Trans yoke slip - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 08-28-2010, 05:07 PM   #1
$upernova
Member
Pullin gears
$upernova's Avatar
Default Trans yoke slip
How much yoke slip should there be for the trans yoke?
Slower than I think I am!!!!!!!!!
$upernova is offline   Reply With Quote
Old 08-29-2010, 09:58 PM   #2
Bob Hollinshead
Launchin
Default Re: Trans yoke slip
I think the general rule is to have the yoke pulled out 3/4"-1" from bottomed out under running conditions?
Bob Hollinshead is offline   Reply With Quote
Old 08-29-2010, 11:55 PM   #3
Hutch
Moderator
Hutch's Avatar
Not really sure what your asking. Can you elaborate a little , Im having a moment.
Hutch
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
Old 08-30-2010, 07:46 AM   #4
$upernova
Member
Pullin gears
$upernova's Avatar
How much should the trans yoke be pulled out of the trans to be safe for in and out movement.
Old 08-31-2010, 01:27 AM   #5
Hutch
Moderator
Hutch's Avatar
Depends on how active the rear suspension is by design. I think 1" out from all the way in should be fine.
Hutch
www.hutchtrans.com
519-453-4318
Old 08-31-2010, 05:06 PM   #6
$upernova
Member
Pullin gears
$upernova's Avatar
Thank you!
Old 09-01-2010, 10:04 AM   #7
SILVERFOXTRANS
Member
Pullin gears
SILVERFOXTRANS's Avatar
When I do swaps (most often 4R70W into stuff) in one event I used a large ratchet strap to load the suspension as much as I could - this was pushing the DS the furthest into the trans...then I meassured what kind of clearance I had at the pinion.
------------------------- Dan Gilsdorf ---------------------------
SILVERFOXTRANS is offline   Reply With Quote
Resources saved on this page: MySQL 1.15%
