheels, Deist, Mallory, Valvoline, Innovate Motorsports, Stroud, BTE, Ultimate Converter Concepts, Davis Technologies, VP Racing Fuels, Fluidyne, Redhorse Performance, Chiseled Performance, Pac Racing Springs, Randy's Ring and Pinion, Comp Cams, Sonnax, Probe, Chris Alston Chassisworks, Borg Warner, The Driveshaft Shop, Mittler Brothers, NLR, CFM, Tial, Weldon, Currie, CSU, Titan, Milodon, Melling, Firecore50.
markadams is offline   Reply With Quote
Old 01-02-2011, 04:20 PM   #4
gutlassracing
gutlassracing's Avatar
I use a product from evercoat called slicksand .. Price wise it is pretty cheap around $75 dollars a gallon and it works great .. It is a spray polyester also and it sands alittle hard compared to primer but I wouldn't use anything else .. After my blocking is done I will even wetsand this and seal and paint directly over it ..
gutlassracing is offline   Reply With Quote
Old 01-02-2011, 05:04 PM   #5
markadams
markadams's Avatar
Quote:
X2. That is a good product also. I think evety manufacturer has their own version of spray poly. Hard to sand is an understatement. .
Big THANKS to:
Old 01-02-2011, 05:35 PM   #6
JFontaine
JFontaine's Avatar
Utech is a good build primer. Sprays and sands nice. All I use anymore.
If you need a extra high build for anything then you are doing it wrong.
JFontaine is offline   Reply With Quote
Old 01-02-2011, 06:49 PM   #7
429 Powered 84
Pre-Staged
Thumbs up Re: High build primers?
I am just looking to see what the best kind is and not gonna brake the bank? I use to do a lot of body work back when my Dad had our own shop but since I have been driving truck and out of it for so long there are so many changes since we were doin it! The body on my car has been completely stripped down to bare metal with aircraft paint stripper and doing all body work as I go. Replaced driverside quarter and redone some old body work in a couple other areas. I was watching Trucks today on Spike and they were sprayn some stuff I have never herd of and could not even find on the net? I think it was called Black polly primer/filler by Clawson? I know I know that I will have to put down etching primer before I can use much of anything else. All the help so far has been great. I do hace a Glass hood that I will need to use some good primer on to get a good block job done has bunch of cracks in the gel coat.
Dan
Old 01-03-2011, 12:10 AM   #8
mico
Spooled up
mico's Avatar
Ive read good things about Utech, know anywhere to get it on the net? No jobbers sell it here in Co.
Mike G
Blacktop Hobbies LLC
mico is offline   Reply With Quote
Old 01-03-2011, 01:25 AM   #9
JFontaine
JFontaine's Avatar
Quote:
That would be odd. Try calling Azko Noble and ask them for a distributor in your area. 1-800-618-1010
Old 01-03-2011, 10:34 AM   #10
mshred
J.I.R.
mshred's Avatar
Utech stuff works good, I used it on my car, had no problems
mshred is offline   Reply With Quote
Old 01-03-2011, 10:40 AM   #11
camaro1968ks
Spooled up
camaro1968ks's Avatar
Speies Hecker the only wat to go,the cheap stuff will crack.
camaro1968ks is offline   Reply With Quote
Old 01-03-2011, 10:48 AM   #12
JFontaine
JFontaine's Avatar
Quote:
Lol.....
Old 01-03-2011, 05:01 PM   #13
racefab57
Ive used slick sand,works good.Used u-tech works good. Sikkens had another one yrs ago but I forget the name of it.U need a BIG tip to spray these primers I have found,or at least it SURE helps.LOL..DR
racefab57 is offline   Reply With Quote
Old 01-03-2011, 11:34 PM   #14
mico
Spooled up
mico's Avatar
Quote:
Sikkens polysurfacer, used a lot of the stuff making goalie masks.
Mike G
Old 01-04-2011, 02:22 AM   #15
1986iroc
1986iroc's Avatar
PPG K-36 works good and sands nice but $$$
1986iroc is offline   Reply With Quote
