long version of AC Delco PF48 oil filter - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > LSX, Mod Motor and Gen III Hemi Tech
Old 11-13-2010, 11:46 AM   #1
dwill73
Default long version of AC Delco PF48 oil filter
Is there a long version of the AC Delco PF48 filter in Wix or Mobil 1? If so what are the part numbers?
dwill73 is offline   Reply With Quote
Old 11-13-2010, 02:12 PM   #2
Formulized94
Formulized94's Avatar
Default Re: long version of AC Delco PF48 oil filter
Pick one up for an 01 or 02 5.3 suburban. I have one on my truck but don't know the number.
Formulized94 is offline   Reply With Quote
Old 11-13-2010, 03:02 PM   #3
stage20
Quote:
pf52 is the # you are looking for, but i dont know if the 48 shares the same threads.
be cautious when installing.
pf 46 is the short version of the 52. never messed with a 48.
TJ
88 iroc-z/28 408 LSx
all the good stuff.
05 2500HD 6.0L
one hauls, one hauls @$$!
CHP May 2011 feature
http://www.chevyhiperformance.com/fe...aro/index.html
stage20 is offline   Reply With Quote
Old 11-13-2010, 04:32 PM   #4
studderin
studderin's Avatar
just got a few from napa today, didn't see any of the better older delcos anymore that were easier to find. Most are cheap junk now
http://www.yellowbullet.com/forum/sh...d.php?t=294125
looked it up for a 99 sill.. found the longer one
1522 napa gold/WIX
New Era Performance
studderin is offline   Reply With Quote
Old 11-13-2010, 06:52 PM   #5
JonZ
Member
Pullin gears
JonZ's Avatar
PF 63 is the new, longer version of the 48. Dealership will have it for about $9. Havent found a true cross reference to date.
JonZ is offline   Reply With Quote
Old 11-13-2010, 08:06 PM   #6
dwill73
Have not confirmed yet, but I've read Mobil 1's part number is M1-212. This filter is suppose to be 1 inch taller then the M1-113 and PF 48.
Old 11-14-2010, 12:53 PM   #7
shortdog
Burnout box
shortdog's Avatar
Quote:
Originally Posted by studderin View Post
1522 napa gold/WIX
This is the filter that's even preferred over the K&N long? I see it's cheaper also.
99 Z28 A4
Nitrous 347
shortdog is offline   Reply With Quote
Old 11-14-2010, 04:09 PM   #8
stage20
wix owns!
TJ
all the good stuff.
05 2500HD 6.0L
Old 11-14-2010, 07:30 PM   #9
Formulized94
Quote:
Originally Posted by stage20 View Post
wix owns!
this
Old 11-14-2010, 08:07 PM   #10
Tally TransAm
Member
Pullin gears
Tally TransAm's Avatar
carquest should be 85522
i stick with wix stuff
Tally TransAm is offline   Reply With Quote
Old 11-14-2010, 08:19 PM   #11
JL Performance
Napa gold (made by wix) has one, the one for a 6 litre truck is about an inch longer then a standard f body filter. And they are the same thread.
JL Performance is offline   Reply With Quote
Old 11-15-2010, 01:01 AM   #12
ShorTuning
LSXTTFMF
Pullin gears
I've been using the PF-63 on mine for a long time. They can be found at Wal-Mart for under $5. They recently changed part numbers to a PF-63E, don't know if they are good filters or not but I change mine so often it shouldn't matter anyway's. I like the taller/longer filter's better due to the increase flow they can support and the extra volume.
James Short
ShorTuning is offline   Reply With Quote
Old 11-15-2010, 10:42 AM   #13
dwill73
Quote:
I called the number on the Mobel 1 website and was told the M1-212 oil filter is the longer version of the M1-113, Napa Gold 57060, and the AC Delco PF-48 oil filters. The M1-212 is the same size as the AC Delco PF 63 which are about 1 inch longer then the rest. The Mobil 1 M1-212 oil filters are only sold in certain areas as of now.
Old 11-15-2010, 09:10 PM   #14
stage20
Quote:
compare an E suffix with an older stock regular one and they are night and day just by looking at them.
i need to go buy one and just cut one apart. i be there is half the media in the new ones vs the older filters. if its the same amount, its surely not the same quality.
TJ
all the good stuff.
05 2500HD 6.0L
Old 11-16-2010, 12:38 AM   #15
ShorTuning
LSXTTFMF
Pullin gears
After reading all this I'm gonna probably swap to a WIX filter just cause they are proven. I used to use the Napa or WIX filters but switched to the ACDelco because they are conviniently in Wal-Mart. Guess I'll have to start going to Napa for my filter's at least.
James Short
Resources saved on this page: MySQL 1.02%
