The diesel engine as a viable performance option - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 10-16-2010, 09:14 PM   #1
cOMP461
cOMP461's Avatar
Default The diesel engine as a viable performance option
First Iím primarily a gas racer; I cut my racing teeth as a Competition Eliminatorcrew member, and racer. I get a woodie when I put my foot on the throttle of a 11,000 rpm small block.
I was stranded without a affordable and competitive engine program at the end 2001 season, after a fairly successfully 5 years of campaigning a D/ed with a Splayed valve V6. I stumbled in to the diesel performance world, and found it to be a new found passion.
The diesel engine development curve is where the gas world was 30 years ago. I speculated it would rapidly catch up, and itís coming along, there are a lot of inovatators in the diesel couminity .
When I first started with diesels, mentioning cylinder head and cam development was laughed at. They stated that boost would overcome it all. 6 years later the shop that I begged to do my head, and build a sheet metal manifold has a 3 month waiting list to get a head and manifold.
So is the diesel engine as a viable power plant for a muscle car, bracket car, or even race car .
I donít mean the typical smoke belching engine, but well refined engine programs. The diesel engine has made huge gains in this arena with the advent of electronic common rail high pressure with 20,000 to 30,000 psi fuel systems.
With the CR systems you can tune around destructive peak cylinder pressure as the engine goes thru peak torque. The solution to this before, on mechanical fuel systems was to reduce compression ratio, killing low eng cylinder pressure, and this worked on all out engines, but killed bottom throttle response. These lack of bottom end , also effected the AR selection on turboís
The advent of cylinder heads that in effect doubled air flow (Cummins stock 144 CFM ) ( Duramax stock 140 CFM ) to both heads flowing close to 250 CFM on streetable heads and 300+ CFM on all out race heads.
Cam design, which I made one of my pet projects, was way behind. The major player would grind BBF RV grinds on the Cummins 54.5 mm core, the events were to big , and with way to much overlap
Problems was the turbo diesel engine cores were on at best 102 to 106 LSA and the overlap was one of the greatest no noís on a diesel . The diesel engine has little scavenge with 1.2 to 1.5 boost to turbine inlet pressure ratioís . The tipical street cams would open the intake 10 ATDC and close at 2 or 3 ABDC . I use a cams that is 230 230 on a 116 in at 116 . and do it on 60 mm cores
So to the latest in Chevy Duramax engine for a street engine
First forget the huge injectors, twin pumps and compound turboís. A stock short block Duramax with a good cylinder head, and cams program will breath well, and make 600 hp and 1000 ft lbs of torque, and rev to 5000+ rpms and last forever. The great part about doing the heads and cam, on a entry level engine is, that now this good breathing engine will make a good power curve at low boost levels. The great part is no need for an intercooler at this boost level. Just use Water injection on the street.
This engine in a muscle car will run good, smoke free, and get 40+ MPG on # 2 diesel fuel. Go ahead and put a good set of rods in the motor and the hp level is close to 1100 hp with nitrous , which doubles as an intercooler.
Here are some pictures of the NX Mustang and My Dragster and their engine programs based around the Dmax diesel engine.
Oh and I love this forum, the knowledge level is humbling.
Competition Eliminator D/ed , C/ed
Texas Mile
http://www.facebook.com/COMP461
G.M. Racing ChevyDmax clean Diesel Top Dragster
It is not necessary to build a swimming pool to determine that a bowling ball won't float." .....Zora Arkus-Duntov
cOMP461 is offline   Reply With Quote
Old 10-16-2010, 09:29 PM   #2
gryphon68
gryphon68's Avatar
Default Re: The diesel engine as a viable performance option
Are you at a point on the Mustang or Dragster where the available gearing is limiting the 1/4 mile performance??
Beebe Motorsports
gryphon68 is offline   Reply With Quote
Old 10-16-2010, 10:01 PM   #3
cOMP461
cOMP461's Avatar
No not really, the engine in race trim will turn up to 6000 rpms the real sweet spot is between 4500 and 5500. The engine will make a flat torque curve from all the way down to 2500. Down there the peak cylinder pressure is destructive.
I run a PowergGlide with a GearVendors and a Coan Mega convertor.
