PA Transbrake c4 pro tree - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 08-04-2010, 11:42 PM   #1
Dist.Forward
Member
Pullin gears
Dist.Forward's Avatar
Default PA Transbrake c4 pro tree
Anybody used the Pro 4.0 c-4 valve body from performance autaaaaaaaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
Dist.Forward is offline   Reply With Quote
Old 08-05-2010, 09:21 AM   #2
1320Motorsports
Spooled up
1320Motorsports's Avatar
Default Re: PA Transbrake c4 pro tree
Well what makes it a pro 4.0 ... is just the transbrake solenoid...
If your asking about the difference with the "pro" transbrake solenoid ... It makes a difference in reaction times for sure and if your running a comp. Heads up class its must IMO.
Now if your asking abou PA valvebodies ... I have ran all their full-man's with TB and electric OD in all my stangs with AOD's or 4R7OW's as well as a bunch of customers cars. And they work great never had a problem with them ever!! But as far as the C4 valve body we actually just took the C4 out of our renegade car and put the FreddyBrown A03 back in it cause the C4's are ticking time bombs. But we had Frank lupo & sean from pro-formance build our C4 with the "pro" transbrake and it most def made huge difference... You'd be amazed in the R/T times difference between the 2 trannys
Team A&E Motorsports
OverKill Performance
Tim@ MPR
Jermey@ UPR Products
"The Red Rocket" Nmra Efi Renegade# 4124
1320Motorsports is offline   Reply With Quote
Old 08-05-2010, 08:07 PM   #3
Dist.Forward
Member
Pullin gears
It was supposed to read Anybody used the Pro 4.0 c-4 valve body from Performance Automatic and had any ups or downs with it
Resources saved on this page: MySQL 2.27%
