Best push to connect line 1/4" - Yellow Bullet Forums
Old 09-27-2010, 11:19 PM   #1
LTLHOMER
LTLHOMER's Avatar
Default Best push to connect line 1/4"
The stuff I've used is that stiff nylon junk and I want to swap it out for the nicer and more flexible stuff. What's the best stuff you guys have come across and where can I buy it?
'98 Mustang
5.7 HEMI, Work Turbochargers, Big Stuff 3
Hyperaktive Performance Solutions
LTLHOMER is offline   Reply With Quote
Old 09-28-2010, 12:32 AM   #2
BOOKEM
Pre-Staged
BOOKEM's Avatar
Default Re: Best push to connect line 1/4"
http://www.mcmaster.com/param/asp/PS...MainWidth=1162
BOOKEM is offline   Reply With Quote
Old 09-28-2010, 12:47 AM   #3
Bigturbonotch
Member
Pullin gears
Bigturbonotch's Avatar
defiantly mcmaster they have any push to connect you can imagine
Bigturbonotch is offline   Reply With Quote
Old 09-28-2010, 07:30 AM   #4
Robert1320
Custom Engine Shop
Robert1320's Avatar
Will it see vacuum? If so, anything "softer" might collapse.
Also the more flexible the more likely it will balloon up.
CDR Performance
The Custom Engine Shop
317-361-2044
Dealer For:
Aeromotive - Aeroquip - BRC Custom Pistons - Brodix - Callies - CustomCams - Dart - Oliver - T&D Rockers - Trend - JGS W/G & BOV - BorgWarner - Precision - EV Carb Hats - CSU Carbs - BS3 - Star Vacuum Pump - Stroud Safety - More
http://www.cdrperformance.biz
http://www.cdrperformance.com
Sponsor of the 2010 YellowBullet.Com Nationals
Robert1320 is offline   Reply With Quote
Old 09-28-2010, 12:19 PM   #5
LTLHOMER
LTLHOMER's Avatar
Pressure only. Just using for boost controller lines.
McMaster has a bunch of options. And half of them are plastic type. Which is the good one?
'98 Mustang
Old 09-28-2010, 01:37 PM   #6
Robert1320
Custom Engine Shop
Robert1320's Avatar
Best of temp and chem is teflon but, the worst for bending and running.
We use DOT black Nylon. Not to hard to run and hold up to most heat and chem.
If you need hard turns we use P.T.C. elbows.
You could run it in hard line as well. Tube/sleeve aluminum tubing with AN adapters.
CDR Performance
317-361-2044
Dealer For:
Old 09-28-2010, 01:41 PM   #7
Tims86
Tims86's Avatar
Also if you heat it very little it will bend and then hold the shape. I mean a little, sometimes just rubbing it with a rag and bending it will put enough heat in it it will hold that shape better.
Tim Huspen
Special Thanks to:
Teamzmotorsports.net, Majerusgarage.com, BorgWarner Turbo, PTP Racing, MFI (Methanol Fuel Injection), C&S Specialties.com, Workturbochargers.com, UltimateConverter.com, Diamond Pistons (diamondracing.net), Extreme Velocity, Harris Oil
Tims86 is offline   Reply With Quote
Old 09-28-2010, 01:42 PM   #8
OB1
YB.com Approved Vendor
OB1's Avatar
We stock all of the fittings and the 1/4" line. Use ONLY DOT airbrake tubing if your gonna run that way!!!! If it were me, I would measure the line and run stainless braided teflon hoses.
OB1 is offline   Reply With Quote
Old 09-28-2010, 01:45 PM   #9
Robert1320
Custom Engine Shop
Robert1320's Avatar
I guess I have unintentionally bent some with heat and they still worked.
CDR Performance
317-361-2044
Dealer For:
Old 09-28-2010, 01:51 PM   #10
Bigturbonotch
Member
Pullin gears
ill be using stainless line for mine, i have had the nylon melt before. Better to be safe then have a line fail when you need it most.
Old 09-28-2010, 02:17 PM   #11
cgeise
cgeise's Avatar
The "plastic" lines go real soft with heat - not what you want
cgeise is offline   Reply With Quote
Old 09-28-2010, 03:17 PM   #12
MEAN_SBC
TURBOBULLET.COM BITCHES!
MEAN_SBC's Avatar
I got all mine from Joe at tempest, and it seems like good stuff. I havent had a failed line yet, and it is so easy to repair if it does fail. I keep extra hose and fittings in the trailer, but still haven't had to use any of it.
Brant Campbell
Worlds Fastest MPH Car on 275's
6.92@212.09
2011 PSCA XDR/TT5 Champion
2011 PSCA Sin City Shootout Champion
Thanks To The Following:
MEAN_SBC is offline   Reply With Quote
Old 09-28-2010, 10:47 PM   #13
Anthony
Anthony's Avatar
Quote:
i use dot air brake line, if its routed correctly, there wont be a problem, diesel engine bays see way more heat for WAY longer than a race car ever will.
routing, routing, routing
Anthony is offline   Reply With Quote
Old 09-28-2010, 11:09 PM   #14
69GTO
Spooled up
69GTO's Avatar
Dot air brake lines here on a single-turbo street car.... X1000 on routing like Anthony mentioned!
69GTO is offline   Reply With Quote
Old 09-29-2010, 09:50 AM   #15
Bankbook
Launchin
Bankbook's Avatar
CAll Joe at Temptest racing. He provided me with evrything needed at a reasonable expense.
Bankbook is offline   Reply With Quote
