Connecting rod discussion of aluminum vs Steel - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Supercharged - All Out Automotive
Old 09-22-2010, 06:18 PM   #1
Outlaw Bill
Outlaw Bill's Avatar
Default Connecting rod discussion of aluminum vs Steel
I have been thinking this over for a long time. My engine consists of a DRCE 2 9.400 deck block with a 2.100 rod journal 3.750 stroke. It will see 9000-9500 rpms. It will be fed by the F3-139 making 2500hp or more. I'm trying to decide if a steel rod can live, or if aluminum rods are necessary. I have called Oliver, they pretty much told me they had not done anything like that before, and would be expensive to design a rod to live. I like the idea of the steel rod life, but if aluminum is the only rod that live, so be it.
TeamZmotorsports Stock Suspension 25.3 Outlaw Drag Radial 1991 Mustang
http://www.teamzmotorsports.net/category_s/166.htm
Thank you to the following-
TeamZmotorsports
Marcella Manifolds
Schoneck Composites
Ultimate Converter Concepts
http://www.hardcore50racing.com/vbulletin/index.php
Outlaw Bill is offline   Reply With Quote
Old 09-22-2010, 07:22 PM   #2
tomato
Default Re: Connecting rod discussion of aluminum vs Steel
how many cubes? aluminum rods on this, with that much rpm. not to discourage from trying steel or anything new.
cube question had nothing to do with opinion, just asking?
tomato is offline   Reply With Quote
Old 09-22-2010, 07:33 PM   #3
Ron Clevenger
If your going to build and run a motor like that you better figure into the expense a rod maintenance program. Personally, I would run a MGP aluminum rod and replace them after 100 runs.
Your piston speed is not unmanageable but will requirer attention.
For comparisons......at 9500 @ 3.75" piston speed will be 5937 FPM, a Pro Stock engine runs around 6300 FPM and a 632 with a 4.75 stroke @ 8000 runs 6333 FPM.
Blessings.........Ron.
Creekside Racing Ministry...John 14:6
Now testing new Travis Quillen Motorsports Engineering Methanol boost referenced high pressure MFI system
First full pass, 6.25 @ 235+mph, very soft tune
Steve Morris www.stevemorrisengines.com
Ron Clevenger is offline   Reply With Quote
Old 09-22-2010, 07:48 PM   #4
Outlaw Bill
499 c.i.d. - 4.600 bore x 3.750 stroke.
MGP and GRP are on my list.
TeamZmotorsports
Marcella Manifolds
Schoneck Composites
Old 09-23-2010, 09:50 PM   #5
ssnova
Launchin
ssnova's Avatar
BME's,,,, pretty sure thats what the top fuel guys run, id stick with bill millers, seen some bad machining allowing the pin to drop out of the grp's and numerous sets cracked up next to the rod bolts in a friend of mines super street outlaw car
ssnova is offline   Reply With Quote
Old 09-24-2010, 01:18 PM   #6
Injected65
Injected65's Avatar
Quote:
Mike Smith by chance?
Bill - You might talk with Mark Wolfe with the twin turbo T-Bird. I think he was running steel rods in his car. I assume it was probably in that same hp and rpm range. He might have some valid input from the steel rod perspective.
Chris
C & B Motorsports - www.candbmotorsports.com
Innovators West - www.innovatorswest.com
Injected65 is offline   Reply With Quote
Old 09-24-2010, 02:55 PM   #7
BigB
Member
Pullin gears
BigB's Avatar
Why even consider the steel, the aluminum isolate harmonics from the crank, is it a maintenance issue?
BigB is offline   Reply With Quote
Old 09-24-2010, 03:22 PM   #8
LPRacing
LPRacing's Avatar
and most pro stock motors have steel rods in them now too
we run steel olivers in our 525 f3 combo at 8500 rpm, no issues
LPRacing is offline   Reply With Quote
Old 09-24-2010, 03:25 PM   #9
Outlaw Bill
Who did you get them from?. Oliver says they don't make a 6.200-6.250 rod with 2.100 journals with a .990 pin to withstand 2500 plus hp and 9000 plus rpms. They only make a 2.200 rod journal. I'm looking at $3000.00 for a custom designed rod from Oliver. They say the 2.100 journal will break over 2000hp.
TeamZmotorsports
Marcella Manifolds
Schoneck Composites
Old 09-24-2010, 03:59 PM   #10
seabass459d
Launchin
" I have called Oliver, they pretty much told me they had not done anything like that before, and would be expensive to design a rod to live"
Interesting, Oliver told my builder last week they have a"extreme duty" steel rod for up to 2500hp that are being run in twin turbo cars with no failures... This is what he ordered me for my blower project.... EDIT maybe they just dont make it in your length
seabass459d is offline   Reply With Quote
Old 09-24-2010, 04:08 PM   #11
Jp outlaw
peanut hunter!!!
4.600x3.750 - man we've been threatening to do with with a roots combo for some time now.
I would think the biggest thing with a steel rod would be to keep a very close eye on the bearings. Being more rigid they're going to transfer more harmonics and more "bang" to the crankshaft. - I would think in that kind of app steel rods would likely have a noticable duty/life cycle as well as aluminum, thus though they might go 200 runs instead of 100. With the "crazy custom" cost difference, I personally don't see a benefit.
Jp Shawgo - Close E'nuff Racing
www.sandeperformance.com
www.shraonline.com/
www.outlawtenfiveracing.com
www.transmission-specialties.com
25.4 '85 notchback for sale; roller or turn-key
Jp outlaw is offline   Reply With Quote
Old 09-24-2010, 04:59 PM   #12
Outlaw Bill
They don't make it in a 2.100 rod journal or that short from what the guy told me. Maybe they do, or the person I talked to thought I was a stroke. Happens once in a while, I have a speech inpediment called stuttering. Looks like aluminum rods will be the way to go, plus I can buy multiple sets for the price I was quoted on steel rods.
TeamZmotorsports
Marcella Manifolds
Schoneck Composites
Old 09-24-2010, 06:59 PM   #13
Ron Clevenger
Outlaw Bill, Mark Wolfe does indeed run steel rods in his AA/T comp car. But the motor is something like 347"s which would have substantionally less reciprocating weight. Also the turbo's require considerably less gross power to produce the same power to the rear wheels. I think Mark is actually in the 2650+hp area.
You would certainly be on the fringes with a steel rod if you had one made for it. An aluminum rod would be a tried and true area and would serve you. Personally I prefer the MGP rods which use the A-1 rod bolts. If you order from them make sure you torque the bolt as they specify......one pull to full torque.
Have fun.........................Blessings............. Ron.
Old 09-24-2010, 08:25 PM   #14
Outlaw Bill
Thank you Ron. It appears aluminum rods are my only choice. I have plenty of room for a top fuel sized aluminum rod in my block.
TeamZmotorsports
Marcella Manifolds
Schoneck Composites
Old 09-26-2010, 07:48 AM   #15
ASH
mfi turbos rule
ASH's Avatar
419 cubes
MFI fuel injection
http://www.quillenmotorsports.com/
ASH is offline   Reply With Quote
