421 sbc?? - Yellow Bullet Forums
Old 12-07-2010, 03:08 PM   #1
BFalfa
Member
Pullin gears
BFalfa's Avatar
Default 421 sbc??
what are you guys using cam wise for a 4.155x3.875?? do you have to use a small base circle cam?? thinking of this combo in a dart little m. with 15 degree heads??
how are you guys make the 800-900 hp with the 15 deg headed engines??
BFalfa is offline   Reply With Quote
Old 12-07-2010, 03:13 PM   #2
kba1987
kba1987's Avatar
Default Re: 421 sbc??
You better get you a raised cam block if you want to make 900 hp and forget the little m I have a Dart Iron Eagle for sale raised cam keyway lifter bushings and a 55mm cam tunnel if intrested for a good price!!!
And yes you will have to have a small base circle cam if you dont have a raised cam block.
kba1987 is offline   Reply With Quote
Old 12-07-2010, 03:23 PM   #3
JeffMcKC
JeffMcKC's Avatar
You can use a stroker rod for 800, but 900 HP is not going to just be bolted together, there is a lot of difference to a 800 HP and 900 in a SBC
"IF IT DOES NOT HAVE A TRAILER HITCH ITS A RACE CAR!!!"
TRZ Dealer
2012 Winner SSSB/NA 9.67 @ 139MPH
2007 Winner SB/NA Drag Week 9.98
Thanks Curtis @ RFD Heads and Intakes
http://www.raceflowdevelopment.com/
JeffMcKC is offline   Reply With Quote
Old 12-07-2010, 04:20 PM   #4
BFalfa
Member
Pullin gears
BFalfa's Avatar
i kinda thought that the small base circle cam and little m block may have its hp limits.
Old 12-07-2010, 04:42 PM   #5
JeffMcKC
JeffMcKC's Avatar
Yes it will!
TRZ Dealer
Old 12-07-2010, 05:04 PM   #6
CNC BLOCKS
CNC BLOCKS's Avatar
We just built a 421 using an SHP block with the callies compstar rods and we used a 1.000 base circle and I could have used a 2.000 rod pin and used a standard base circle cam.
CNC BLOCKS is offline   Reply With Quote
Old 12-07-2010, 05:20 PM   #7
JeffMcKC
JeffMcKC's Avatar
And made 900 HP? with a 1 inch BS cam?
TRZ Dealer
Old 12-07-2010, 07:07 PM   #8
CNC BLOCKS
CNC BLOCKS's Avatar
Quote:
Where did I say it mad 900 horse??? or did I miss something
Old 12-07-2010, 07:25 PM   #9
bad427
bad427's Avatar
For the 800-900 HP Sbc motor you better of using the taller deck block! As for the camshaft for that king of HP if n/a you better of with roller cam bearings and small base 4/7 swap camshaft... You still have to check all your clearances rod to block, rod to camshaft.... At that kind of HP level everything is a custom deal! Just build a Sbf you won't have those issues lol! Just kidding!
bad427 is offline   Reply With Quote
Old 12-07-2010, 08:06 PM   #10
JeffMcKC
JeffMcKC's Avatar
I geuss the fact your posting it in a guys question about a 800/900 hp 421
TRZ Dealer
Old 12-07-2010, 11:08 PM   #11
69chicken
69chicken's Avatar
55mm roller or 60mm base cam core, 1.000" lift on the intake side mid .800s on exh, Lots of rocker ratio, the biggest lifters and pushrods you can get just to start. I would do the 9" deck Dart I.E. block with the cam raised .440" I think this is the Arrora(spelling???) cam height. Crank 3.750" arm dont need that super light weight though but a nice one with 2.00" pins. Custom pistons, thin rings and on and on.
The CFE head is a great place to start. I think Butch Kemp had a nice setup for sale with intake also.
69chicken is offline   Reply With Quote
Old 12-08-2010, 09:40 AM   #12
z289sec
z289sec's Avatar
800 can be achieved with just a small base circle cam and a standard block, hell.......that can even be done with a 23 degree head.
Getting to 900 like others have said is a whole 'nother ball game.
RTCTTFMF!!!!
Stock suspension 67 Camaro
565 Conventional head BBC with fogger and a plate on 275's
Just about done
Thanks to:
Texas Racewerks, Sanger, Texas
Nyes Automotive Racing Engines, Muncie, Indiana
FTI Converters and Transmissions, Deland, Florida
ACE Racing Transmissions, Garland ,Texas
z289sec is offline   Reply With Quote
Resources saved on this page: MySQL 2.15%
