66 chevelle suspention set up - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 11-13-2010, 09:54 AM   #1
STEVEG
Launchin
STEVEG's Avatar
Default 66 chevelle suspention set up
i have a 66 chevelle and want to know the best set up to bolt on i only want to buy stuff once.i would like to be able to run 10.0s with it. i just want to hear from you guys on what to do.also i do want to drive it on the street.i dont have any peices yet so i am starting from scratch.
STEVEG is offline   Reply With Quote
Old 11-13-2010, 11:02 AM   #2
1QuickBird
1QuickBird's Avatar
Default Re: 66 chevelle suspention set up
TRZ, hands down. They have everything you need for a A body, I would re-bush the front suspension with good energy suspension bushings. Put a decent shock up front, then get the adjustable rear control arms and anti roll bar from TRZ. Along with Strange Double adjustable shocks. You will never have to buy anything again.
WWW.LEGENDRACINGENT.COM
https://www.facebook.com/LREhorsepower
Midwest Muscle Car Specialists
High Performance engine builders
Induction Solutions Midwest dealer
1QuickBird is offline   Reply With Quote
Old 11-13-2010, 05:50 PM   #3
STEVEG
Launchin
STEVEG's Avatar
can i run the arb on the street? also what shocks on the front?
thanks for the info
Old 11-13-2010, 06:09 PM   #4
1QuickBird
1QuickBird's Avatar
Ya know, I've never run one on the street. I don't see why you couldn't. I'll let someone else with experience chime in on that.
Front shocks, you could go with a 90/10 comp engineering. Or a 3 way adjustable comp engineering, those would both be pretty in-expensive. Or you could put a simple single 12 way adjustable strange or Qa1 in the front. It definitely is not as crucial as the rear is. Also might need travel limiters in the front at some point possibly.
Old 11-14-2010, 03:53 PM   #5
STEVEG
Launchin
STEVEG's Avatar
so in the rear you are just putting replacing everything with stronger stuff, not doing any relocating? do you just change the IC with ride height? what is the desired pinion angle?
Old 11-14-2010, 07:40 PM   #6
Gary Abbey
Gary Abbey's Avatar
I have a customer with a 69 chevelle,they were hoping for 9.80's. How 9.69 sound instead. TRZ upper and lower A-arms,Qal coil overs in the front and Affco double adjustable on the back,with a little more shock tuning im sure we can get the 60's down and upper 9.50's.
Gary Abbey is offline   Reply With Quote
Old 11-14-2010, 08:46 PM   #7
onebadd66
Spooled up
onebadd66's Avatar
I have an arb on my 66,and no issues what so ever.I also have QA1 dbl adjst in front,but switching to Afcos this winter.Car rides fine on the street.
onebadd66 is offline   Reply With Quote
Resources saved on this page: MySQL 1.08%
