TH-400 spitting fluid up and out the dipstick tube - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 09-03-2010, 09:31 AM   #1
WingMan-ROP
Burnout box
Default TH-400 spitting fluid up and out the dipstick tube
I was told by an ROP member that this would be the place to get an answer to an issue that a friend is having with his turbo 400. Shifts normally (nice crisp shifts) but it will force fluid out the top of the dipstick tube. When the transmission is full it will push it up and out for a while. Nothing comes out of the vent tube though. Vent tube is clear and open (ran a wire into it). It is not leaking out the front seal, rear seal, transmission cooler lines, etc. Torque converter is old (supposedly off a 64 GTO). This transmission was working fine before I put it in storage for about 5 years. It was not taken apart during that time.
Any ideas of what could be the problem?
WingMan-ROP is offline   Reply With Quote
Old 09-03-2010, 10:08 AM   #2
left 4 dead
Member
Pullin gears
Default Re: TH-400 spitting fluid up and out the dipstick tube
Sounds like the vent is plugged!
Even though you can push a wire into it doesnt mean the pump cavity is open/ clear, only the tube. Put a vacuum pump on it and see if it holds suction or not. With 5 years of storage you can have a spiders nest or other insects build a nest in the pump cavity.
If you blow air into the vent you will have a mess of oil come out of the dipstick!
Are you sure the dipstick and tube are correct?
left 4 dead is offline   Reply With Quote
Old 09-03-2010, 10:23 AM   #3
Robert1320
Custom Engine Shop
Robert1320's Avatar
Check the vent tube for blockage, do a fluid & filter change and report back.
Hit the newbie thread too.
CDR Performance
The Custom Engine Shop
317-361-2044
Dealer For:
Aeromotive - Aeroquip - BRC Custom Pistons - Brodix - Callies - CustomCams - Dart - Oliver - T&D Rockers - Trend - JGS W/G & BOV - BorgWarner - Precision - EV Carb Hats - CSU Carbs - BS3 - Star Vacuum Pump - Stroud Safety - More
http://www.cdrperformance.biz
http://www.cdrperformance.com
Sponsor of the 2010 YellowBullet.Com Nationals
Robert1320 is offline   Reply With Quote
Old 09-03-2010, 10:28 AM   #4
WingMan-ROP
Burnout box
Tube and dipstick came off a good turbo 400.
I'll see if I can get to those this weekend. Thanks for the suggestions.
Old 09-03-2010, 07:58 PM   #5
Gregaust
Member
Pullin gears
Check oil level is correct also . Level should be approx equal to the pan flange. 400's can be sensitive to overfull
Gregaust is offline   Reply With Quote
Old 09-04-2010, 06:29 AM   #6
chris718
Was it hard to fill with oil initially?
Cristoforos Kokkonis,GM automatic transmission specialist.
chris718 is offline   Reply With Quote
Old 09-25-2011, 11:00 PM   #7
cooke
Member
Pullin gears
cooke's Avatar
I realize this is an older post; but was the vent-tube clogged and did "clearing" it help? I've recently encountered the exact same thing (blowing ATF out of dipstick and all over the back of motor,etc.). I did a search and found this and was curious if it was ever resolved?
Appreciate any input that might be offered. Thanks.
cooke is offline   Reply With Quote
Old 09-26-2011, 01:56 PM   #8
themadreefer
Spooled up
themadreefer's Avatar
tt
themadreefer is offline   Reply With Quote
Old 09-26-2011, 02:11 PM   #9
cgeise
cgeise's Avatar
I had one do that when it had a restricted filter - ran ok at low power but got hot and did not want to take fluid on the fill up
cgeise is offline   Reply With Quote
Old 09-26-2011, 04:59 PM   #10
cooke
Member
Pullin gears
cooke's Avatar
Quote:
Appreciate your reply. But this has a brand new filter.
Old 09-26-2011, 07:24 PM   #11
Hutch
Moderator
Hutch's Avatar
Is the new filter a mesh screen or paper filter?
Hutch
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
Old 09-26-2011, 08:58 PM   #12
cooke
Member
Pullin gears
cooke's Avatar
Mesh screen.
Old 09-27-2011, 12:06 AM   #13
Hutch
Moderator
Hutch's Avatar
Mesh screen is good , you may have other problems. Oil level incorrect, restricted cooler lines,pump halves not flat or distorted,fwd drum checkball leaking,sealing ring leakage etc.
Hutch
www.hutchtrans.com
519-453-4318
Old 09-27-2011, 12:10 AM   #14
cooke
Member
Pullin gears
cooke's Avatar
Thanks for the input. That'll give us a place to look. I feel like it'll one of the last three you listed. I'd never get lucky enough to have something simple.
Again, I appreciate your time.
Resources saved on this page: MySQL 2.11%
