F250 Wander Steer - Yellow Bullet Forums
Old 08-14-2010, 08:46 PM   #1
Luxy72
Launchin
Luxy72's Avatar
Default F250 Wander Steer
Got an 02 F250 Super Duty that has horrible wander steer...I've replaced the gear box, steering stabilizer, had tires and an alignment done...damn things still wanders all over the rode...just seems like tons of slop...everything in the front end is tight...is there something else on these trucks that cause this?
Luxy72 is offline   Reply With Quote
Old 08-14-2010, 09:05 PM   #2
projoe87
Default Re: F250 Wander Steer
Did they do a toe and go or did it need the cams? sounds like a possible caster issue.
projoe87 is online now   Reply With Quote
Old 08-14-2010, 09:09 PM   #3
Long_Stroke
Launchin
Long_Stroke's Avatar
Ball joints? I know mine are bad and my heap wonders everywhere.
99 F250
8 Second Street Car, on Radials
Get Some
www.Steeda.com
Long_Stroke is offline   Reply With Quote
Old 08-14-2010, 09:11 PM   #4
tverble
Launchin
tverble's Avatar
Tires need to be atleast E load rated.
EZ111
352CI & F2
tverble is offline   Reply With Quote
Old 08-14-2010, 09:40 PM   #5
Leonard 95
Leonard 95's Avatar
I would check ball joints as posted, you could also slightly loosen up the adjustment on top of the steering gear to help the wander. Try about a 1/2 turn counter clockwise and see if it helps.
Leonard 95 is offline   Reply With Quote
Old 08-14-2010, 09:40 PM   #6
cmccarthy
Tellin' it like it is
cmccarthy's Avatar
I was complaining at the servoce department of local dealer about my F250 wandering the road and he said that the front sway bar end links commonly go bad and cause this issue. Have a look at them.
Charles
BAITTFMF
cmccarthy is offline   Reply With Quote
Old 08-14-2010, 10:04 PM   #7
mad man
mad man's Avatar
never had that problem put 175000 + on 2 of them
mad man is offline   Reply With Quote
Old 08-14-2010, 10:38 PM   #8
Cowboy
Pre-Staged
ball joints or radius arm bushings will cause this!
Cowboy is offline   Reply With Quote
Old 08-14-2010, 10:51 PM   #9
mach9
Some tires will cause this. What tires do you have on it?
Mack Johnson
'86 Mustang footbraker
Pump gas 347
6.435 @ 104
https://www.facebook.com/NCslottracks?ref=hl
mach9 is offline   Reply With Quote
Old 08-14-2010, 10:56 PM   #10
EHA Racing
EHA Racing's Avatar
I'm having the same problem. Ball joints, steering stabilizer and sway bar links have been replaced. Nothing in the front is loose and an alignment didn't fix it. The more weight I put in the back the worse it gets. BTW it's a 2001 F-250 diesel.
The dealer told me it's probably the torque arm but there is no play in it at all.
2 different sets of tires and no change. If I run it at the recommended tire pressure I cant drive it over 60mph without it almost pulling me off the rouad.
Doug Vanstrom / P4046
SBF 114mm Turbo
4.67 @ 162.8 on 275's
7.51 @ 186 1/4 on 29's
www.vanstromperformance.com
www.eha.us.com
www.ultimateconverters.com
www.penngrade1.com
Quote:
Originally Posted by morris View Post
You want to go Bruder fast, Jackson fast it is from the flywheel back.
EHA Racing is offline   Reply With Quote
Old 08-14-2010, 11:31 PM   #11
abadwillys
abadwillys's Avatar
Garage
mine was like that, i put a new steering box in it not a cheapo reman, and its been like a new truck
UNDER PRESSURE RACING
1941 Willys Coupe
6.71 blown 468" Chevy
7.63et@180mph
abadwillys is offline   Reply With Quote
Old 08-15-2010, 01:15 AM   #12
Luxy72
Launchin
Luxy72's Avatar
It has BF Goodrich All Terrain tires on it...it's been like this for a while...even before all the items got replaced...I'm starting to think @ 200,000 the ball joints may need to be replaced...the front carrier bearings are shot and howling so I may just take a weekend to rebuild the whole front end of the truck...front axle, u-joints, ball joints...aside from that the diesel runs its balls off.
Old 08-15-2010, 03:06 AM   #13
lukelabob
Member
Pullin gears
lukelabob's Avatar
replaced every thing on my 2000 even gear box still has some slop i think its in the slip shaft in the colum!
lukelabob is offline   Reply With Quote
Old 08-15-2010, 09:22 AM   #14
JeffMcKC
JeffMcKC's Avatar
If its the slip shaft you will get a clunk at parking lot speeds over the lightest bumps, the sway bar links the same way, they are very sensitive to tread "wiggle" on new tires the tread is tall and the rubber moves around under the tire ( feels like the back will pass the front) also if your squating the back the toe will change, I cant belive your not getting pinion shudder then you will need a air bag set up to maintain the ride height. Ball joints every 40,000 are very common the Ford ones are cheaper than the part store just jack the front up put a bar under the tire and lift very easy to check
"IF IT DOES NOT HAVE A TRAILER HITCH ITS A RACE CAR!!!"
TRZ Dealer
2012 Winner SSSB/NA 9.67 @ 139MPH
2007 Winner SB/NA Drag Week 9.98
Thanks Curtis @ RFD Heads and Intakes
http://www.raceflowdevelopment.com/
JeffMcKC is offline   Reply With Quote
Old 08-15-2010, 10:08 AM   #15
Leonard 95
Leonard 95's Avatar
Quote:
Good lord 200000 miles on original set of ball joints, I bet they are shot. I start seeing them going bad around 60000 to 100000 miles. Get the ball joints replaced and see what happens, then try loosen the sector shaft adjustment on the gear. The most common things to wear out on front ends on these are ball joints, sway bar bushings and links. The newer f250's, 2005 and up had alot of issue with steering wander, think there was a tsb out for adjusting the gear then replacing it if it doesn't fix it.
