ALL PRO 245 SBC HEADS - Yellow Bullet Forums
Old 11-20-2010, 07:13 AM   #1
jottsracing
Launchin
jottsracing's Avatar
Default ALL PRO 245 SBC HEADS
I bought a set of these from rons porting service, im switching from the brodix m2t1 227 track 1 heads hoping to see a change.
jottsracing is offline   Reply With Quote
Old 11-20-2010, 07:34 AM   #2
smallblk77
I like to party!!
smallblk77's Avatar
Default Re: ALL PRO 245 SBC HEADS
Keep us posted on the performance gaines
Here for the and
smallblk77 is offline   Reply With Quote
Old 11-20-2010, 09:18 AM   #3
BLUEBYU
Pre-Staged
BLUEBYU's Avatar
what kinda deal did he give u on these heads if u dont mind me asking??
BLUEBYU is offline   Reply With Quote
Old 11-20-2010, 10:40 AM   #4
BIG PURPLE
BIG PURPLE's Avatar
i have a set on my twin turbo firebird they work great! i still have alot of work to do with my combo but so far the heads are great.
BIG PURPLE is offline   Reply With Quote
Old 11-20-2010, 10:57 AM   #5
onehookinsuv
Spooled up
onehookinsuv's Avatar
There was a guy on RG selling a new set of RR245 complete with a super victor intake that were cnc ported by Rons for $4200.00.
onehookinsuv is offline   Reply With Quote
Old 11-20-2010, 11:02 AM   #6
gforce nos
Launchin
gforce nos's Avatar
Quote:
Trust me you will see a big change !I have a set that I brought from Ron's porting service. These heads make killer horsepower !
gforce nos is offline   Reply With Quote
Old 11-20-2010, 11:27 AM   #7
Jalil Jaber
Lord of Lords
Jalil Jaber's Avatar
Same here, got a set from Ron's and they definately kicked the shit out of my old Dart 220 RR's
Blown Injected Alcohol True Ten Five 1970 Chevelle SS
Jaber Racing Enterprises thanks all it's sponsors:
Steve Woods Specialties - San Leandro CA
Big-0 Tires - Alameda, CA
Lonnie Houde Performance - www.lonniehoude.com
ERC Racing Fuel - www.ercracingfuels.com
Jalil Jaber is offline   Reply With Quote
Old 11-20-2010, 12:16 PM   #8
99horse
Member
Pullin gears
99horse's Avatar
I Have a set of -cnc- All Pro 245 RR ...bad azz heads for sure
they call me 'THE ZIP TIE JEDI' THE ONE & ONLY BLOW-THRU CAR ON THE 'PASS-TIME' all Turbo edition
2011 CLASH OF THE TITANS 'CHEAP STREET' CHAMPION
69 NOVA---ON 275'S
4.92
143.7
1.15 60' ON LEAF SPRINGS
@ 3425 #
99horse is offline   Reply With Quote
Old 11-20-2010, 03:39 PM   #9
dante1020
Member
Pullin gears
dante1020's Avatar
what did you guys see as far as ET pickup?
X275
dante1020 is offline   Reply With Quote
Old 11-21-2010, 08:26 AM   #10
jottsracing
Launchin
I paid 4000.00 for the heads and he is gonna sell me a raised runner intake fully cnc'd for 980.00.
Old 11-21-2010, 08:26 PM   #11
BLUEBYU
Pre-Staged
BLUEBYU's Avatar
that sounds reasonable.when u get them bad ladds on and get some numbers keep us posted.i put together a 18* headed motor wish i just went with some 23*allpro stuff
Old 11-21-2010, 09:43 PM   #12
jottsracing
Launchin
I will keep you posted, im hoping to run high 20's to low 30's on one stage maybe a 300 shot . I've been a 5.41 with the Brodix Track 1 KC 227 heads so i hope they pick me up a tenth.
Old 11-22-2010, 12:13 AM   #13
alkyal
Launchin
Be sure and check your valve pocket locations of the int/ex, as there is a .085 dowel pin shift that usually requires the pockets to be cut addl towards the int. side of the pocket on both the int and ex pockets. the revised int/ex split[left/right] will usually fit [ie 60/40] ok. Most pistons will accomidate the cut, but measure the thickness to be sure your min is @ leaset .120/.140 for n/a or .160/.180 if using a power adder @ the very bottom of the pocket @ the vertical wall corner!
alkyal is offline   Reply With Quote
Old 11-22-2010, 05:58 PM   #14
BlackNotch85
BlackNotch85's Avatar
These are BAD ASS heads. I have been 5.24 @ 133.96 3150lbs, 275 radial in the 1/8 on a 275 shot of spray. I ran the same time with the Brodix 10X heads but need to spray 325 to get the same ET. That is the closest comparison I can give you. There is a lot more left in that setup, but I'm in the middle of building a procharged setup and havent wanted to get too agressive and hurt anything
Take alkyal advice and def check the valve pockets. We had to touch up the valve pockets in my motor.
You should have no problem getting into the teens, let alone the 20's once you get the combination figured out.
Thanks to Jason Gatlin @ Automatic Transmission Factory (ATF) and the whole crew Danny, David, Patrick, and Doug www.atfspeed.com, Procharger, Diamond Pistons, DoubleAAPerformance (www.doubleaaperformance.com) Jason Eckard @ BRE, Speedwire, The Brake Man, S&E Performance, Stainless Works SW Army Member, TRZ Motorsports and most importantly my crew.
Email me at SEAN@X275.net
7.03 @197 on 275's
405 cu in SBF with Procharger F1X
RIP COOPS
BlackNotch85 is offline   Reply With Quote
Old 11-22-2010, 06:09 PM   #15
7secondmalibu
7secondmalibu's Avatar
I've had a set on my car the last few years. I've been 7.82 at 180mph at 3400lbs. I made some changes to go faster, 7.8-1 compression changed to 9.5-1 compression, better intake manifold, etc...
Unfortanatly, lifter failure put me out for a little while. Bob Williams is a great guy to work with.
Special thanks for helping me rebuild:
ScottRodFab.com
TRZMotorsports.com
Gressmanpowersports.com
Tubingjon.com
JR Racecraft
PM me for Laser Etched Chassis Tags.
7secondmalibu is offline   Reply With Quote
Resources saved on this page: MySQL 1.03%
