Took car to the dyno... Need help troubleshooting - Page 7 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Electrical - Hyperaktive Performance Solutions
Old 12-07-2010, 05:02 PM   #91
michaeld
michaeld's Avatar
Default Re: Took car to the dyno... Need help troubleshooting
Quote:
Originally Posted by 67AfroMaro View Post
Here is where we blew #7 primary off...
http://www.youtube.com/watch?v=WadoTx1yIfU
I assume your O-2 sensor is on the other side?
michaeld is offline   Reply With Quote
Old 12-07-2010, 05:18 PM   #92
67AfroMaro
That guy...
67AfroMaro's Avatar
Quote:
Yes... I've been thinking about adding an O2 to this side as well...but in a primary for a cleaner reading.
DJ Reid - www.afromaro.com
Vortech Superchargers
Chris Alston's Chassisworks
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Unlimited Fiberglass
Holley Performance
Flatiron Racecars
Follow me on Facebook
Follow my build on
67AfroMaro is offline   Reply With Quote
Old 12-07-2010, 07:05 PM   #93
michaeld
michaeld's Avatar
http://img146.imageshack.us/img146/1...headers007.jpg
The header tubes need to be attached to the collector like this on every tube.. the tubes that are not attached are the ones that blow out...
Old 12-07-2010, 07:08 PM   #94
67AfroMaro
That guy...
67AfroMaro's Avatar
You are saying it is normal to blow out a primary?
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Holley Performance
Flatiron Racecars
Follow my build on
Old 12-07-2010, 07:21 PM   #95
michaeld
michaeld's Avatar
No.. not normal,, on engines with power you will always blow out the primary tube that is not bolted to the collector.. Most people mount there slip on collectors with two tubes,, it needs to be all 4 tubes securely attached to the primaries...
Old 12-07-2010, 07:28 PM   #96
yeti
Make a pull with the room lights off. What color is the header pipe? What color is steel when it is soft enough to bend easily?
yeti is offline   Reply With Quote
Old 12-07-2010, 07:58 PM   #97
michaeld
michaeld's Avatar
Quote:
Yes the tubing gets soft then the exhaust pressure blows the improperly mounted primary out of the collector,,, I`ve seen primaries with 1.5 inch of overlap into the collector get blown out, then people look at it scratching there head trying to figure out "how the fuck that came out of there and how we gona put it back in..."
Old 12-07-2010, 08:08 PM   #98
michaeld
michaeld's Avatar
Witch one do I use to drag the actual pic from the host?
Old 12-07-2010, 10:50 PM   #99
03supercobra
Spooled up
03supercobra's Avatar
There yah go^^
03supercobra is offline   Reply With Quote
Old 12-24-2010, 12:02 PM   #100
67AfroMaro
That guy...
67AfroMaro's Avatar
I re-checked the crank sync last night and it was 8 degrees off... no wonder why we had to set it at 41* reference. So now it is at 49* reference. To fix my map, I multiplied my timing table by 120%. Only thing is that it has me around 40* at idle and around 30* under 30#'s of boost... on a 15* head (and it seemed like it wanted more given the iceless inlet temps and the power gains on the previous pulls)!!! I spoke to some people and we are thinking my ignition is not fully up to the task, hence the timing numbers. We'll soon see.
Thanks Ben for coming out with me and keeping the tuneup safe over the 5 gazillion pulls. Thanks Sean on the keen eye for some small but important details. Thanks Mike for the phone a friend tech support. And thanks Rob for bringing all the shitheads to make fun of me during the pulls
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Holley Performance
Flatiron Racecars
Follow my build on
Old 12-24-2010, 01:30 PM   #101
Greg Kelley
Thanks to DJ for creating one of the most informative threads that I have seen on YB.
GK - 609-265-2110 -- http://www.motorsportsinnovations.com/
Data Logging - Racepak - Edelbrock
Wide Band O2 - Innovate -
Good Old EGT kits too!
Greg Kelley is offline   Reply With Quote
Old 12-24-2010, 02:09 PM   #102
NOS-Nelson
Procharger Power
NOS-Nelson's Avatar
Anytime DJ. Glad it's finally coming around for you.
NOS-Nelson is offline   Reply With Quote
Old 12-24-2010, 02:17 PM   #103
turbo
Outlaw 8.5 #2
turbo's Avatar
damn thats the thanks i get
Rob
Turbo SB2
2010 WCHRA Outlaw8.5 #2
www.4rsfed.com
turbo is offline   Reply With Quote
Old 12-24-2010, 02:21 PM   #104
67AfroMaro
That guy...
67AfroMaro's Avatar
Quote:
LOL... and the spare box... and the spare coil... and the house calls... and... well, you get the point.
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Holley Performance
Flatiron Racecars
Follow my build on
Old 12-24-2010, 09:04 PM   #105
lil grey
Pre-Staged
lil grey's Avatar
Why i gotta be a shithead???
lil grey is offline   Reply With Quote
