Is this piston to heavy? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Nitrous - Induction Solutions
Old 12-23-2010, 08:56 AM   #1
ernie's 5oh
ernie's 5oh's Avatar
Garage
Default Is this piston to heavy?
I have a new set of CP pistons for my sbf, 4.125 flat top, great looking piston very beefy, now is it too beefy?
it weights 665 grams 90 grams more then my last set, most of the weight is in the thickness of the piston top, not sure the technical name for it. The thickness is .350" almost .100" thicker then my last.
I'm running more nitrous then my last motor, and running a heads up class.
Do you think I should look into milling underneith, or leave it thick?
I'm sure the guys at CP know what they are doing.
ernie's 5oh is offline   Reply With Quote
Old 12-23-2010, 09:08 AM   #2
BUCKETT
BUCKETT's Avatar
Default Re: Is this piston to heavy?
I think more on the dome would be good?
BUCKETT is offline   Reply With Quote
Old 12-23-2010, 09:12 AM   #3
Badboss351
Badboss351's Avatar
What is the peak rpms going to be, and whatkind of rods? I know they have options for that when you buy the custom pistons.
XSR built S/S 446" nitrous SBF
Dealer for:
Ultimate Converter Concepts
Baseline Susp.
CV Products/Xceldyne
many more.......
Badboss351 is offline   Reply With Quote
Old 12-23-2010, 11:46 PM   #4
bad427
bad427's Avatar
I guess 665g is with the pin right? I think your piston should be no more than 600g with the pin but then again it all depends... Remember Steve's green mustang with the 420ci Bennett motor... I was tuning the car at the CSCN, he finished runner up to Splash camaro... well the pistons in that motor don't weigh more than 600g and in the final round I put a 700hp tune up in that speedtech system and car become air born 4 wheels of the ground broke the wheelie bars lol... The fastest we run was 8.16@178mph (stock suspension) 2 years of 500-700hp spray never hurt a thing!!! A bad tune will melt the best piston! My 2c
bad427 is offline   Reply With Quote
Old 12-23-2010, 11:59 PM   #5
bad427
bad427's Avatar
Remember this : http://m.youtube.com/#/watch?xl=xl_blazer&v=8cE2XC-Mhjs
Old 12-24-2010, 09:44 AM   #6
bad427
bad427's Avatar
Sorry about the link is from my iphone.. try this: http://www.youtube.com/watch?v=i6Gu_8H2xdc
Old 12-24-2010, 01:05 PM   #7
ernie's 5oh
Garage
Quote:
I wish the piston alone is 665 the rist pin is another 176
But I have corella rods more then strong enough, just wondering how much power I will loose from being crazy heavy.
peek rpm should be around 8500-8700
and its a 412 ci with a 3.85 stroke
Old 12-24-2010, 02:09 PM   #8
bad427
bad427's Avatar
Steel rod @ 8700rpm with 2 stages and a piston with pin that weighs 841g... Ouch!!
I am not an expert but you better of with an aluminum rod! I hate aluminum rods but that is lots of punishement for a steel rod!!!
Old 12-24-2010, 02:20 PM   #9
Sam Vincent
Sam Vincent's Avatar
what is the comp height? Yes, thats pretty heavy. done them (NOT CP) with more top ring land than that weigh 520g range amdn pins in the 135-150g range
sponsors:
Nitrous Express, Diamond, JESEL, Marcella Manifolds, M/T, VP racing fuel, GRP, Bullet Cams, RacePak, Leashed Elect, ATI performance
Vincent Performance
Graham KY
270-977-1893
Dealer:
Diamond, Trend, TotalSeal, BulletCams, Morel, Jesel, Brodix, Moroso, Manton, GRP, Callies, PSI~PAC, Stef's, Nitrous Express, TrickFlow, TotalEngineAirflow, PTC converters, William's Perf, ProLite batt, UltraPro Machine, Danny Bee, ATI Perf, MOSER Engineering, Sonnax Industries, PST shafts...
Sam Vincent is offline   Reply With Quote
Old 12-24-2010, 03:32 PM   #10
ernie's 5oh
Garage
comp height is 1.265 the piston is .010" in the hole 4.126 bore I do have a solid (heavy 58.5lbs) bryant crank, I think the only thing that will help me is that the stroke is only a 3.85
The rist pin, is a .990
Old 12-24-2010, 03:38 PM   #11
NOS-Nelson
Procharger Power
NOS-Nelson's Avatar
That is a heavy piston. Once a piston has been cam ground to size you do not want to modify the deck as it can tweak the skirts.
NOS-Nelson is offline   Reply With Quote
Old 12-24-2010, 03:42 PM   #12
ernie's 5oh
Garage
Quote:
the pistons already have the valve reliefs if thats what you mean, its ready for ceramic coating, and the thinest part of the piston is .350"
Old 12-24-2010, 03:46 PM   #13
NOS-Nelson
Procharger Power
NOS-Nelson's Avatar
No I meant you don't want to mill the underside of the deck to reduce weight. .350 is extremely thick. Is it any thinner under the valve reliefs?
Old 12-24-2010, 03:52 PM   #14
bad427
bad427's Avatar
Is Paul Silva building your engine? He is being doing sbf's before I even knew mustangs existed! What does he have to say? I would listen to Paul if he is building your engine!
Old 12-24-2010, 04:06 PM   #15
Northside
Burnout box
Northside's Avatar
CP builds pistons to specs that builders ask for. I assume your builder asked for them that way.
Northside is offline   Reply With Quote
