should i buy a vaccum pump or not? - Page 2 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Nitrous - Induction Solutions
Old 09-07-2010, 11:30 AM   #16
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
Default Re: should i buy a vaccum pump or not?
It is real obvious. Normally your vacuum stays constant going down the track. On some cars it rises a little, others it falls a little. When you see the gauge bouncing all-over the place you know you have problems!
Mike Beck is offline   Reply With Quote
Old 09-07-2010, 11:53 AM   #17
spray power
It can be obvious, or it can just ba little dip in vacuum at a certain spot. Most cars will raise vacuum going down track, where you will more than likely see it first is on the gear change. Once you see it you can then deside what changes you are going to make to correct the problem. I have seen dips in pan vacuum but not able to see it on the plugs, so if you watch every thing close it will be help full nitrous or n/a.
Auston Pasquith
ACP Performance & Custom Fabrication
Hot Springs, AR.
Custom manifold porting/EFI conversions
Dealer for:
Induction Solutions/ Woody's Pluming/Jerry Bickel Race Cars/RJ Race Cars/Race Parts Solutions/Hyperformance/BTE-Memphis Performance/Strange Eng./FAST Fuel Injection/Schoneck Composites and more!
spray power is offline   Reply With Quote
Old 09-07-2010, 12:12 PM   #18
coolbeans
Pre-Staged
coolbeans's Avatar
Quote:
Just ordered the sensor and will install before the weekend. I am planning to mount the sensor to the front of the valve cover where I have a #12 capped. Any concerns about vibration or oil splashing it? Thanks for your responses (Mike and Spray Power)
Chris
coolbeans is offline   Reply With Quote
Old 09-07-2010, 12:54 PM   #19
spray power
Quote:
Chris
Do you have a gage? If so tap into it (.250 brake air line work good with a small peice of rubber hose on the ends) and run it to the sensor. We will put the sensor right next to the 7531 box for we don't have to run any more wires. You can come off the #12 but we try to put a fitting (.250 push lock air line fiting) in the back of the intake or value cover which makes it much ezer in the long run.
Auston Pasquith
Hot Springs, AR.
Dealer for:
Old 09-07-2010, 08:45 PM   #20
1fast10
1fast10's Avatar
so wheres the best placement of map sensor. i have msd 7531 and a vacuum pumo. i have guage on cowl thats plumb into valave cover. is this where sensor needs to be or reading vacuum from intake
www.precisionfabandwire.com
https://m.facebook.com/precisionfabwire/
Leashelectronics.com dealer
Holley efi dealer
Injector dynamics dealer
Nickels performance
1fast10 is offline   Reply With Quote
Old 09-07-2010, 10:40 PM   #21
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
I don't used a Digital 7, but I do have a GM MAP sensor under my dash with a 3/16" or so rubber line going through the firewall to a fitting on the back of the valve cover so it can easily be removed in the rare instance I check my lash.
I had the sensor hooked to my LM-1 at the time so I could record the vacuum during a pass. I also had a regular vacuum gauge on the dash so I could see it going down the track. It certainly saved my ass one night when I tried a "hero shot"! I saw the gauge bouncing-around and instantly kiiled the juice and continued down the track on motor. I saw the same thing on the data logger. When I opened the drain on my breather tank there was a lot of oil in there, normally there is nothing. I'm sure I would have hurt it good if I had made a full-track nitrous pass that night.
Old 09-07-2010, 11:42 PM   #22
Sam Vincent
Sam Vincent's Avatar
what is the MSD part # for MAP sensor? will it show in inches of vacuum?
sponsors:
Nitrous Express, Diamond, JESEL, Marcella Manifolds, M/T, VP racing fuel, GRP, Bullet Cams, RacePak, Leashed Elect, ATI performance
Vincent Performance
Graham KY
270-977-1893
Dealer:
Diamond, Trend, TotalSeal, BulletCams, Morel, Jesel, Brodix, Moroso, Manton, GRP, Callies, PSI~PAC, Stef's, Nitrous Express, TrickFlow, TotalEngineAirflow, PTC converters, William's Perf, ProLite batt, UltraPro Machine, Danny Bee, ATI Perf, MOSER Engineering, Sonnax Industries, PST shafts...
Sam Vincent is offline   Reply With Quote
Old 09-08-2010, 12:24 AM   #23
spray power
Quote:
2311 MSD, and yes it will show in inches of vacuum. It will read map on the trace log.
Auston Pasquith
Hot Springs, AR.
Dealer for:
Old 09-08-2010, 12:35 AM   #24
Sam Vincent
thanks
sponsors:
Vincent Performance
Graham KY
270-977-1893
Dealer:
Old 09-08-2010, 12:40 AM   #25
Sam Vincent
thanks
not coming up under that part # 2312, 2313, 2314 but no 2311
sponsors:
Vincent Performance
Graham KY
270-977-1893
Dealer:
Old 09-08-2010, 12:56 AM   #26
spray power
I just looked at one in the shop and it's 2311. They must have changed numbers.
Auston Pasquith
Hot Springs, AR.
Dealer for:
Old 09-08-2010, 07:42 AM   #27
R Parsons
Launchin
R Parsons's Avatar
The one I was looking at was the 2314 also .
R Parsons is offline   Reply With Quote
Old 09-08-2010, 01:49 PM   #28
Seattle_Mike
Seattle_Mike's Avatar
2311 is the 1 bar
2312 = 2 bar
2313 = 3 bar and so on.
68 Camaro ProMod - 848ci - M&M 3 Speed
www.yvonnelucasracing.com
Seattle_Mike is offline   Reply With Quote
Old 09-08-2010, 11:10 PM   #29
1fast10
1fast10's Avatar
i have guage on cowl but for some reason i never see it going down track. so i was wanting to log the vacuum to see whats happenig. what location do you mount the rubber hose or the map sensor for logging. i currently have a -4 fitting in valvecover beside vacuum pump line fitting for guage. didnt know if i could tee off of that. or get at another location
Holley efi dealer
Nickels performance
Old 09-08-2010, 11:53 PM   #30
Sam Vincent
Quote:
that a 4 bar MAP sensor. the 2311 is the 1 bar which MSD no longer sales the told me on the phone today. Pete from MSD said a 1 bar would give best resolution ofr vacuum only use. just need a plain ole GM MAP sensor
sponsors:
Vincent Performance
Graham KY
270-977-1893
Dealer:
