Is there an easy way to strip undercoating?? - Yellow Bullet Forums
Old 11-06-2010, 08:09 AM   #1
lurtch
Member
Pullin gears
lurtch's Avatar
Default Is there an easy way to strip undercoating??
I have been using a wire wheel but it is taking forever. Just wondering if anybody new a product or an easier way to remove???
lurtch is offline   Reply With Quote
Old 11-06-2010, 08:15 AM   #2
forcd02
forcd02's Avatar
Default Re: Is there an easy way to strip undercoating??
there are several diff types of undercoating, respond to diff types of products-i havent found a miracle product, just hard work-on flat surfaces, i use a torch and putty knife, sometimes wipe with gasoline afterwards-sometimes oven cleaner will work, but depends on under coat-thicker stuff seems to come off easier than thinner stuff-be interesting to see what works for others
when your credit cards are max\'ed-call and raise the limits
forcd02 is offline   Reply With Quote
Old 11-06-2010, 08:56 AM   #3
racecar77
racecar77's Avatar
It's messy no matter how you do it. What i did was scrape the heavy, thick stuff off. Then I sprayed a small area (1 or 2 square feet) with Zep Big Orange degreaser and wipe with a rag. Gasoline works also, but the fumes aren't good. Takes it to bare metal pretty easy. You need to have a lot of rags and a lot of patience.
racecar77 is offline   Reply With Quote
Old 11-06-2010, 09:16 AM   #4
5.0Cammer
5.0Cammer's Avatar
Get some paint or varnish stripping gel.
5.0Cammer is offline   Reply With Quote
Old 11-06-2010, 09:29 AM   #5
badss540
badss540's Avatar
3 weeks on my back with lots of wire wheels and 2 drills to strip and redo the 69Camaro..keep at it
[SIGPIC]
badss540 is offline   Reply With Quote
Old 11-06-2010, 09:38 AM   #6
72 Dart
Pre-Staged
we did a couple of cars up here by dry ice blasting ,it was amazing it like froze the undercoat and it would fall off ,clean up was also easy just shoveled it up , highly recomended!!!
72 Dart is offline   Reply With Quote
Old 11-06-2010, 09:39 AM   #7
Kevin Zaske
Eddie Haskell
Kevin Zaske's Avatar
Quote:
X2, I looked like a racoon for a while
Kevin Zaske is offline   Reply With Quote
Old 11-06-2010, 09:47 AM   #8
gray86hatch
gray86hatch's Avatar
I used brake parts cleaner on my car.
Tim
86 mustang 3000lb
454 FTI LS3 Mast intake FTI hyd roller Holley EFI 275 MT e85
9.24 143.58 1.33 3.73 5.84 116.21
HR Drag Week 2013 ss-BB-NA Winner
LSX here we come
with help from
My wife and daughter's 2
www.flowtechinduction.com
www.boozebrothersracing.com
gray86hatch is offline   Reply With Quote
Old 11-06-2010, 09:49 AM   #9
dumbassprick
Member
Pullin gears
dumbassprick's Avatar
For flat panels I don't want to warp with the propane torch / putty knife technique, I use a paint stripper gel.
dumbassprick is offline   Reply With Quote
Old 11-06-2010, 09:50 AM   #10
WeDgiE
WeDgiE's Avatar
I did a 67 charger on time with a torch and as scraper! man is that a shitty job!
WeDgiE is offline   Reply With Quote
Old 11-06-2010, 09:50 AM   #11
MercilessMike
MercilessMike's Avatar
i used a torch to warm it up, then scraped off like butter
MercilessMike is offline   Reply With Quote
Old 11-06-2010, 09:51 AM   #12
Tom Cowle's wife
Tom Cowle's wife's Avatar
Quote:
dry ice rocks
RPM MAGAZINE/LUCAS OIL WAR BY THE SHORE
AUG 5th & 6th 2016
www.warbytheshore.com
RENEGADE RACING ASSOCIATION
2016 Schedule TBA
www.renegaderacingassociation.com
Tom Cowle's wife is offline   Reply With Quote
Old 11-06-2010, 09:51 AM   #13
Jamie Gelting
Burnout box
Jamie Gelting's Avatar
If you don't want to use a torch, get a heat gun and a putty knife to get the bulk of and almost any solvent after that can get off the residue.
Jamie Gelting is offline   Reply With Quote
Old 11-06-2010, 10:52 AM   #14
1970ls
Aviation Section
1970ls's Avatar
Quote:
This is correct, there are several types, is yours still pliable or hard as a rock from age? Chemicals for the soft and the best thing for hard is a device called a needle scaler, it is run by air pressure and has several small round rods on the end for cleaning welds, it will tear up undercoating and leave a nice surface for prime and paint, costs less then $75.00 but you will need an air compressor to run it. Dave
Big Jet Crewmember, heavy drinking cured my fear of flying and made me a better person!, hold my Scotch and watch this!
Si Vis Pacem, Para Bellum
64'G/P, 421/Tri-Power A/C 4 Spd.,
73'T/A, 461 A/C 4 Spd.
Part of the Tribe!
1970ls is offline   Reply With Quote
Old 11-06-2010, 10:52 AM   #15
pdq67
I figure that Methylene Chloride IF you can get it will cut it off in a NYM!!
pdq67
pdq67 is offline   Reply With Quote
