2000 Dodge Durango Heater blowing warm air, will not get hot?? - Yellow Bullet Forums
Old 12-18-2010, 03:55 PM   #1
GregS
GregS's Avatar
Default 2000 Dodge Durango Heater blowing warm air, will not get hot??
Is this a heater core issue? Coolant is fine.....
If its the heater core...is it a big job to replace? Waterpump is new as of this year.
This Vehicle is killing me....
1988 Ford Mustang LX
Fox Lake, Procharger, FB Glide, AutoFab Race Cars, PCS, FAST XFI and, Harlow Sammons Racing
8.77/157 MPH Best ET/MPH
GregS is offline   Reply With Quote
Old 12-18-2010, 03:56 PM   #2
E357RACER
Spooled up
Default Re: 2000 Dodge Durango Heater blowing warm air, will not get hot??
flush the heater core if that doesnt help replace, dash will have to come out not too bad to do few hours work.
E357RACER is offline   Reply With Quote
Old 12-18-2010, 03:57 PM   #3
jsj372
jsj372's Avatar
Is the temp guage reading normal? If so, sounds more like a blend door not closing off the cold air.
Team Blevins Motorsports
Southern Motors
www.southernmotors.com
Gilsbach Racecraft
www.gilsbachracecraft.com
Outlaw Photo
Wired 4 Speed
jsj372 is offline   Reply With Quote
Old 12-18-2010, 03:59 PM   #4
RLS Racing
Member
Pullin gears
RLS Racing's Avatar
I got a '99...same problem. Check your thermostat; degree probably is to low.
RLS Racing is offline   Reply With Quote
Old 12-18-2010, 04:02 PM   #5
jsj372
jsj372's Avatar
Quote:
Normally when the T-Stat sticks open and normal engine temp is not achieved, the CEL will come on with either of these two codes.
P0125-CLOSED LOOP TEMP NOT REACHED
P1281-ENGINE IS COLD TOO LONG
Southern Motors
Gilsbach Racecraft
Outlaw Photo
Wired 4 Speed
Old 12-18-2010, 04:06 PM   #6
GregS
GregS's Avatar
Old 12-18-2010, 04:08 PM   #7
GregS
GregS's Avatar
By the way....that is one sick twin turbo Mustang!!!
Old 12-18-2010, 04:08 PM   #8
jsj372
jsj372's Avatar
Quote:
I'll pass on the kind words to the owner. Thanks
Southern Motors
Gilsbach Racecraft
Outlaw Photo
Wired 4 Speed
Old 12-18-2010, 04:42 PM   #9
cumissn
that guy....
cumissn's Avatar
Thermostat.................replaced 3 in one day to get it right....
Pebble Pusher
cumissn is offline   Reply With Quote
Old 12-18-2010, 06:01 PM   #10
KWIK84
KWIK84's Avatar
Locate both heater hose lines, with engine up to temp, are boht lines relatively the same temp? If not back flush heater core. If engine temp is correct and heater core is not plugged, check actuator for blend door, IIRC drop down the glove box door and should be able to get to it, move temp selector through full sweep and see if actuator moves. If not check switch with DVOM and see if it is working correctly. Remove blend door actuator and see if with it still hooked up it will move, if not actuator is bad, if so either blend door is broken, or warped causing it to stick.
KWIK84 is offline   Reply With Quote
Old 12-18-2010, 09:48 PM   #11
1970ls
Aviation Section
1970ls's Avatar
Could be as simple as air in the system, if it was a bad core it would be leaking either inside or outside the vehicle, try to take off the lower hose at one side just for an instant and then reconnect, that will usually "burp" the system, and then make sure it is all the way full when you are done, not just the tank but the rad itself. Dave
Big Jet Crewmember, heavy drinking cured my fear of flying and made me a better person!, hold my Scotch and watch this!
Si Vis Pacem, Para Bellum
64'G/P, 421/Tri-Power A/C 4 Spd.,
73'T/A, 461 A/C 4 Spd.
Part of the Tribe!
1970ls is offline   Reply With Quote
Old 12-18-2010, 09:53 PM   #12
dvdeick
dvdeick's Avatar
Quote:
X2 Have seen a quite a few with blend door problems.
Quote:
Originally Posted by ISELLSPEED View Post
If ya turn your head sideways it looks like an Arby`s r.b sandwich.
Thanks to
The whole crew @ Billet Atomizer Injectors
Quillen Motorsports
BB&T Racing
PTC Converters
Joel at Orme Bros.
Bob Kurgan
dvdeick is offline   Reply With Quote
Resources saved on this page: MySQL 2.20%