Texas Mile
Old 10-17-2010, 09:13 AM   #4
cOMP461
cOMP461's Avatar
here is the new manifold on the NX Mustang
dropping the pin back to a 1.156 .300 wall pin saves 125 grams . This JE piston for the Dmax saves another 200 grams
we drop the rod throw back to hemi , and take the stroke to 4.00 making any inexpensive 427 cid engine.
here is a twin turbo 68 Z28 build
Texas Mile
Old 10-17-2010, 09:19 AM   #5
jason418
Spooled up
jason418's Avatar
got any vids of them on the strip? very cool cars!!!
jason418 is offline   Reply With Quote
Old 10-17-2010, 02:47 PM   #6
cOMP461
cOMP461's Avatar
here are a few
http://www.youtube.com/watch?v=3ziBz...layer_embedded#!
http://www.youtube.com/watch?v=gt8OP...eature=related
http://www.nitrousexpress.com/videos.php
here is one of Project X diesel , don't laugh
http://www.youtube.com/watch?v=r65SH...eature=related
Texas Mile
Old 10-17-2010, 02:58 PM   #7
Greg2
Way cool! Thanks for sharing something different.
Accurate information is expensive, rare and difficult to find.
Greg2 is offline   Reply With Quote
Old 10-17-2010, 03:33 PM   #8
CROWER
CROWER's Avatar
billet crank and rods yet ? can help if you need
CROWER is offline   Reply With Quote
Old 10-17-2010, 03:34 PM   #9
cOMP461
cOMP461's Avatar
I'm new to YellowBullet , so I don't want to get on the wrong side by posting too much , so as long as it ok , Iíll keep posting more pictures of some of my builds
Here is the first diesel to race in an NHRA National event , I ran the first 8 second pass anyone had ever done in any diesel , and did it on Sunday just before the final round of the proís 8.72 @ 154 .
I eventually got the truck to go 8.29 @ 167 in Vegas
Notice that the exhaust is clean , in a diesel itís just like a gas motor , lean is mean .
here is the motor on the Dyno 1157 hp with power from 4500 to 5500 over 1000.
here is a header for the Cummins that Pollydyne makes its worth about 30 hp on a 400 hp street truck
here is me wearing out a GT at Hot rod drag week , notice again no smoke , 8.30's @ 129 mph in a 6200 lbs truck and got 23 mpg on the trip
Texas Mile
Old 10-17-2010, 03:44 PM   #10
megajoltman
Member
Pullin gears
megajoltman's Avatar
Nice stuff
1969 Dodge Dart
2010 Dodge Ram CTD Mega Cab
1998 Dodge Ram 12V CTD 4x4 (toast)
megajoltman is offline   Reply With Quote
Old 10-17-2010, 03:44 PM   #11
cOMP461
cOMP461's Avatar
this is the side draft manifold that Greg younf at ZZ custom fam makes .
to port the cummins head you have to cut the intake off to even get to the ports .
Tommy at KPE making seats , for the Dmax , and the heads from ZZ .
and since this is YB here is my faverite picture of the intake manifold
Texas Mile
Old 10-17-2010, 03:57 PM   #12
cOMP461
cOMP461's Avatar
Quote:
you did the rods in the Mustang are yours , they are hemi big eng , and 1.156 pin .
I would like to have some that are designed for this size, and lighter. I am using Aluminum rods in the dragster .
I also need a short crank for the dragster 3.700 I need to rev it up and if you can't feed it air , no since in making it bigger .
The Mustang is a 4.00 stock crank and 4,125 bore 427 cid , its great on the street .
I have a set of heads that Chris Franks is doing at Frankenstein racing heads.
With a little wielding he is confident that he can get 300+ cfm of air.
Texas Mile
Old 10-17-2010, 04:39 PM   #13
cOMP461
cOMP461's Avatar
here is a finished picture of the heads on the NX Mustang
here is a stock piston cut for piston to valve , and coated .
notice the second piston, this is a JE , it has the open bowl design and it allows a lot better burn .
On a lower hp build, not only keep compression in , but will bump it to 18.5 to 1 . this give unreal throttle response on a 650 hp and below motor. it will not work great on big hp builds , but under no circumstances go under 16 to 1
here is the transmission on my Top Dragster
a Coan glide with a GearVendors
Texas Mile
Old 10-17-2010, 04:42 PM   #14
LBSRACING
Launchin
LBSRACING's Avatar
As a diesel mechanic I just flat out love them. Granted my race car is a BBF. I did indeed debated going into the diesel seem. You can make monster power out of them. Most people don't think they will go fast cause all they ever see them in is 6000+ lbs trucks. Next year we are going to start building our 7.3 Powerstroke land speed truck. Nice pics by the way.
LBSRACING is offline   Reply With Quote
Old 10-17-2010, 05:26 PM   #15
cOMP461
cOMP461's Avatar
the 7.3 would be great in LSR , it would run in A diesel truck, and that is a soft cass
NHRA has spec a diese engine in SS to run in GT/DT ar 12 bs per factory hp the engine is a 285 hp Duramax . the index is 12.85
Texas Mile
