should i buy a vaccum pump or not? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Nitrous - Induction Solutions
Old 09-03-2010, 01:44 PM   #1
03z06killa
Burnout box
Default should i buy a vaccum pump or not?
I have a sbf 331 stroker nitrous car going to hit it with 200-250 never have used a vaccum pump in the past my friend told me i should get one but i dont know anything about them. if i do need one wich should i get 3vane or 4 if anyone could help i would apreciate it.
03z06killa is offline   Reply With Quote
Old 09-03-2010, 02:14 PM   #2
seabass459d
Launchin
Default Re: should i buy a vaccum pump or not?
yes, 3 vane moroso will be fine
seabass459d is offline   Reply With Quote
Old 09-03-2010, 02:31 PM   #3
91stangnos
Launchin
91stangnos's Avatar
Quote:
this would be best but you can also use header evac system
91stangnos is offline   Reply With Quote
Old 09-03-2010, 02:56 PM   #4
Kurt
Launchin
Kurt's Avatar
Solved my oil leaking problem. I'd assume it added a little power also.
Moroso 4-vane here.
Kurt is offline   Reply With Quote
Old 09-03-2010, 03:08 PM   #5
stix818
Member
Pullin gears
stix818's Avatar
If you have money to spend then a 3 vain.. You could always do like 91 stangnos mentioned.. I good evac system will work just fine with your combo..
Nelson Speed & Marine
Hellbound Train & Heartbeat Dragboat Racing
1986 Cole TR-3 Dragboat
stix818 is offline   Reply With Quote
Old 09-04-2010, 12:08 AM   #6
spray power
4 vane pump and record the pan vacuum to detech deadanation in the engine. If you are useing a 7531 you can hook up a map sensor to it and record off that.
Auston Pasquith
ACP Performance & Custom Fabrication
Hot Springs, AR.
Custom manifold porting/EFI conversions
Dealer for:
Induction Solutions/ Woody's Pluming/Jerry Bickel Race Cars/RJ Race Cars/Race Parts Solutions/Hyperformance/BTE-Memphis Performance/Strange Eng./FAST Fuel Injection/Schoneck Composites and more!
spray power is offline   Reply With Quote
Old 09-04-2010, 12:10 AM   #7
bottlefed1
bottlefed1's Avatar
A vacuum pump is one of the best investments you can make on a nitrous motor, over time they usually pay for themselves by allowing you to see detonation and keeping the cylinders dry. I would also go ahead and get a 4 vane if you can that way you will always have room to grow.
bottlefed1 is offline   Reply With Quote
Old 09-04-2010, 08:53 PM   #8
Seattle_Mike
Seattle_Mike's Avatar
Besides all the benefits already mentioned, you should pick up at least 25hp. That's what I saw on one of the engines I had built when we had it on the dyno.
68 Camaro ProMod - 848ci - M&M 3 Speed
www.yvonnelucasracing.com
Seattle_Mike is offline   Reply With Quote
Old 09-06-2010, 09:35 AM   #9
craig w.
Launchin
craig w.'s Avatar
Quote:
Does anyone have a part number for the proper map sensor to use with a 7531 box?
Craig Watson
2QuickNovas Racing
'73 Death Nova
'16 OSCA NTS Champion
5.23@131
Sponsors:
Fast Shafts
AEM Electronics--get your data loggers here
TRZ Motorsports
Carnivore Performance--stop babysitting your nitrous bottles
Bradco Converters
Rapp Racing
craig w. is offline   Reply With Quote
Old 09-06-2010, 07:05 PM   #10
Seattle_Mike
I believe it's the part number 2311 for the single bar sensor. They have an online catalog you can use.
Old 09-06-2010, 09:54 PM   #11
craig w.
Launchin
craig w.'s Avatar
Summit says that part isn't available. I'll do some searchong and see what I can find in a single bar 0-5v sensor.
Thanks for the info.
Craig Watson
2QuickNovas Racing
'73 Death Nova
5.23@131
Sponsors:
Fast Shafts
TRZ Motorsports
Bradco Converters
Rapp Racing
Old 09-06-2010, 10:12 PM   #12
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
There is no reason you shouldn't be able to use an everyday GM 1 bar sensor. They are readily available from any auto parts store. GM used the same sensor on miilions of vehicles. Look at a 1991 S-10 truck for an example.
I would put a vacuum pump on any nitrous engine. Not cheap, but it's certainly worth it. I use the Star Sportsman stuff myself. They have one of the best drive mandrel setups out there.
The worst part of a vacuum pump (next to the price) is mounting it and making it work with any other accessories you already have, Alternator, Power Steering pump, Water pump...........
Mike Beck is offline   Reply With Quote
Old 09-07-2010, 03:05 AM   #13
Seattle_Mike
It shows up online http://www.summitracing.com/parts/MSD-2311
I believe it's the standard GM sensor anyway that you can get pretty much anywhere.
Old 09-07-2010, 09:19 AM   #14
spray power
Use the MSD map sensor and same you some troble. MSD makes the plug in a little different than the regular GM map sensors and you will spend some time trying to get it to plug in the MSD 3 pin harness. Yes the MSD is a little more but sames time which is money.
Auston Pasquith
Hot Springs, AR.
Dealer for:
Old 09-07-2010, 11:26 AM   #15
coolbeans
Pre-Staged
coolbeans's Avatar
Just to be clear, detonation can be recorded by monitoring pan vacuum? I assume this is detectable to a logger like racepak. What do you see when detonation occurs? Is it real obvious, or are there subtle changes in vacuum? Is this useful in n/a setups as well?
Also, I am looking for a racepak o2 single channel. It seems they are out of stock for a couple of more weeks.
coolbeans is offline   Reply With Quote
