RENEGADE NEWS UPDATE - Page 3 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 11-09-2010, 09:23 PM   #31
ozone eater
ozone eater's Avatar
Default Re: RENEGADE NEWS UPDATE
Quote:
Originally Posted by Mr Z View Post
Milans OLS rules,
1/8 Mile, Heads Up, .400 Pro Tree, 32 Car Field, Sportsman Ladder, Lane choice goes to higher qualifier first round, and then the faster car from previous round.
Rear Tires
29.5" x 10.5 non W or 315 drag radial or smaller
Front Chassis/Suspension
Stock front frame rails and suspension required. Aftermarket control arms and bushings allowed as long as they bolt in stock locations. Rack and pinion steering allowed. Aftermarket coil over shocks allowed and aftermarket direct replacement struts are allowed, but must bolt in stock location.
Aftermarket bolt in sub-frame allowed. Must bolt in unaltered stock OEM mounting locations. OEM suspension configuration required. These bolt on subframes must be from a manufacturer with designated company part numbers and must be produced for the vehicle they were designed for from the manufacturer.
Rear Chassis/Suspension
Any type rear suspension allowed. Firewall must be retained and in stock location.
Engine
Any engine combination allowed. Motor plates and solid mounts allowed. Mufflers required for all cars except turbocharged entries. All nitrous bottles to be safety vented pop off to outside the vehicle.
Transmission
Any type automatic or OEM manual transmission allowed.
Weights
SB/BB N/A No Weight Limit
SB NOS 2500 lbs
BB NOS 3100 lbs
SB Turbo 3100 lbs
SB Twins Supercharger/Turbos 3150 lbs
SB Supercharger 3100 lbs
BB Supercharger 3200 lbs
BB Single Turbo 3200 lbs
BB Twins Supercharger/Turbos 3250 lbs
Leaf Springs - Subtract 100lbs
I think the weight should be 3000# across the board for simplicity , just my 2cents.
it is a very competitive class up there. watched and ran it. great both ways. 1/8mi is absolutely the way to go. cant wait!
i'm mike barran and i approve this post.
yes i can, and yes we can.
ask not what mike barran can do for you but what you can do for mike barran
Follow my race team on facebook at mike barran racing
ozone eater is offline   Reply With Quote
Old 11-09-2010, 09:53 PM   #32
BONDOBOB
Launchin
BONDOBOB's Avatar
Tom, i might be interested in doing some sponsorship for the class
please give me a call at my shop to discuss it further
Bob
Bobs Performance Fabrication LLC
419-927-4570 9 am to 8 pm
www.BobsProFab.com
WD For :
Strange Engineering
FK Bearings
AFco Racing
Sander Engineering Wheels
chromoly tube front steer k members for A B and E body mopars
custom chromoly cages / 4 link and ladder bar installs / mini tubs
mopar super stock chromoly front end parts and lighten K frames
BONDOBOB is offline   Reply With Quote
Old 11-09-2010, 10:33 PM   #33
Leavinsteven
REBUILDING
Leavinsteven's Avatar
Thank you Mr. Z.!
http://youtu.be/5L5h8pyAG6Q
Life is Drag Racing....
Everything else is waiting.
Leavinsteven is offline   Reply With Quote
Old 11-10-2010, 04:30 PM   #34
Little Z28
Slow Poke
Little Z28's Avatar
I'm with a few others, if the 8.90 deal needs cars, I'll run motor and try to run that number. If it is a full field, I may spray the crap outta the car and try to run some low 5's in the 1/8 to run OLS. Either way will be alot of fun. Don't worry, I'm 99% sure that the car is getting a wider rearend housing and smaller tires for next year!
Little Z28 is offline   Reply With Quote
Old 11-10-2010, 05:56 PM   #35
Tom Cowle's wife
Tom Cowle's wife's Avatar
PLEASE READ THE MATCO TOOLS OFFER IN THE "RENEGADE DISCUSSION" THREAD AND LEAVE COMMENTS THERE.
