Trans-brake pressure relief orfice ????? - Page 3 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 08-22-2010, 05:44 PM   #31
ERV JR
ERV JR's Avatar
Default Re: Trans-brake pressure relief orfice ?????
Quote:
Originally Posted by Hutch View Post
I have made leaf spring drag radial cars work just fine with a 2.48 first gear TH400 without a progressive. You have more tols to work with that I ever had so im certain you will get it sorted out. Don't think of caling me a smart ass , I hope im not coming across as one. I speak from hands on experience , im not just a trans guy I have spent some time in the trenches too!!
I still think your car will work with what you have , Im just trying to save you a few bucks on a bunch of shit you don't need.
Hutch
Hutch what rear gear did the car have ?
ERV JR is offline   Reply With Quote
Old 08-22-2010, 08:41 PM   #32
$upernova
Member
Pullin gears
$upernova's Avatar
Ok here's my combo:
525 ci tall deck bbc
4.310 bore x 4.50 stroke
11.4-1 compression
Dart pro-1 325 cc heads ported out to 368 cc's and flows 411 cfm's
Eddy 454 tall deck intake ported to heads
1000 cfm hp 4150 Holley from Pro Systems (class rules)
Wilson nitrous plate
Cam Motion cam specs: .716 .714 lift, 276 283 duration @ .050, at 111 installed at 107
MSD 7531, crank trigger 36* locked
all Magna fuel, PS 500
Hughes PG-95 converter 5000 stall
PG trans 1.80 lower gear set
4.30 gears in the rear
Calvert split mono's, Cal-tracs Rancho RS 9000 rear
Anti roll bar.
Moroso trick springs, QA-1 R single ajust up front
Mickey Thompson 275/60/15 drag radial's
Here's the video with the trans brake hitting the tires so hard it's instant tire spin. No nitrous, no timing out, At 4000 rpm's 16.5 tire pressure:
$upernova is offline   Reply With Quote
Old 08-22-2010, 09:34 PM   #33
Hutch
Moderator
Hutch's Avatar
Quote:
3.89 rear gear.
Hutch
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
Old 08-22-2010, 09:41 PM   #34
Hutch
Moderator
Hutch's Avatar
Quote:
Originally Posted by $upernova View Post
Ok here's my combo:
11.4-1 compression
Anti roll bar.
Looks like you have some very nice stuff hidden under that sleeper. Does it actually stall 5000 rpm? Will it run down the track on the motor?
Hutch
www.hutchtrans.com
519-453-4318
Old 08-22-2010, 09:51 PM   #35
$upernova
Member
Pullin gears
$upernova's Avatar
It runs down the track on motor to a 6.35 with 5* for .15 out of the box launched at 3500 rpm's. Converter hump is at 5000 rpm's.
If we paint the car it's just another painted car at the track. We call it Frankin Nova. All the goodies are under the skin.....
Slower than I think I am!!!!!!!!!
Old 08-22-2010, 09:58 PM   #36
$upernova
Member
Pullin gears
$upernova's Avatar
here's what the rpm gragh looks like a good run;
Old 08-23-2010, 12:30 AM   #37
Hutch
Moderator
Hutch's Avatar
Appears to barely make it down on the motor alone!! Don't paint it either.
Hutch
www.hutchtrans.com
519-453-4318
Old 08-23-2010, 06:41 AM   #38
$upernova
Member
Pullin gears
$upernova's Avatar
Hutch
Hence the questions!
I'm looking at everything that might help. A gear change might help alot.... New shock for the back, retardd the cam, put more waight in the back, have the converter worked on, and on and on and on......
Old 08-23-2010, 11:48 PM   #39
Hutch
Moderator
Hutch's Avatar
I would really focus on rear suspension , check for binding , check driveshaft length and make sure the yoke slides free on the splines, get a good set of rear shocks for sure , they are very important.
Hutch
www.hutchtrans.com
519-453-4318
Old 08-24-2010, 07:23 AM   #40
$upernova
Member
Pullin gears
$upernova's Avatar
Hutch
Everthing is good. Except the shock.
Old 08-24-2010, 10:13 PM   #41
tilt
Burnout box
did you check front suspension? Calvert recommends a min 5 inches of front suspension separation. Just something you may want to look at also, because they told me that the front suspension is just as important and has to be right also. You may wanna contact caltrac and talk to Travis or John.
tilt is offline   Reply With Quote
Old 08-26-2010, 01:45 AM   #42
$upernova
Member
Pullin gears
$upernova's Avatar
Yep, front end is good. 5" of travel and it has QA1 R shock on it. The gear and the rear shock is what I'm changing, I talked to Marty Chance And his sugestion was change to a 3.70 gear and make sure I have a good DA shock on the back.
Old 09-06-2010, 01:59 AM   #43
chprob
color me gone
chprob's Avatar
hey chris what are your front shocks set at the video i just saw looks like if was having a hard time lifting the front end it could just be that video just wondering
8.91@ 153 N/A
California Horsepower& Performance
When Fast Isn't Fast Enough
www.chpdragracing.com
Speed Equip. & Service under 1 Roof
Upland CA
909-579-6344
chprob is offline   Reply With Quote
