Best Electric Water Pump - Yellow Bullet Forums
Old 10-20-2010, 11:19 AM   #1
69camaro434
Default Best Electric Water Pump
Which water pump is better Meziere, CSR or something else for a SBC?
69camaro434 is offline   Reply With Quote
Old 10-20-2010, 11:42 AM   #2
footbrake racer
Pre-Staged
footbrake racer's Avatar
Default Re: Best Electric Water Pump
you don't need an electric water pump. A Moroso water pump drive kit will do all you need. Use one for nearly 20 years racing every weekend and running in the 9's.
But if you've got ~ $300 burning a hole in your pocket and have to have one, buy a Meziere
footbrake racer is offline   Reply With Quote
Old 10-20-2010, 11:53 AM   #3
slowstang
slowstang's Avatar
Quote:
if you street drive it get the 55 gph not the standard 35.the meziere i had was new and leaked right out of the box...i have an aerospace on my current engine and so far so good.
slowstang is offline   Reply With Quote
Old 10-20-2010, 11:56 AM   #4
footbrake racer
Pre-Staged
the 55GPH pumps will NOT pump that capacity unless your hoses are the same diameter as the pump's inlet and outlet
Old 10-20-2010, 01:48 PM   #5
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
I used to drive on the street all the time with that little Moroso electric motor spinning my stock water pump. Never lost a belt. First motor lasted 4 years or so.
I would not buy a CSR pump, had two, got rid of both! Have a Mezier but see no difference in cooling between it and the stock pump driven by the Moroso motor. Looks cleaner, that's all. Costs a lot more too! If the Moroso motor pukes it is a few minutes to change and no mess!
Mike Beck is offline   Reply With Quote
Old 10-20-2010, 01:57 PM   #6
yeti
A motor that's too weak to pump its own water needs some serious help. LOL
yeti is offline   Reply With Quote
Old 10-20-2010, 02:03 PM   #7
slowstang
slowstang's Avatar
we tried this with a bbc and it just sucked on the street,switched to meizere and problems went away after we fixed the leaky new pump
Old 10-20-2010, 02:26 PM   #8
502SS
502SS's Avatar
I must be the only cheap one here... LOL
I have a Proform $150 35GPH pump on mine. It's worked flawlessy for at least 4 years now, gets driven a lot on the street, as well as 5MPH driving on the hot ass sand dunes. Never had an issue
502SS is offline   Reply With Quote
Old 10-20-2010, 02:29 PM   #9
69camaro434
Good idea, do I have to relocate my alternator? It is on passanger side head. I would like to get one of those alt. bracket kits that relocates it lower, but I forgot the name of the company.
Old 10-20-2010, 03:07 PM   #10
footbrake racer
Pre-Staged
no need to relocate your alternator to mount/run Moroso's "universal" water pump drive kit.
Cheap, easy to install and does the job well. Mine drove the factory 7 blade steel clutch fan for nearly 2 decades.
Old 10-20-2010, 09:33 PM   #11
dover1320
dover1320's Avatar
Powermaster. Nice kit!
dover1320 is offline   Reply With Quote
Old 10-20-2010, 11:54 PM   #12
slowstang
slowstang's Avatar
Quote:
x 2 i just mounted a powermaster kit tonight,could get any easier
Old 10-21-2010, 12:31 AM   #13
NOVALOU
Member
Pullin gears
NOVALOU's Avatar
I use the Moroso electric motor as well, and a close friend of mine uses one also. I use to have a plastic fan mounted to my water pump, and between rounds trying to cool the engine down I only had to run one electric motor to run both fan and pump. Never mind the arrows.
NOVALOU is offline   Reply With Quote
Old 10-21-2010, 06:40 AM   #14
bruce69camaro
jus sayin pot stirrer...
bruce69camaro's Avatar
I got a Moroso drive on my car plus I use an alternator bracket from this place: http://www.alangrovecomponents.com/
He makes some good brackets.
Bruce
My homeland security
Those who think they know it all, have no way of finding out they don't.........
bruce69camaro is offline   Reply With Quote
Old 10-21-2010, 07:34 AM   #15
Real McCoy
Real McCoy's Avatar
I use to run the Moroso drive on the stock pumps with a aluminium flex fan to cool my race cars. They worked well for many years and my old Nova my brother owns now still has one on it. I bought a CVR about 10 yrs ago. It has done well and never given me any issues so far.
Real McCoy is offline   Reply With Quote
