Took car to the dyno... Need help troubleshooting - Page 2 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Electrical - Hyperaktive Performance Solutions
Old 12-01-2010, 12:33 PM   #16
NOS-Nelson
Procharger Power
NOS-Nelson's Avatar
Default Re: Took car to the dyno... Need help troubleshooting
Quote:
Originally Posted by 67AfroMaro View Post
Yes, tried timing at 20, 25 and 30 and the box sets it correctly against my light.
All you need to do is check it at 30. If it matches then your crank trigger is exactly where your crank angle reference value is. What do you have for the reference?
NOS-Nelson is offline   Reply With Quote
Old 12-01-2010, 01:12 PM   #17
67AfroMaro
That guy...
67AfroMaro's Avatar
Quote:
41
DJ Reid - www.afromaro.com
Vortech Superchargers
Chris Alston's Chassisworks
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Unlimited Fiberglass
Holley Performance
Flatiron Racecars
Follow me on Facebook
Follow my build on
67AfroMaro is offline   Reply With Quote
Old 12-01-2010, 01:21 PM   #18
67AfroMaro
That guy...
67AfroMaro's Avatar
Sucks!
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Holley Performance
Flatiron Racecars
Follow my build on
Old 12-01-2010, 01:22 PM   #19
NOS-Nelson
Procharger Power
NOS-Nelson's Avatar
41
Yeah that's too late. Advance the crank trigger 9 and set the reference back to 50. How much timing do you have at idle? 34-36 or so?
Old 12-01-2010, 01:24 PM   #20
NOS-Nelson
Procharger Power
NOS-Nelson's Avatar
Sucks!
Scroll back to where you are on the throttle and repost a screenshot.
Old 12-01-2010, 01:38 PM   #21
67AfroMaro
That guy...
67AfroMaro's Avatar
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Holley Performance
Flatiron Racecars
Follow my build on
Old 12-01-2010, 01:40 PM   #22
67AfroMaro
That guy...
67AfroMaro's Avatar
doh... this is the not full TPS one... I'll have to download the 100% one
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Holley Performance
Flatiron Racecars
Follow my build on
Old 12-01-2010, 01:46 PM   #23
NOS-Nelson
Procharger Power
NOS-Nelson's Avatar
That TPS value should be fine. Go into your AFR negative correction and make sure all the values are -. From the looks of it you may have positive values in there.
Old 12-01-2010, 03:20 PM   #24
yeti
18.3V ? Use a 'noid' and a stethoscope to see if the injectors are firing and sound the same as the others.
yeti is offline   Reply With Quote
Old 12-01-2010, 03:24 PM   #25
67AfroMaro
That guy...
67AfroMaro's Avatar
It's a 16v system with an alt.
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Holley Performance
Flatiron Racecars
Follow my build on
Old 12-01-2010, 03:34 PM   #26
Uncle Paul
Uncle Paul's Avatar
Quote:
Or do it old school and use a long blade screw drive. The metal end on the injector and the plastic end to your ear. At 16 volts you will hear them click.
I'm your Huckleberry,,,,
http://www.northernchateau.com/
Uncle Paul is offline   Reply With Quote
Old 12-01-2010, 04:25 PM   #27
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
At almost ANY voltage you will here them click! Taught my daughter how to "listen" to things on the engine with a long screwdriver. The "poor mans" stethescope!
Were the injectors flowed before using them? Were they flowed at the rail pressure you are running? Some injectors do not like high rail pressure. I have almost never seen a clogged injector. A little bit of crap in the inlet screen, but never enough to stop flow 100%. And...........it is far better to have NO flow than to have SOME flow!
Mike Beck is offline   Reply With Quote
Old 12-01-2010, 04:32 PM   #28
yeti
http://www.injectorcleaning.co.uk/spray.htm
Old 12-01-2010, 04:37 PM   #29
Greg Kelley
sounds like rotor phase to me.
did you say you have a crank trigger and the 7 reluctor teeth removed configuration?
I think I have a video of testing injectors and harness with a 9 volt battery, I'll try to find it.
before I had my own injector cleaning/flowing machine I rigged up some hose and a can of carb cleaner and hooked up a 9 volt battery to a push button. It would find any injector that way way clogged. I may have a pic of that as well.
GK - 609-265-2110 -- http://www.motorsportsinnovations.com/
Data Logging - Racepak - Edelbrock
Wide Band O2 - Innovate -
Good Old EGT kits too!
Greg Kelley is offline   Reply With Quote
Old 12-01-2010, 04:51 PM   #30
67AfroMaro
That guy...
67AfroMaro's Avatar
Would rotor phase consistently miss the same two cylinders?
Do you spray through the injector opening or outlet?
I have this dist http://www.summitracing.com/parts/MSD-2340/
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Holley Performance
Flatiron Racecars
Follow my build on
