winter upgrades/changes - Page 46 - Yellow Bullet Forums
Old 02-03-2012, 07:27 AM   #676
DOTracer
DOTracer's Avatar
Default Re: winter upgrades/changes
Thank you. Nothing really to update. I brought the rear bumper home to test fit (in primer) as we narrowed the corners. Took some tweaking, but it's fitting fine.
I also completed the tubular core support, so I dropped those parts off to the paint shop. I'm on him right now to get the rest of the body parts back so I can get all the steetmetal installed and lined up. Not a whole lot major I can do till I get the rest of the body parts back.
DOTracer is offline   Reply With Quote
Old 02-04-2012, 01:01 PM   #677
BENCHSEATRACIN
Launchin
BENCHSEATRACIN's Avatar
here ya go Todd......
BENCHSEATRACIN
www.BENCHSEATRACIN.com
BENCHSEATRACIN is offline   Reply With Quote
Old 02-04-2012, 05:00 PM   #678
t-bird racer
t-bird racer's Avatar
Just a few upgrades this winter. I'm installed the Holcomb light weight racing steering column. A couple new gauges/shift lights. I may get a new cowl hood and take
some weight off the front of the car. Then the usual ( Belt re-cert 100) (Cage re-cert 200) New slicks (450). Damn this shit gets expensive.
t-bird racer is offline   Reply With Quote
Old 02-04-2012, 08:01 PM   #679
68 nova 10.5
68 nova 10.5's Avatar
Do you have voltage reducers to your components?
http://s87.photobucket.com/albums/k1...nsperformance/
1.399 60' 3rd pass foot brake no spool stock suspension! On a 9" slick!
68 nova 10.5 is offline   Reply With Quote
Old 02-04-2012, 08:19 PM   #680
DOTracer
DOTracer's Avatar
Quote:
You mean because of the 16 volts?
If so, not step down needed on any of the components.
Old 02-04-2012, 09:03 PM   #681
68 nova 10.5
Thanks we are using the stack,7531& the K&R wiring because you showed how nice they are! They should pay you for advertising!
Old 02-04-2012, 09:05 PM   #682
Monkey Grip
D.J. RIBBY
Monkey Grip's Avatar
Brakes have been bled, driveshaft sensor installed & wired, pressure transducers mounted, vacuum sensor mounted, main fuel line up front completed, brake light wire corrected, shock bumpers cut down and shocks remounted inverted.
Have the stock core support mocked up taking measurements to fabricated a chromoly tubular replacement. Oh yea, the new smaller/lighter radiator/fan assembly came in this week.
I HAVE A COUPLE THINGS TO SAY ABOUT THIS BUILD.......CLEAN AND CLEAN!!!!!
Monkey Grip is offline   Reply With Quote
Old 02-04-2012, 09:07 PM   #683
DOTracer
DOTracer's Avatar
I wish!
Old 02-04-2012, 09:14 PM   #684
DOTracer
DOTracer's Avatar
Quote:
thank you.
Old 02-05-2012, 12:45 PM   #685
DOTracer
DOTracer's Avatar
Worked this morning in the garage correcting an issue that came up.
The seat covers came this week, so I installed them, sat in the car and put my helmet on. The headroom was not what I was looking for. It was a bit tight and once I put padding on the upper bars it was gonna get worse. Also, the seat position vs steering wheel location and gauge display location had the top of the steering wheel blocking my view of the top half of the tach. This bothered me from day one, but everything was pretty much mounted where it needed to go.
Well, this morning I decided to lower the seats by cutting down the seat brackets. A couple hours worth of work allowed me to drop the seats 1" which is about all I could get out of them.
Everything back in place and the headroom is much improved, and gauge display visibility is noticeably improved as well. Not perfect, but better and I think I can live with it now.
Will have to take the seat brackets for blasting and then have them powder coated again.
Old 02-05-2012, 05:47 PM   #686
JCRVETTE
JCRVETTE's Avatar
^^ I know that one. My wife, who works at/in the shop will say something like: "Ya know, I can already see you don't like how thats turning out. you might as well fix it now before you just have to cut it out later. You aren't going to sleep or be happy until thats perfect". I see you are the same way about your work.
Actually, saw it in you the first day
Paul @ JCR Chassisworks Weirsdale, Fl. 352-821-FAST (3278 )
follow us on FACEBOOK
www.jcrchassisworks.com
JCR Upper and Lower Mustang Torque Box Install and 25.3 New Edge Build
A few JCR build threads - Click links below
Top Sportsman Plymouth Duster
'06 GTO Street/strip Car with Solid Rear Axle
1st Gen Camaro Flush Lexan
JCRVETTE is offline   Reply With Quote
Old 02-05-2012, 05:51 PM   #687
DOTracer
DOTracer's Avatar
Thanks Paul. Good to know I'm not the only anal one out there.
Old 02-05-2012, 06:34 PM   #688
DOTracer
DOTracer's Avatar
Thought I would share this one pic quick to show how the interior colors will work out.
Rear plastic interior panels will be reinstalled and are black. Carpet will be black as well as the 5 point harness. The window net is silver as it was the only color webbing they had in stock when I was doing the fabrication phase. The door panels will be carbon fiber and the dash will be painted black.
Just trying to have a little contrast in the interior as it was all black prior.
Old 02-05-2012, 06:38 PM   #689
hiway
hiway's Avatar
Perfection!
Just your average Arkansas street machine
MidsouthRacers.com
hiway is offline   Reply With Quote
Old 02-05-2012, 06:49 PM   #690
john burdine
john burdine's Avatar
Quote:
Originally Posted by hiway View Post
Perfection!
You win bro, everyone else just quit. its fucking perfect. to make myself feel better i was hoping to pick out somthing i dont like, but it just aint happening. Killer job!
john burdine is offline   Reply With Quote
Resources saved on this page: MySQL 2.06%
