Dragstrip surface preparation equipment? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 09-22-2010, 04:18 PM   #1
461poncho
461poncho's Avatar
Default Dragstrip surface preparation equipment?
Google couldn't help me on that one,who sells the equipment for the small tracktors for track preparation?
461poncho is offline   Reply With Quote
Old 09-22-2010, 04:52 PM   #2
Tom Cowle's wife
Tom Cowle's wife's Avatar
Default Re: Dragstrip surface preparation equipment?
RAY PRICE owns a fab shop in norwalk ohio, he builds a nice drag for behind a tractor
RPM MAGAZINE/LUCAS OIL WAR BY THE SHORE
AUG 5th & 6th 2016
www.warbytheshore.com
RENEGADE RACING ASSOCIATION
2016 Schedule TBA
www.renegaderacingassociation.com
Tom Cowle's wife is offline   Reply With Quote
Old 09-22-2010, 05:02 PM   #3
rattman
Launchin
rattman's Avatar
Quote:
Dave Price> mailto:info@fabriweldcorp.com
rattman is offline   Reply With Quote
Old 09-22-2010, 06:15 PM   #4
Tom Cowle's wife
Quote:
Originally Posted by rattman View Post
lol...right
AUG 5th & 6th 2016
2016 Schedule TBA
Old 09-22-2010, 06:19 PM   #5
94-6spd
94-6spd's Avatar
How about a large tractor tire and some really heavy weight? This is what was used on the stickiest track I've ever been on. Sounds ghetto but it works great. It's just rubber being dragged.
94-6spd is offline   Reply With Quote
Old 09-22-2010, 06:19 PM   #6
461poncho
461poncho's Avatar
Thanks.
Old 09-22-2010, 06:26 PM   #7
z289sec
z289sec's Avatar
What are you looking for? Something to put down rubber? Something to take off the old? Or something for between rounds or oil down clean up?
RTCTTFMF!!!!
Stock suspension 67 Camaro
565 Conventional head BBC with fogger and a plate on 275's
Just about done
Thanks to:
Texas Racewerks, Sanger, Texas
Nyes Automotive Racing Engines, Muncie, Indiana
FTI Converters and Transmissions, Deland, Florida
ACE Racing Transmissions, Garland ,Texas
z289sec is offline   Reply With Quote
Old 09-23-2010, 08:38 PM   #8
461poncho
461poncho's Avatar
We are looking for something to lay down rubber,clean the track and to use for cleanup after oil spills.
A few guys from here will be at the Orlando world street nationals and
Jason from VP has agreed to show them some tricks and tips and hopefully this winter we can buy a tractor with the basic equipment.
All we have now is track bite and the cars lay down the rubber and cleanups are done with cat sand,a torch and gasoline to burn up the rest.
Old 09-23-2010, 09:04 PM   #9
badcompany89
badcompany89's Avatar
Quote:
x2 if i rememeber right piedmont use to do that and it worked great. hadnt been in a while so not sure if they still do it that way. they also use to do it with an s10, maybe the tractor was phucked at the time lol .
89 camaro-under construction-4 link, 9", 496 with a little boost (hopefully)
89 gt mild 351w, c4, and 4.56 1.54 60' 7.56 @ 89 mph
American by birth, southern by the grace of God.
badcompany89 is offline   Reply With Quote
Old 09-23-2010, 09:15 PM   #10
MercilessMike
MercilessMike's Avatar
http://www.tennantco.com/equipment/o...-city-cleaning
MercilessMike is offline   Reply With Quote
Old 09-23-2010, 09:27 PM   #11
461poncho
461poncho's Avatar
Doesn't the rubber need to be soft compound /slick tire ?
Old 09-23-2010, 09:33 PM   #12
Tom Cowle's wife
Quote:
better practice, yes
AUG 5th & 6th 2016
2016 Schedule TBA
Old 09-23-2010, 09:34 PM   #13
461poncho
461poncho's Avatar
We actually tried this with massive tires from a forklift and it turned to "rubber dust" then we bought a softer rubber mat that we put the heavy tires on and it worked better but eventually it tore up.
Old 09-23-2010, 10:17 PM   #14
TuffEnuff
TuffEnuff's Avatar
I actually perfer to use "street tires" they seem to last longer and keep the track from building up too much rubber.
Grudge racers check in! Support the RSD program by making a quick post and saying hello! ->www.rsdforums.net
Concert sound and lighting in the Chicago
area = www.tsaproductions.net
TuffEnuff is offline   Reply With Quote
Old 09-24-2010, 11:31 AM   #15
mongse
mongse's Avatar
You might be able to fab something up yourself too. When ADRL was in St. Louis, they used a tractor and a pull-behind scrubber. The scrubber consisted of an upside down 9" rear end connected to the PTO of the tractor. There were two chains that dropped down from the rear end to an axle that had 4 tires mounted on the axle. As the tractor moved forward, the PTO would turn the tires counter-clockwise and lay down a ton of rubber.
I've seen other places use 3-4 old slicks mounted under a rear-mounted deck w/ weight on it. The tires were cut so that they laid flat and would apply a good amount of rubber and generate a good amount of heat.
mongse is offline   Reply With Quote
