Go Back   Yellow Bullet Forums > Technical Section > Tires - Mickey Thompson Tires
Old 07-26-2010, 11:05 PM   #1
HardOnRacing
Spooled up
HardOnRacing's Avatar
Default Which should I run??? Radials or Slicks?
The big debate going on in my head is which do I want to run Radials or Slicks? A little about my car 1st, it’s a mini tub outlaw S/S car, Dbl adj. rear coilovers, single adj. front coilovers, Glide w/ brake, BBF nitrous, 3.55 gear, with me in it weighs about 3300 lbs. I have 12” wheels and can fit a 29/10.5W w/o problems. I really don’t want to put HP #’s out there. The tracks I will run at on a 1 – 10 scale, the best would be a 8, but the worst would be a 3 to 4 on a good night(this is the closest to me) as far as track prep goes. I want to run some grudge races, yet I want to run some of the S/S races (28/10.5 non W) but most of all I want to go fast as possible and of course like everyone else I want to do it consistently! So I guess my question behind this post is…. Why should I run this tire or why should I NOT run the other? Or better yet, whats the pros and cons of running the given tire?
All you little sum Bitches bunch up and all you BIG sum Bitches Line up!!!
HardOnRacing is offline   Reply With Quote
Old 07-27-2010, 12:03 AM   #2
team hyperactive ez555
Default Re: Which should I run??? Radials or Slicks?
28s,stiffs,tubes,screws or bead locks. grudge racing, consistency at most tracks.
team hyperactive ez555 is offline   Reply With Quote
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
YellowBullet.com
