Took car to the dyno... Need help troubleshooting - Page 5 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Electrical - Hyperaktive Performance Solutions
Old 12-02-2010, 08:46 AM   #61
michaeld
michaeld's Avatar
Default Re: Took car to the dyno... Need help troubleshooting
Quote:
Originally Posted by michaeld View Post
MSD has had a lot of problems with the 8261 in the last 18 months,, I lost a round of competition cause the new {2 passes} 8261 went bad {miss fire under load, like it on the rev limiter} have been replacing them with the big red Mallory coil. Car seems to rev higher with the Mallery than it ever did with a 8261 coils....
In fact between me and a couple customers of mine we have 3 8261 coils that I would like to return,, $162.00 each,, I was especially pissed when I lost first round due to coil failure. I`m on the msd mvp program,, guess I should call them and see what happens,, hate returning stuff but these things add up...
michaeld is offline   Reply With Quote
Old 12-02-2010, 07:14 PM   #62
67AfroMaro
That guy...
67AfroMaro's Avatar
Being a guy with one coil...what can I do to test it?
DJ Reid - www.afromaro.com
Vortech Superchargers
Chris Alston's Chassisworks
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Unlimited Fiberglass
Holley Performance
Flatiron Racecars
Follow me on Facebook
Follow my build on
67AfroMaro is offline   Reply With Quote
Old 12-02-2010, 08:14 PM   #63
yeti
Quote:
Get one of these for $7.60, plug it in and see if it makes any difference.
http://cgi.ebay.com/ebaymotors/Ignition-Coil-Ford-Mazda-Mercury-Lincoln-FD478-/330441908796?pt=Motors_Car_Truck_Parts_Accessories &hash=item4cefdf623c
Or, you could pay twice as much for it here,
http://cgi.ebay.com/ebaymotors/NEW-I...item255efbcafb
at $14.75 it must be twice as good……..LOLOLOLOL….twice as many volts....BWAAHHAAHHAAAA......
Or here, for 20 bucks……
http://www.napaonline.com/Search/Detail.aspx?R=MPEIC24SB_0150094660
Seriously, for troubleshooting, any other (known good) coil will do.
yeti is offline   Reply With Quote
Old 12-04-2010, 01:35 PM   #64
67AfroMaro
That guy...
67AfroMaro's Avatar
Ohm tested my wires...
----- COIL (323) -----
8 [780] ------ 7 [814]
6 [906] ------ 5 [853]
4 [1208] ---- 3 [1056]
2 [1347] ---- 1 [1175]
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Holley Performance
Flatiron Racecars
Follow my build on
Old 12-04-2010, 04:37 PM   #65
yeti
The numbers are normal. Longer = more resistance.
Old 12-04-2010, 06:07 PM   #66
michaeld
michaeld's Avatar
By chance are they msd wires? Did you shake them as you thested them? sometimes the crimp on the spark plug end is loose...
Old 12-06-2010, 06:30 AM   #67
The Metal Man
The Metal Man's Avatar
did you ever try swapping the injectors to different holes and seeing if the problem changed holes?
The Metal Man is offline   Reply With Quote
Old 12-06-2010, 10:00 AM   #68
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
We had several problems with the MSD wires that have the multi-angle spark plug boots on them. This was on a BBC. Went-outside and took the wires off his F-250 which had the 45* angle boot we needed, threw them on the engine, and it was fine.
Now, these MSD wires were brand-new and went through two sets. Seems that when we made the bend in them the core broke. Was hard to find with a voltmeter since it was intermittent. These were pre-made, after that we made them ourselves.
We really couldn't see the misfire since it was a single turbo setup and the other cylinders really masked-out the problem.
Mike Beck is offline   Reply With Quote
Old 12-06-2010, 12:58 PM   #69
67AfroMaro
That guy...
67AfroMaro's Avatar
It was pointed out to me that negative correction was adding fuel. In the log, you can see the AFR is at 10.5 on a 11.8 target and is still adding 5%, this is the only thing I could find that was definitively wrong. I was told buy one person that this wouldn't cause the problem and told by the person that saw the issue, this is exactly what their problem was when they went to the dyno...
Going back to the dyno today. Other things I have done...
New plug wires.
Valve lash.
New plugs with tighter gap.
Flushed rails and injectors.
Shuffled injector location in rail.
Checked for boost leaks.
Bringing a spare coil.
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Holley Performance
Flatiron Racecars
Follow my build on
Old 12-06-2010, 05:05 PM   #70
yeti
May the force be with you. Or...May you apply The Force to the dyno.
Old 12-06-2010, 05:29 PM   #71
RPMOUTLAW
Launchin
RPMOUTLAW's Avatar
Cam sync error enabled in the big stuff? Disable it and try it.
RPMOUTLAW is offline   Reply With Quote
Old 12-06-2010, 08:25 PM   #72
michaeld
michaeld's Avatar
Ok,, some times if the AFR is on the fat side and the timing a little on the low side the loaded engine will exhaust fire,, the O-2 "sees" fire as a lean condition and tries to add fuel.. If you are serious about tune and making power in a drag race application you should turn off the O-2,, {open loop} The O2 will still read for data and the target AFR table will still be use in algorithm to calculate fuel.. In a good running drag race engine the O-s simply reads history,, meaning by the time the O-2 reads what is in the exhaust and the ecu tries to "fix" the afr it is too late,, the engine speed, load, boost, has changed.. We never use the O-2 for anything other than data log,, we have always ran better with a good tune and the O-2 in open loop..... O-2 is a running down the road street car thing,, For what it is worth even most new cars go to open loop at wfo anyway..
Old 12-06-2010, 08:32 PM   #73
michaeld
michaeld's Avatar
I have had many problems with msd wires on a multitude of cars for years now,, Most of the time the problem isn`t obvious unless the car is equipped with egt`s on every cylinder.. The cars would launch on all the candles then loose one shortly into the run,then go across the finish with all candles lite.... When someone brings me a car for tune and it has msd wires the first thing we do is change them to Moroso.. Just not worth having this problem...
Old 12-06-2010, 08:38 PM   #74
yeti
The way they (MSD) crimp the conductor to the terminals with the separate crimp instead of folding it back over the insulation causes the little spiral wire to break.
Old 12-06-2010, 08:43 PM   #75
michaeld
michaeld's Avatar
Quote:
Exacly,, and if it isn`t broken it is loose in the crimp... It is hard as hell to take the plug boot off the wire but when you do you can see what we are referring to..
