LS in a fox body - Yellow Bullet Forums
Old 11-28-2010, 07:17 PM   #1
Dragpny
Member
Pullin gears
Dragpny's Avatar
Default LS in a fox body
Im thinking of using a LS motor for my 92 5.0. Is there alot of cons to these combinations? How much can I spray with those motors? Any suggestions on where to get a set-up?
92 Mustang
25.5
LS Powered on the Spray
Powerglide
Dragpny is offline   Reply With Quote
Old 11-28-2010, 07:46 PM   #2
Jordan81
Duct Tape and WD-40
Default Re: LS in a fox body
might have better luck here
http://www.yellowbullet.com/forum/forumdisplay.php?f=36
Jordan81 is offline   Reply With Quote
Old 11-28-2010, 07:52 PM   #3
phantomracer
having fun
phantomracer's Avatar
aluminum or iron block?
im setting up a fox soon for one of these engines-we have an iron block lq9 truck engine for the car--ordering an aje crossmember for this car
the aluminum block is just that-softer aluminum -ive seen a few on the street locally that have sprayed right through the casting with over 200 hp shots--maybe bad tunes? who knows-i didnt work on em or build em
but in the end these guys have switched to iron blocks so im assuming they either need the beefier block so theyre bad tunes can melt the pistons instead-or the aluminum block is just that weak..
this space for rent
phantomracer is offline   Reply With Quote
Old 11-28-2010, 10:56 PM   #4
Justahbu
Member
Pullin gears
http://www.yellowbullet.com/forum/sh...d.php?t=285122
Justahbu is offline   Reply With Quote
Old 11-28-2010, 11:00 PM   #5
d16v
Launchin
d16v's Avatar
Bad Chad has one and i think running 150 shot.
d16v is offline   Reply With Quote
Old 11-28-2010, 11:08 PM   #6
blackflag
blackflag's Avatar
Quote:
How much are you wanting to spray? 150-175? Ls1 with arp2000 rod bolts
200-250? - Iron 6.0L block with a set of pistons. L92 heads and Ls3/L76 intake
250+ - Iron 6.0L or LSX block w/ forged bottom end etc
Your 92 should go mid 11's with a cam only Ls1 or 6.0L iron setup and 10's on a 150 easily.
LSX
blackflag is offline   Reply With Quote
Old 11-28-2010, 11:51 PM   #7
Fryguy302
Fryguy302's Avatar
Can't answer the spray questions, but I have one of these for a street car. We used the AJE k-member and Kooks headers for this application and they both worked great. We used an F-body oil pan and fabbed a cross member. I like the AJE stuff because the same k-member can accept a SBF if you buy a different pair of motor mount stands. I bought both sets just in case I want to go back to the SBF.
www.detroitracing.com
Fryguy302 is offline   Reply With Quote
Old 11-29-2010, 12:31 AM   #8
Supersport623
Spooled up
Supersport623's Avatar
The swap itself is very easy nowadays. I've had a few customers do the swap already using the AJE K member and Tranny crossmember. As Fryguy said the AJE stuff is nice because of the interchangable motor mounts. Headers are becoming easier to come across nowadays too.
Mike
Mike
PM about a big discount on MSD 7531 Digital 7. $769 - $50 off of Summit!
http://www.skspeed.com
We will BEAT Summit's prices whenever possible, PM me for any quotes.
Dealer for:
AFR-ARP-Autometer-BBK-B&M/Hurst-Comp Cams - Crower -Eagle -Edelbrock-Ford Racing-Holley-Moroso-MSD-Moser-Proform-Quickfuel-XRP... and many more!
Long Island's Speed Shop
Email me for any parts needs, Competitive Pricing, Nationwide Shipping
Supersport623 is offline   Reply With Quote
Old 11-29-2010, 12:47 AM   #9
brandoz28
Member
Pullin gears
brandoz28's Avatar
let me know if you do this, i'll want to see the car at the track!
and there are guys who have sprayed up to a 200 on a stock bottom end, but you have to be on top of the tuneup. 150-175 shouldn't be too much of a stretch though. going to be going carbed or fuel injected?
let me know if you need any help putting it all together, not sure where you're at in iowa
86 Camaro Sport Coupe,
special thanks:
Burkhart Chassis
PA Racing
Nitrous Outlet
brandoz28 is offline   Reply With Quote
Old 11-29-2010, 12:55 AM   #10
cmccarthy
Tellin' it like it is
cmccarthy's Avatar
Hell, they sell the K-member and headers in Jegs now. I say its a great swap. A killer engine in a killer chassis, what can be bad about that?
Charles
BAITTFMF
cmccarthy is offline   Reply With Quote
Old 11-29-2010, 12:59 AM   #11
jamnutz
jamnutz's Avatar
I sprayed a stock bottom end LS1 with a 200 shot for years, when the motor finally went I had been running it NA for about a year. Right now I have an aluminum blocked LS1 that's in my 99z that makes an extra 300 RWHP on the kit (fogger), and no block issues. Biggest issue with LS1's is if you are using a single nozzle, or a plate, the #7 cylinder likes to go lean, and you end up with busted ring lands. We setup my fogger on the dyno, using EGT's from each cylinder, so my jetting is not just based on NX's recommended jetting. So not all of my cylinders have the same jet setup. Right now it's making about 795 RWHP on the kit, we are preparing to re-jet for another 100 rwhp, so we'll see what she can handle. This motor is being pulled to go in my Fox Project in my signature.
2010 SS 9.93 @ 141 stock short - Sold for an offer I couldn't refuse.
99 Z28 runs 9's - Street car.
87 Turbo Regal Gets the job done.
91 Syclone Not as quick as the Regal.
02 25.2 Formula 15 sec 632bbc open headered bracket car.
90 Mustang GT 275 DR LS1 Assload of spray
jamnutz is offline   Reply With Quote
Old 11-29-2010, 03:19 AM   #12
proxemics
Launchin
I just got my fox from the exhust factory they fabricated long tubes headers and X pipes for me. mine has aluminum blocked LS1
proxemics is offline   Reply With Quote
Old 11-29-2010, 12:36 PM   #13
orangenotch
Burnout box
Its pretty easy swap. My bone stock 6.0 lq4 intake to pan with a th350,3500 stall and 8.8 with 3.73's has went 12.17@111 with a 1.68 60ft n/a and 11.29@117 on a 100 shot with a 1.56 60ft all on drag radials.
1986 comp orange notch
Bone stock 05 lq4 6.0 swap,built th350, 3500 stall, longtubes, cai, and tune. 12.1@111 1.68 60ft on radials
11.2@117 1.56 on radials and 100 shot
orangenotch is offline   Reply With Quote
Old 11-29-2010, 12:41 PM   #14
5.0Cammer
5.0Cammer's Avatar
Quote:
with a cam and intake. Vids
http://www.htownracing.com/forums/sh...ad.php?t=48285
5.0Cammer is offline   Reply With Quote
Old 12-03-2010, 08:25 AM   #15
Dragpny
Member
Pullin gears
Dragpny's Avatar
Do the L92 heads use the same exhaust manifolds as all LS heads? And Im going to use a motorplate from Racecraft inc with a glide. Should be a nice change. Who makes a good stroker kit for 6.0 iron blocks?
92 Mustang
25.5
Powerglide
