06 Dodge Truck + Dead Battery = Major Electrical Problems HELP - Yellow Bullet Forums
Old 10-20-2010, 10:21 PM   #1
Caddy Daddy
Launchin
Caddy Daddy's Avatar
Default 06 Dodge Truck + Dead Battery = Major Electrical Problems HELP
06 Dodge Truck + Dead Battery = Major Electrical Problems My partner left the radar detector plugged in for over a week in our work truck and the battery died. He jumped it off and it started fine. He drove about an hour and picked me up and I noticed all the dash lights were on and the transmission would not shift. The transmission stays in drive and will not kick down or go into OD. The four wheel drive will not engage. We took the truck to a local mechanic and he couldn't get the scanner to sync with the truck. We took it to a local dealer and a few hours later they call and want us to take it to another dealer since they can not figure out whats wrong. Said one of two modules may be bad and there scanner was not able to read accurately. WTF is wrong with this truck? Anybody got any guesses? I'm stumped!
Caddy Daddy is offline   Reply With Quote
Old 10-20-2010, 10:27 PM   #2
mj79stang
Member
Pullin gears
Default Re: 06 Dodge Truck + Dead Battery = Major Electrical Problems HELP
there's has to be more to it than a dead battery. did he jump it with the cables reversed? does it have a new battery? get a new battery before anything if you havent already. voltage problems can cause some crazy stuff, though.
mj79stang is offline   Reply With Quote
Old 10-20-2010, 10:50 PM   #3
Caddy Daddy
Launchin
Dealer asked if he jumped it with cables reversed. He said he didn't and if he did, wouldn't sparks have tipped him off it was wrong? The truck started and has started every time since. Battery is original to the truck and mileage is 55,000+- We removed cables and tried to clear codes and re-boot and still have all and I mean all the lights and warnings lit on the dash. I and my buddy the mechanic have never seen anything like this.
Old 10-20-2010, 11:15 PM   #4
Diddly
Launchin
Diddly's Avatar
I'm sure you probably tried it but if not when the battery is unhooked touch the two cables together.
Diddly is offline   Reply With Quote
Old 10-20-2010, 11:23 PM   #5
Mike Thompson
"Darkness"
Mike Thompson's Avatar
Take it to a real dealer. What kind of dealer says take it to another dealer? A worthless one!
We have one up the road that pulls the same shit.
1.19 4.81 at 146.98 mph Ultra 275
Mike Thompson is offline   Reply With Quote
Old 10-20-2010, 11:27 PM   #6
phantomracer
having fun
phantomracer's Avatar
Quote:
x2
this space for rent
phantomracer is offline   Reply With Quote
Old 10-20-2010, 11:38 PM   #7
Mike Thompson
"Darkness"
It sounds like it may have lost BUS communication causing the trans to go into limp mode. The TIPM or underhood fuse box could have a issue. This is not uncommon. Smell it. Sometimes they smell like they once got hot when they fail.
It also could be something else. Any dealer with a good drivability guy can figure it out.
Old 10-20-2010, 11:41 PM   #8
Monte Smith
The nitrous guy
If the battery was that dead, it is possible that the jump start cleared the computer. Is the odometer working???? If not, it may need the VIN reprogrammed in the computer. If thats the case, I'm surprised it will even run.
Monte
Monte Smith
Motorsports Technical Representative
Nitrous Oxide Systems
www.montesmithperformance.com
gtxmonte@msn.com
ph. 256-783-3418
Monte Smith is offline   Reply With Quote
Old 10-20-2010, 11:42 PM   #9
phantomracer
having fun
Quote:
Monte
so theres no eprom involved there?
or is it just cleared of the access to that eprom?
this space for rent
Old 10-20-2010, 11:52 PM   #10
Mike Thompson
"Darkness"
A 06 ram has a NGC controller. Any DTC it has will not be cleared from a battery disconnect. The vin is also stored in a few other modules. TIPM, PCM,and WCM all store the vin in this vehicle if I'm not mistaken.
There may be more to this story than we know or its possible the dead battery issue is not even related. Chrysler products have issues with modules and wireing.
I wonder if the cluster displays a "no bus" message with the key on or while running.
Old 10-21-2010, 01:06 AM   #11
jsj372
jsj372's Avatar
Quote:
Originally Posted by Mike Thompson View Post
A 06 ram has a NGC controller. Any DTC it has will not be cleared from a battery disconnect..
Not true, stored codes will clear with a battery disconnect. Sounds like he has active faults. Stored faults will clear with a battery disconnect, active will not.
The best thing for this guy to do is get in contact with a dealer that knows how to use a STAR Scan or Star Mobile, check the vehicle Network Topology and see if any modules are offline. Then have them run a vehicle scan report and try to pinpoint where the issue is. I'm sure there is YB member who can analyze the Vehicle Scan Report
Team Blevins Motorsports
Southern Motors
www.southernmotors.com
Gilsbach Racecraft
www.gilsbachracecraft.com
Outlaw Photo
Wired 4 Speed
jsj372 is offline   Reply With Quote
Old 10-21-2010, 01:14 AM   #12
phantomracer
having fun
sooo what your saying is..............
its most likely not a bad carb?????
holy hell why do companies make cars so dependant on electronics now!!
pretty soon cars wont be able to run without booting up first
this space for rent
Old 10-21-2010, 01:47 AM   #13
chevythunder
Launchin
with the technology out now, think of whats in the works for 5 years from now. with throttle by wire, brake by wire, lane managment, in not too long cars will be driving them selves.
chevythunder is offline   Reply With Quote
Old 10-21-2010, 01:52 AM   #14
phantomracer
having fun
Quote:
and hopefully fixing themselves..
someone asked to me to take a look at theyre hybrid honda the other day
i told em now fucken way am i putting my hands on that shit-im not gonna be shocked to death by a car
this space for rent
Old 10-21-2010, 07:45 AM   #15
Caddy Daddy
Launchin
I did not get back in town in time to pick up the truck yesterday. I'll pick it up today and try to decide what to do or where to take it after we speak with the local dealer. The local dealer is a multi brand dealer selling mostly GM vehicles and Dodge Trucks.
Got my curiosity peaking about suggestions of touching the cables together after battery disconnect. What would this do to help solve the problem? Thanks for the suggestions and replies.
Resources saved on this page: MySQL 1.03%