THANKS
RPM MAGAZINE/LUCAS OIL WAR BY THE SHORE
AUG 5th & 6th 2016
www.warbytheshore.com
RENEGADE RACING ASSOCIATION
2016 Schedule TBA
www.renegaderacingassociation.com
Tom Cowle's wife is offline   Reply With Quote
Old 11-11-2010, 09:19 AM   #36
Tom Cowle's wife
NEW SPONSOR NEWS
CHUMLEY MOTORSPORTS http://chumleymotorsportsohio.com/ has signed on to be a partner AND a 2 car participant in the 2011 racing season. CHUMLEY MOTORSPORTS is a successful custom automotive repair/service/upgrade facility located at 6470 Belmont Ave. in Girard, Ohio. You can expect full dearship service from ASE certified automotive technicians without the high price. From an oil change to a suspension change CHUMLEY MOTORSPORTS has you covered. Check out the website or call Tim Chumley 330-501-0781 for additional details or to schedule an appointment.
AUG 5th & 6th 2016
2016 Schedule TBA
Old 11-11-2010, 09:26 AM   #37
fastbill73
Member
Pullin gears
fastbill73's Avatar
I met them 5 years ago nice guy. Big ford freak
fastBill73
fastbill73 is offline   Reply With Quote
Old 11-11-2010, 09:39 AM   #38
koolrayz
Moderator
koolrayz's Avatar
On the OLS class I think you need to change the DR size from 315 and smaller to 325 and smaller. There are some guys who cant fit a 30" tire like the 315/60R15 and run the 325/50R15. It is a lesser tire and will avoid some confusion I have seen at other events this year. Case in point I have a friend with a vette and he cant fit the 30" tire so he runs the 28" tall 325. There are no 30" tall drag radials wider than the 315 that are worth a shit. Just want to get the biggest car count for the new class. I also may run in the OLS to help get it kicked off. If we can adapt the tire change I would bet my buddy would bring his vette also.
X275 ERL motor, Midwest Chassis Suspension, Garrett 88mm turbo, AEICNC, Shearer fabrications, Driveshaft shop, All Pro heads, RPM transmission, PTP performance, Big Stuff 3
Like WWW.facebook.com/koolrayzracing
koolrayz is offline   Reply With Quote
Old 11-11-2010, 09:50 AM   #39
jonesy1
jonesy1's Avatar
Rumor has it the higher ups at RRA are thinking about letting chassis cars compete next year!!!!!!!!!!!!!!!! J/K!!!!!!!!! Sorry Tom I had to stir the pot!!!!!!!!!! LOL !!!!!!!!
4.27 @ 170 MPH
6.67 @ 210 MPH on 2 guns with my OLD motor. The new one is going to be a different story.
Thanks to:
Davis Race Cars
Abruzzi Transmission & Converters
Dave Bayus
Hyatt Racing Services
L and M Motorsports
Buck Racing Engines
jonesy1 is offline   Reply With Quote
Old 11-11-2010, 10:03 AM   #40
Tom Cowle's wife
Quote:
Ray, the 325/50r is accepted in this class. The 315/60r is the largest diameter radial accepted. sorry for the confusion.
We are trying to make a home for the displaced radial guys and the milan rules posted make the most sense without making a 'radial only' class.
AUG 5th & 6th 2016
2016 Schedule TBA
Old 11-11-2010, 03:15 PM   #41
koolrayz
Moderator
koolrayz's Avatar
No problem I think it is a GREAT plan.
Old 11-11-2010, 05:06 PM   #42
viperakron
Member
Pullin gears
Quote:
How we gona weigh these cars?
viperakron is offline   Reply With Quote
Old 11-11-2010, 05:07 PM   #43
viperakron
Member
Pullin gears
THANKS
Correction the offer is from Wright Tool, not Matco.
Old 11-11-2010, 05:15 PM   #44
Tom Cowle's wife
Quote:
we have scales to use
AUG 5th & 6th 2016
2016 Schedule TBA
Old 11-11-2010, 05:21 PM   #45
gerry penn
doing it right
gerry penn's Avatar
ray blow me im not switching from 29.5 to a 28 or from a 315 to a 325 cause your bitch ass cant make it fit
Team Blankenship & penn to the top
gerry penn is offline   Reply With Quote
Resources saved on this page: MySQL 1.03%
