Club Car golf cart fuel delivery problems HELP - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Racing on two wheels
Racing on two wheels Talk about motorcycles with censorship
Old 09-27-2010, 09:51 PM   #1
NASTYCAMARO
Get you some
NASTYCAMARO's Avatar
Default Club Car golf cart fuel delivery problems HELP
I have a 98 carryall Club Car and it has been having some trouble getting fuel to the carb. I replaced the fuel pump and lines and fuel filters. I also replaced the oil and filter. I dont know why the fuel pump just will not provide the correct amount fuel. I feel it has something to do with this vaccum or what ever you want to call it from the engine. I towed my car at the track for years and it has progressivley gotten worse. Thanks for any help..
NASTYCAMARO is offline   Reply With Quote
Old 09-27-2010, 09:55 PM   #2
comp3452
Pre-Staged
comp3452's Avatar
Default Re: Club Car golf cart fuel delivery problems HELP
You didnt put too much oil in it did you?? I did this before and believe it or not had to drain some back out and ran perfectly fine after that...
comp3452 is offline   Reply With Quote
Old 09-27-2010, 09:58 PM   #3
comp670
comp670's Avatar
I just had the exact same problem with mine...The pickup tube INSIDE the fuel tank was plugged. I was able to unscrew the shutoff valve at the top of the tank and then blow air backwards thru the line.Runs great now.
NHRA Comp Elim B/A 670.
comp670 is offline   Reply With Quote
Old 09-27-2010, 10:01 PM   #4
NASTYCAMARO
Get you some
No I didnt I found it was a little thin. It has been doing this for a few months. It runs but you get about 75' and it slows down and bogs and you hit the choke and it will speed up again. Someone on another forum mentioned valve lash
Old 09-27-2010, 10:03 PM   #5
NASTYCAMARO
Get you some
Quote:
Yea did you notice how thin this tube is? I did this once before it helped but this time it didnt
Old 09-27-2010, 10:05 PM   #6
Hoosierdaddy
Hoosierdaddy's Avatar
Quote:
This says you definately have an internal carb problem or a problem keeping enough gas in the carb. You've got a pm coming.
1988 coupe mustang 357 cleveland powered
stock 4-bolt block, unported 4V heads, nonstroked crank and NO NITROUS
10.08 @ 135
Hoosierdaddy is offline   Reply With Quote
Old 09-27-2010, 10:16 PM   #7
NASTYCAMARO
Get you some
COMP670 I just went out in the shop and unscrewed the pick-up tube and took it apart. (I didnt know you could unscrew it)And found a big peice of cardboard like debris.. Thanks Guys I am glad I posted this problem. I am goiing to drain and fill tank with fresh and clean fuel...THANKS YB!!!
Old 09-27-2010, 10:26 PM   #8
Hoosierdaddy
Glad you found the problem. Make sure to clean the tank out good. Chances are there's more in trash in it.
10.08 @ 135
Old 09-27-2010, 10:32 PM   #9
NASTYCAMARO
Get you some
yep I see little pieces of crap in it. I will clean it out good. Thanks for the offer hoosierdaddy
Old 09-27-2010, 10:41 PM   #10
Hoosierdaddy
Does the fuel pump on that thing look like an aluminum square with two mounting tabs and three lines going to it. Should say Mikuni on it. If it does and ever quits, don't buy one. The golfcart places will say you have to buy another one but that's BS. They are rebuildable but the kit is not easy to find. I have a connection to get the kits and they are cheap. Those pumps are about $65-$75 for a lawnmower but the golfcart shop will likely say much more than that. The kits are about $12 and there's nothing to rebuilding it.
10.08 @ 135
Old 09-27-2010, 11:54 PM   #11
dragula1971
If you need anymore help go to buggies gone wild .com . Pretty neat cart forum !!
dragula1971 is offline   Reply With Quote
Old 09-28-2010, 12:01 PM   #12
ctjstr
ctjstr's Avatar
I don't know about you guys but it seems that I end up screwing around with my golf cart more then the nitro harley I pull it with. The little bastard has a mind of its own...and its evil.
ctjstr is offline   Reply With Quote
Resources saved on this page: MySQL 1.04%
