sbc street strip/strip combo post - Yellow Bullet Forums
Old 09-30-2010, 09:43 PM   #1
yenkomike
Member
Pullin gears
yenkomike's Avatar
Default sbc street strip/strip combo post
i did a search and came up short so i thought id start one.
looking for street strip sbc combos. i meen real street cars full interior, pump gas , stock wheel well street cars . that can be driven . i dont meen on the highway but at leist to work and back and some cruise nights and car shows as well as some trips to the track. this is the type of car i build and like and so i thought id try it this way. thanks in advance.
yenkomike is offline   Reply With Quote
Old 10-01-2010, 12:45 AM   #2
67RS502
Member
Pullin gears
Default Re: sbc street strip/strip combo post
unless your building a heavy tank theres no reason you cant run 9s with a decent 23* sbc on pumpgas. Go with better heads and light wt. and some high 8s could happen, as it takes about 750hp @ 2800lbs to run 150mph, and theres a few here that have built pumpgas SBs that make that much or more.
67 camaro
pumpgas
420 - 641hp BretBauerHRcam 1.39, 9.79 @ 137.5
383 - 490hp 224/224HRcam 1.56, 10.77 @ 124.6
502 - 626hp 252/263HRcam 049s 1.44, 10.08 @ 132.7
62 Nova cruiser
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
67RS502 is offline   Reply With Quote
Old 10-01-2010, 02:39 AM   #3
jeff c
pig hunter
jeff c's Avatar
yenko, not sure if you want a 23* setup or step up to a little better head design but i have done both and run very well. the old nova i had was street driven full interior stock suspension with many many pumpgas engines, it was my test bed for engine combo's..you can run 9's with a 18* setup. 23* takes a lot more effort to push a normal 3500# street car into the 9's on pump gas.. with a little power adder you can make the maro fly.. i would do a large cid 420-434 pumpgas with airwolf's, rr allpro's, 220 allpro's, 235afr,245 afr, or step up to a set of rfd 18*, bmf 18*. caltrac, th400, 3.73 gear and your should be good to go.. i can run 8.40s with a very highly modifed 430+cid and a fogger running a 230 dart head that has way to much work, time and money into them but there 11 yrs old and do the job..the intake i used is a ported gm bowtie it had a ported super vic and ran the same numbers as the bowtie..4500 carb btw cool ride is it real??
sr-20 headed 4.60x3.70=492cid 2.49 per cid @ 9100rpm's
jeff c is offline   Reply With Quote
Old 10-01-2010, 03:00 AM   #4
ten5nova
Beer me!!
ten5nova's Avatar
My buddy's combo: 72' Nova, 355, GM crank & rods, speed pro forged pistons 11.5:1, Comp solid flat 250ish @ .050, not sure on lift, 215 Iron Eagles (old heads), Dart single plane, 750 Demon, MSD 6AL, 175 shot, with this set up it ran 11.4's with a cold bottle, and horrible conditions, really bad DA. I just sold him a set of AFR 210 Eliminators, he says the car is night and day now. Hoping to get the car to the track again some time next year with warm bottle, and better conditions, should go 10's pretty easy, even up here in this shitty DA. Car has full interior, 12 bolt with 3.73's, slappers, and 26x8.5 slick. When the weather is good, this car gets driven almost daily, for him to go to work and back is probably 40 some miles round trip. He has raced more than one ladder bar / big tire car, and beat all of them on the street. Hope this is a good example of what you are after Yenkomike....
ten5nova is offline   Reply With Quote
Old 10-01-2010, 07:38 AM   #5
yenkomike
Member
Pullin gears
yenkomike's Avatar
just wanting to see how other street car run and there setups. all motor.
thought id post mine as well. the camaro is going all street . the engine and trans from the camaro are going in my 68 chevelle 300 post.that will be driving next spring. both cars will weigh within 100 lbs of each other so et should be about the same once i get the traction .i only made a few passes with my 406 in the camaro the best being 1.55 60' 7.18 at 99mph 1/8 and 11.16 at 122
406
stock block,eagle crank and 6" rods,probe flat top pistons,stock track 1 215 cc heads,
isky 276/282 @.050 cam 640/640 lift 106 * installed at 103*icl,stock unported vic jr 950 hp,
1 7/8 headers i left the 400 th in the camaro and im running a 350th with my 5200 convertor, im still thinking about the rear gearing. 4.10 or 4.30. stock wheel well 28 by 11.5 et street. looking to get in the 10s when im done.thanks
Old 10-01-2010, 08:06 AM   #6
T-flow
T-flow's Avatar
Alittle stout for a pump gas street car. Cam in the 250's @.050 is more in line with a pump gas build but,port work to the heads, intake and a "Good" custom grind cam should get you there
T-flow
T-flow is online now   Reply With Quote
Old 10-01-2010, 04:04 PM   #7
jeff c
pig hunter
jeff c's Avatar
YENKO, i'm with t-flow on the cam. just a wee bit big on the @ .050 duration.
Old 10-01-2010, 04:45 PM   #8
racerE165
Launchin
racerE165's Avatar
reach out to SmallBlockNova whose Nova is a real street car,running pump gas and very impressive on the track.
Quote:
Originally Posted by Monty Mikho View Post
Ed I think you're a really smart guy. I believe you have a wealth of knowledge to share with everyone.
racerE165 is offline   Reply With Quote
Old 10-01-2010, 06:16 PM   #9
lun40119
I like IceCream
lun40119's Avatar
Joes car does run well..........working on a pump gas small block right now, for a 3600lb street car. 1050, 2970, Dart cylinder heads, and block, 402 inch, 272 duration cam with .849 net lift. Good luck bud.
Jake
Team Clueless
Optimize the Compromise...
Quote:
Originally Posted by Chris Uratchko View Post
Hell no, big blocks are for dump trucks!!!
lun40119 is offline   Reply With Quote
Old 10-01-2010, 06:56 PM   #10
jeff c
pig hunter
jeff c's Avatar
lun40119, could you keep me or us up to date on the build? sounds like a fun one...
Old 10-01-2010, 07:00 PM   #11
yenkomike
Member
Pullin gears
yenkomike's Avatar
thanks . ill try and find his combo and check it out. if i do anything to the engine it will be a cam change and port the intake to match the heads and go from there
ive been looking at that 255/263 duration vodoo cam i think its about right.
Old 10-01-2010, 07:01 PM   #12
jeff c
pig hunter
jeff c's Avatar
post the valve timing numbers @.050 yenko..
Old 10-01-2010, 07:21 PM   #13
lun40119
I like IceCream
lun40119's Avatar
Quote:
No doubt bud, it is the one that I posted the spin tron data from a while back. I will definately keep you in the loop. The only thing that matters to me is that it goes quicker than my last combo did.
When I say street car, I do intend on doing Drag Week with it. And driving it whenever the sun is shining.
Jake
Team Clueless
Old 10-01-2010, 07:24 PM   #14
jeff c
pig hunter
jeff c's Avatar
what if it's at night you can't drive it, sorry had too...... fwiw may name is jeff and i like ice cream too
Old 10-01-2010, 07:30 PM   #15
lun40119
I like IceCream
lun40119's Avatar
I have headlights and windshild wipers........ It rained everyday on the damn Power Tour last year.
Jake
Team Clueless
Resources saved on this page: MySQL 2.06%
